Factory defect warning: Grease in front wheels (3/14 build date) - Page 4 - JeepForum.com
post #46 of 344 Old 05-06-2014, 10:30 PM
redddog
Hey guys. Taking delivery of a LTD tomorrow.
You think this is an issue that can be spotted by inspection before delivery? I asked my guy to take a look, I just hope it can be identified by looking at it rather than waiting for it to fail.
Thanks all
redddog is offline
post #47 of 344 Old 05-06-2014, 11:04 PM
GoPlzGo
formerly 14summithemi
GoPlzGo's Avatar
2015 WK
Thanks all
Absolutely. The mess is unmistakable. Just also be sure as previously detailed they look at the edge of the outer boot outboard ring area for ANY grease oozing from under the boot edge. Small amount of grease now = BIG problem later (very soon). Not trying to scare, just focus attention.
May your delivery be what it should be, a joyous event!
GoPlzGo is online now
post #48 of 344 Old 05-06-2014, 11:40 PM
Kablemodem
2014 WK
Overland with 3/14 build date with 1,600 miles and no signs of grease so far.
Kablemodem is offline
post #49 of 344 Old 05-07-2014, 06:40 AM
Clirry
2014 WK
Dropped her off last monday, and today, still not ready. They said it could be few days or more... nightmare!
Philly and other victims... how long did your jeep stay at dealerships for the repair?
Brilliant Black Crystal Pearl, Limited, OR1, QTII, Plasti dipped
Clirry is offline
post #50 of 344 Old 05-07-2014, 06:48 AM
redddog
Yeah, I'm sure its pretty obvious when it happens. I was wondering if you can tell that the part is faulty BEFORE it actually happens by looking at it
redddog is offline
post #51 of 344 Old 05-07-2014, 08:34 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
The faulty part appears to be a clamp that is loose but not off or hanging Si only early sign is grease not yet flung but just starting to get under boot edge.
White '15 JGC SRT Red Vapor...Borla ATAK Cat-back w/ ceramic coated axle-back, aFe Momentum GT Pro 5R Stage-2 Intake & Billet Tech Oil Catch Can
post #52 of 344 Old 05-07-2014, 08:35 AM
redddog
So they should be able to see if it's loose?
redddog is offline
post #53 of 344 Old 05-07-2014, 08:51 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
It may be loose enough to turn, nobody knows. ANY grease showing around boot edge = Defective.
post #54 of 344 Old 05-07-2014, 08:53 AM
MickinNY
2013 WK
[QUOTE=14summithemi;22680529]^^^^^
Yes, the MDH is assigned in the computer when the body is dropped onto "frame". The Date of Manufacture is when it leaves the line, normally same day or next day. However, 2/28 is a Friday and your "H" is 9pm so it left the line in March, hence, your Date of Manufacture is 3/14.
I'm not following you on this...maybe I need another cup of jo.
First off, how does the H equate to 9pm?
Secondly, if the body was dropped onto "frame' Feb. 28 & as you say DOM is normally same day or next, then his build date of Mar. 14 tells me his Jeep didn't leave the line till 2 weeks later. What am I missing?
MickinNY is offline
post #55 of 344 Old 05-07-2014, 09:14 AM
FlyingDiver
2014 WK
[quote=MickinNY;22731185]
3/14 is not March 14th, but March of 2014.
'14 Grand Cherokee Overland V8 4x4, ORA II, ATP, Blue Ox baseplate, SMI AF1 brake system
FlyingDiver is offline
post #56 of 344 Old 05-07-2014, 09:19 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
As FlyingDiver said, 2014....I know the H is 9pm cause I was referring to his MDH label of 022821, the H (21) being 2100hrs military time or 9p.
Have another cup of Jo on me.
post #57 of 344 Old 05-07-2014, 09:26 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
Just realized I need another cup of Jo too. I mentioned Friday but never followed thru on thought. Since body drop was 9pm on last day of month and they can't finish it in 3 hrs the vehicle would have been finished on Mar 1, 2 or 3 (Monday). Pretty sure JNAP is building on weekends but either way it got finished in March so that is why the Date of Mfr = March.
post #58 of 344 Old 05-08-2014, 01:20 AM
goodhomer
I've been waiting since (this) Monday. Curious too... what reason did they give? Did they give you a rental? Hopefully this isn't the beginning of a part shortage. Good luck.
EDIT: Someone on Jeep Garage reported that their parts are on back order.
goodhomer is offline
post #59 of 344 Old 05-08-2014, 01:26 AM
Kablemodem
2014 WK
My MDH is 022820, so within an hour.
post #60 of 344 Old 05-08-2014, 06:18 AM
Clirry
2014 WK
Originally Posted by goodhomer
I've been waiting since (this) Monday. Curious too... what reason did they give? Did they give you a rental? Hopefully this isn't the beginning of a part shortage. Good luck. EDIT: Someone on Jeep Garage reported that their parts are on back order.
Yeah, they offered me free rental car but I opted. I asked, looks like it ll be ready today. If axle grease fails again...hopefully NOT) but, I might hold it and call them to check if parts are in stock or not. Ha.
Clirry is offline
