FINALLY finished my Rock Rail Install - JeepForum.com
post #1 of 11 Old 06-18-2013, 09:15 PM Thread Starter
MartyA
2012 WK
I actually got the parts about two months ago and once I started it still took a month to get the installation finished but I'm very happy with the results.
Good
  1. Very sturdy and high quality construction
  2. They look great on the vehicle
Less Good
  1. The installation was a pain until I ignored the instructions
  2. The rails stick out a bit further than I expected so my leg pushes against it as I'm getting in.
I found out that prepping for the installation was VERY important. When I was prepping the nuts and bolts I found three nuts that had welding flash on them (see the pic). Filing that off up front was far better than finding it in the middle of the installation. The rear (inside) bolts also thread into nuts welded to the rail. I found that those threads were pretty rough and getting the bolts in and out once cleaned them up nicely.
For the installation itself everything was pretty much on track until I tried to bolt the front (outside) of the rail to the body. The instructions say to bolt the back of the rail on BEFORE the front. There was NO WAY that the front could be attached when following those instructions. The picture with my hand in it shows that the outside top of the rail was at least an inch away from the body and nowhere close to slipping over the very short bolts.
I took the rail down and walked away from it. For quite a while. But that was mostly due to other responsibilities getting in the way.
Finally I came back to the install and this time I put the front on first. The bolts snapped right into place and the front installation worked perfectly. Getting the nuts on the short bolts was very easy. Moving to the back (inside) of the rail I had to use my floor jack to push the rail up to where the bolt holes lined up but that was just awkward, not impossible.
So I bolted everything up with plenty of threadlocker and I'm done! I still need to spray some flat black paint over the scuffed nuts but that doesn't count
Next is the winch mount!! That may take me some time to build up to
MartyA is offline
post #2 of 11 Old 06-19-2013, 05:53 AM
txwest
2012 WK
Nice install!
I agree, that slag was ridiculous.
The winch mount is quite easy, just a little time consuming. I created an in-depth build thread for the winch mount. Enjoy!
http://www.jeepforum.com/forum/f309/...stall-1535128/
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #3 of 11 Old 06-19-2013, 06:43 AM
lysol
2013 WK
Looks great!!!
Can you think of any reason that Mopar decided that open ended rock rails are a good idea?
MINE > '14 JKUR Anvil
HERS > '13 WK2 Overland Summit V8 Mineral Grey
lysol is offline
post #4 of 11 Old 06-19-2013, 07:37 AM
NCJeepGC
2012 WK
Looks good! Thanks for the pics!
2012 Jeep WK2 Laredo 4X4
NCJeepGC is offline
post #5 of 11 Old 06-19-2013, 09:56 AM
kkreit01
Looks great. Sloppy Chinese hardware. Are they made in China? I know other Mopar accessories are.
kkreit01 is offline
post #6 of 11 Old 06-19-2013, 05:45 PM
Alaska-HWY JK
Originally Posted by lysol View Post
Looks great!!!
What do you mean by open ended? Mine aren't.
Alaska-HWY JK is offline
post #7 of 11 Old 06-19-2013, 07:15 PM
lysol
2013 WK
They aren't hollow?
lysol is offline
post #8 of 11 Old 06-19-2013, 10:59 PM
FranksWK
2005 WK
Yeah mopar likes when their wiring hanesses are made in china.....
FranksWK is offline
post #9 of 11 Old 06-20-2013, 06:50 AM
bulj
2012 WK
Good write up and thanks for the info.
Where did you order them?
'12 Overland 4x4 V6
bulj is offline
post #10 of 11 Old 06-20-2013, 03:05 PM Thread Starter
MartyA
2012 WK
Sorry I've been offline for a few days and didn't respond.
Thanks for the kind comments!
For the question about 'open ended', I'm not sure what you mean by hollow. The steel outer skin is held about an inch off the bottom of the body by internal bracing. I don't call that hollow? And I think it's actually a good choice since that will allow any water in the rail to drain out thru several holes.
But typical road splash isn't going to get in there much - they are pretty well closed up once they are mounted.
And if you're questioning the strength I think you're wrong. They function really well as a step and I jacked a wheel off the ground with the jack on the bottom of the rail.
As for china vs elsewhere? Who knows, and for basic fabrications like this I don't think you're going to find anyone who won't use a low bidder. I want to buy american (for example, I won't shop at WalMart) but we don't always have a choice.
MartyA is offline
post #11 of 11 Old 06-20-2013, 03:06 PM Thread Starter
MartyA
2012 WK
Oh, and I ordered them from my local dealer but I did it thru my friends auto shop so they gave him the trade price vs retail. I could have bought them for the same price online but then I'd pay shipping.
MartyA is offline
