First oil change - JeepForum.com
post #1 of 40 Old 01-18-2012, 08:26 AM Thread Starter
MiguelT678
2012 WK
First oil change
Hi everyone. my '12 GCO just hit 5,000 miles. The service manager told me to wait until I get an EVIC message to schedule the oil change. What's your opinion on this? I trust him, but wanted to ensure I should continue trusting him
MiguelT678 is offline
post #2 of 40 Old 01-18-2012, 08:30 AM
HeliDriverEC30
The oil change message on the EVIC can be changed. Check the service schedule that came with the jeep. Then read your manual on how to change your EVIC oil change interval. I'm pretty sure you are correct but I've got an 08' Diesel GC and it's every 10,000.
HeliDriverEC30 is offline
post #3 of 40 Old 01-18-2012, 08:35 AM
danteg
The manual says service at 8,500 miles (V6). I had my first oil changed at 5k.
danteg is offline
post #4 of 40 Old 01-18-2012, 09:25 AM
LS1_DOC
Junior Member
On the wk2 i do not believe the interval is changeable. I think you will be just fine waiting for the evic. Just make sure you dont go over the the 8,000 mile mark.
LS1_DOC is offline
post #5 of 40 Old 01-18-2012, 09:53 AM
nathantw
2012 WK
That brings up a good point. What happens if we change the oil ourselves. How do we reset the EVIC so it'll know we changed the oil? I don't remember seeing anything that dealt with that.
nathantw is offline
post #6 of 40 Old 01-18-2012, 10:40 AM
kloppk
From the FAQ thread at the top of this forum...
http://www.jeepforum.com/forum/f309/...ation-1173618/
Similar info in your owners manual too.
Oil Changes
The WK2 has an oil change indicator system. This system displays a “Oil Change Required” or “Oil Change” message at appropriate intervals on the instrument cluster. The Oil Change Indicator system uses the Powertrain Control Module to process a variety of inputs and then decides on an oil change interval. The factors which point toward severe use include the following:
* Ambient temperature inputs which indicate extended periods of low temperature operation
* Average vehicle speeds which indicate stop-and-go driving
* Run time which indicates prolonged idling
* Trip lengths and coolant temperatures which indicate short trips
* Engine RPM and engine loads which indicate trailer tow usage
* Fuel indications of an ethanol percentage of 60 percent or greater
The oil change indicator can be reset using the following steps:
1. Turn the ignition key to ON but do not start the engine. If you have the push button start, press the button twice with the key in the vehicle and your foot OFF the brake.
2. Slowly depress the accelerator to the floor and release it three times within 10 seconds.
3. Turn the ignition key to the OFF position (or press the push button to turn OFF).
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 40 Old 01-18-2012, 11:20 AM
nathantw
2012 WK
Thank you for that. I was waiting to read that we had to jump through a few more hoops in order to reset it. I'm sure that's a quick and easy way to do it in practice, but just reading it sounds much more involved than just pressing a reset button a display.
nathantw is offline
post #8 of 40 Old 01-18-2012, 11:30 AM
kkreit01
For a brand new vehicle, I typically like to do one around 1500 -- sometimes even less if the vehicle has sat on the lot long enough. Remember, there is also a time interval requirement. EVIC, 6 months, 8500 miles -- whichever comes first. I plan to change mine this weekend (around 1700 mi), and then take advantage of the 2 free dealer OCIs afterwards.
When I bought my car (MKZ), the oil change light came on during the test drive. It was sort of a "demo", but only had 700 mi. However, those 700 mi were all very short trips, and it was on the lot for ~ 1 year (owner drove it). Thus, I changed the oil the weekend I brought it home.
kkreit01 is offline
post #9 of 40 Old 01-18-2012, 11:50 AM
WvTaco
2011 WK
I did the first at 6 months. I was at 7k miles. Second I scheduled next mont at the 1 yr mark. Might have 13k by then.
WvTaco is offline
post #10 of 40 Old 01-18-2012, 12:43 PM
rustyosaurus
2012 WK
so you really should change the oil at 8500 (or whatever your JGC requires) OR 6 months? i only drive 8000 miles a year so i've been pretty much doing it yearly on my other car, but i'll start doing it every six months on the new jeep.
rustyosaurus is offline
post #11 of 40 Old 01-18-2012, 01:01 PM
txwest
2012 WK
I special ordered my JGC. I changed mine to Mobil 1 blend at 500 miles. I don't trust break-in oil. I am coming up on 5k. I will put Mobil 1 fully synthetic in it at that time. 5k should be enough to seat the rings and lubricate the seals. If it's not, the 100k warranty can take care of that.
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #12 of 40 Old 01-18-2012, 03:21 PM
jacobsed
I like to visually check the oil....I actually check the level and color on the dipstick. If its getting too dirty before the oil is due then I change it. I guess that is old school though.
jacobsed is offline
post #13 of 40 Old 01-18-2012, 03:51 PM
superserialMBP
2012 WK
My Jeep dealer here in Denver said that at high altitude you want to do it every 5,000 miles instead of every 8,000 or whatever it says in the manual. I think I'd do every 5,000 anyway to keep it running best.
A mechanic I trust once told me that it is best not to follow the recommended oil change mileage when you get more miles on a car. Car makers want their engines to start to break down after 100K miles so you go and buy a new one, but still feel like your car lasted a while so you don't dump the brand.
2012 Laredo X : QTII, 430N nav, true blue pearl
superserialMBP is offline
post #14 of 40 Old 01-18-2012, 09:37 PM
unimatrixzer0
The manual says every 8000 miles, but I was also talked into buying scheduled maintenance care. It says 3 months or 4,000 miles. It's basically the same schedule but they added an extra oil change in between all the scheduled services in the book. You better believe I'm taking my Jeep in for an oil change every 3 months! lol. I only drive about 9000 miles a year.
unimatrixzer0 is offline
post #15 of 40 Old 01-19-2012, 04:17 AM
peckmv
You should change your oil at or close to the recommended mileage based on light duty driving. If you have severe driving, such as towing then it should be done sooner. I wouldn't go over 5000 miles under these conditions, although the EVIC will most likely alert you. The time is also important. Never go over 6 months, reguardless of the mileage. The reason is that you oil becomes acidic with time and can actually eat bearing surfaces with micro pitting. Just looking at your oil is useless. You can't tell by looking at the level of black in the oil. The best way is to have an oil sample sent out for testing and that will tell you what condition the oil is in at that mileage/time interval. Most people don't bother with this due to cost and time. Thats why they came up with the mileage/time schedule because it covers most drivers.
peckmv is offline
first oil change supersport126 WK2 Grand Cherokee Forum 3 11-17-2011 06:36 PM
V-6 oil change RB145 WK2 Grand Cherokee Forum 13 05-08-2011 04:03 PM
Oil Change nchanin WK2 Grand Cherokee Forum 11 12-27-2010 01:12 PM
V-6 oil change RB145 WK2 Grand Cherokee Forum 7 10-21-2010 06:00 AM
First Oil Change Dabitz WK2 Grand Cherokee Forum 4 09-08-2010 05:43 AM
