Factory Tire Wear - JeepForum.com
post #1 of 30 Old 01-20-2014, 06:55 AM Thread Starter
Chrisfol82
Factory Tire Wear
I bought a 2013 Grand Cherokee a little over a year ago, and have about 16,000 miles on it.
Its a laredo X with the 5.7 v8, 4wd with tow package.
With 16,000 miles on it the rear tires are almost bald, the fronts are a quite a bit better but not a whole lot.
Anyone else get this poor of life out of their factory tires? Why would the rears wear so much more than the fronts? Its all wheel drive so its not like I'm doing burn outs every time i start moving... Just wondering if this anyone else had the factory tires wear so quickly, and hopefully i can expect better wear life when i replace these with something new soon.
Chrisfol82 is offline
post #2 of 30 Old 01-20-2014, 07:39 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
It would help if you mention wheel size and brand. My 20inch GYs went over 40,000 miles replaced only because of a nail in an unrepairable area. Do you do a lot of towing? The QTII AWD is biased a little to the rear.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 30 Old 01-20-2014, 07:40 AM
jim_in_PA
2012 WK
16K miles...rear tires nearly bald, but not the fronts. Have you not been rotating your tires regularly? Outside of a defective tire, if you are properly rotating (I do it at oil changes), all should have similar wear.
That said, 16K miles with that kind of wear would be very unusual. Most folks will get 30-50K miles from a set of tires, depending on the tire and other factors. Something is amiss...
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #4 of 30 Old 01-20-2014, 07:44 AM
kkreit01
Sound like they needed rotating quite some time ago. However, my OE Michelin Latitudes were horrible as well. They were down to 5/32nd at 22K mi. I replaced them before winter, and couldn't be happier.
kkreit01 is offline
post #5 of 30 Old 01-20-2014, 08:23 AM Thread Starter
Chrisfol82
Admittedly i have not rotated them as I should have, and i know that doesn't help, but the fronts aren't much better, so regardless of them not having been rotated they shouldn't have worn out that quick. I don't remember specifically what the tire that came on it stock, ill have to go take a look, but they are the 18" rim tires. Have not done much towing at all. I'm probably going to be getting them replaced in the next week or so just was curious if anyone else had experienced such terrible wear from the factory tires. Sounds like kkreit had some pretty bad wear too, if i rotated mine when i should have id probably be close to the wear you described.
Kkreit how many miles are on your new tires, what kind did you go with, and do they seem to be wearing better if you have enough miles to tell?
post #6 of 30 Old 01-20-2014, 09:17 AM
MarkSRT8
2012 WK
I've got 28k on the OEM tires on my "12" and there is a lot of tread left! But tire air pressure is checked weekly and set at 35psi. Rotated once a year.
MarkSRT8 is offline
post #7 of 30 Old 01-20-2014, 09:43 AM
eibyer
I have 17" Forteras and it finally came off today (5/32 treads left) at 28,400 miles, wasn't planned at all. I had an unrepairable damage on one tire. Got a set of Cooper Discoverer tires, looks more aggressive than my factory tires and not loud at all from the 10 short miles I drove from DT to work.
eibyer is offline
post #8 of 30 Old 01-20-2014, 10:50 AM
Bullheadbud
2014 WK
Very odd that your rear tires have worn faster than the fronts.
Bullheadbud is offline
post #9 of 30 Old 01-20-2014, 11:01 AM
DRKRED12
May have a lot to do with proper rotation and proper air pressure. I also check my air pressure once a week and rotate my tires at each oil change. 20,000 miles on 20" Goodyears on 2012 Altitude with hemi and tires still look new. Also highly contraversial but I run Nitrogen in my tires. Seems to hold constant air pressure more consistent than air.
DRKRED12 is offline
post #10 of 30 Old 01-20-2014, 11:16 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I have never heard of rears wearing faster - it is always the front since they see more wear because of steering.
1) Did you rotate, and hence why the rears are worn more?
2) Are both rears worn evenly?
3) Are they worn evenly across each tire, or is the inside, outside, or middle worn more? That would generally indicate an alignment issue.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #11 of 30 Old 01-20-2014, 12:00 PM Thread Starter
Chrisfol82
I was surprised that the rears were wearing faster than the fronts as well, i expected the opposite, and that is partly why i hadn't rotated them to begin with.
They are worn pretty evenly, and pretty evenly across the tire. The pressures have remained pretty consistent as far as the dash read out they have been pretty steady at ~35 PSI.
Could the rear be out of alignment?
post #12 of 30 Old 01-21-2014, 04:58 PM
oldmac1
2015 WK
My last two GC's had trouble reaching 20k miles with the stock tires. I do maintain the tire pressure and rotated them frequently and still had no luck with them. Needless to say I replaced them with different brand of tires and had better luck. These pot holes we have in the highways can knock the alignment out also. It had been recommended to me to get a tire with harder rubber, the claim is a longer tire life but a harsher ride. Your not alone in needing to change stock tires early. Good luck.
Oldmac1
15 GC Overland
12 Liberty
15 Rubicon Unlimited
oldmac1 is offline
post #13 of 30 Old 01-21-2014, 05:17 PM
fwdjeep
2013 WK
I would say check wheel alinements both front and rear and yes there is an alinment on rear as well
Has the rear been set up correctly
fwdjeep
Alais Scott
Mount Cotton Queensland
Australia
fwdjeep is offline
post #14 of 30 Old 01-21-2014, 07:27 PM Thread Starter
Chrisfol82
Well should be taking it in for some new tires tomorrow, so will have the alignment checked when they put them on. I can only assume the rear was set up correctly from teh factory, it hasn't been in a shop so far to have it checked.
post #15 of 30 Old 01-21-2014, 08:12 PM
ColoradoGrand
2015 WK
2012 Grand Cherokee Laredo X with 5.7, 18" wheels and tires
I replaced my Michelin Latitudes at 32,000 miles. I keep the Jeep aligned and rotated regularly. The rears were well past the wear bars. I probably should have replaced the tires at 28,000 miles. I replaced with Yokohama Geolanders.
I wasn't impressed with the tires only lasting 30,000 miles or so.
ColoradoGrand is offline
