Enter-N-Go not working - JeepForum.com
post #1 of 16 Old 03-18-2012, 03:15 PM Thread Starter
yucca5
2012 WK
Maybe I'm just stupid. But I picked my very first Jeep up yesterday and haven't been able to get the Enter-N-Go to work since. The dealer demonstrated it, so I'm guessing it hasn't timed out. The locks on the door handles don't work either. Any suggestions? Any trick to this? Am I missing something obvious?
yucca5 is offline
post #2 of 16 Old 03-18-2012, 03:35 PM
genciu
2012 WK
The way it is suppose to work is you keep your key in your pocket and just touch the door handle as if you are going to open the door, the doors should then unlock and then you open the door... get in the car, hit the brake pedal and push the start button.
However, many of us, including myself, have had problems with this system.
In this case, slide the button near the key ring, remove the key and use it to open the door. Then get in the car, remove the start button, using your fingernail and then insert the key-fob into the hole and use it as a key to start the car.
Hope this works until you can get to the dealer.
genciu is offline
post #3 of 16 Old 03-18-2012, 03:50 PM Thread Starter
yucca5
2012 WK
I thought about trying that - but if the start button works fine with the fob in the car, it's not an issue with the fob, right? I've been starting it normally....
It's just the unlocking and locking that's not working. I'll try it anyway though.
yucca5 is offline
post #4 of 16 Old 03-18-2012, 03:55 PM
RageOfFury
2014 WK
I believe you can turn off/on the keyless unlock/lock in the EVIC? Check the EVIC settings!
RageOfFury is offline
post #5 of 16 Old 03-18-2012, 04:00 PM
superserialMBP
2012 WK
You have to have the key on your person for it to work. I've had it not work right in cold weather though. When it is like 25F or less, the sensors seem to not work very well for me. I'd say when it is warmer than 25F the keyless entry system works 95% of the time on the first try.
I just wish my tailgate latch handle had the same sensor so I could get into my cargo area without unlocking with the keyfob button.
2012 Laredo X : QTII, 430N nav, true blue pearl
superserialMBP is offline
post #6 of 16 Old 03-18-2012, 05:26 PM
Justal13
2012 WK
??? Just push the button on the chome strip on the rear hatch and it will unlock (or lock) without using the fob. Reaching underneath the right side of the chrome strip is a rubber-covered button that will pop the upper glass only (also without using the fob).
By the way, make sure you are touching the back of the door handle only to unlock (do not push the botton). To lock, push the button only with your finger-tip, do NOT grab the back side of the handle.
Best luck.
Justal13 is offline
post #7 of 16 Old 03-18-2012, 06:02 PM
padgett
2012 WK
Only works if locked when you have the fobik, then I can just touch the handle and it says hello. Would be better if it lit up when I get within a few feet. Frankly I could do without the flipper glass if it meant having a usable amount of vision out the back, as it is you cannot see anything that isn't at least four feet high and in the center. Will be adding a rear vision camera RSN.
One of these is a diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline
post #8 of 16 Old 03-18-2012, 07:18 PM Thread Starter
yucca5
2012 WK
That was it! Not sure why the dealer disabled it after demonstrating it, but there you go...
yucca5 is offline
post #9 of 16 Old 03-18-2012, 09:56 PM
padgett
2012 WK
Probably to keep cars from being stolen if a fobik goes astray, why some turn off the lights and horn, just forgot to reset when you picked it up.
padgett is offline
post #10 of 16 Old 03-21-2012, 07:44 PM
hutchison101
2011 WK
Recently my tailgate button doesn't work at all. The system is not good At all.
hutchison101 is offline
post #11 of 16 Old 03-21-2012, 08:05 PM
MaineJeep11
2011 WK
Have you tried changing the battery in the key?
MaineJeep11 is offline
post #12 of 16 Old 03-28-2012, 11:58 AM
Rdrakea
2011 WK
My 2011 Grand Cherokee is not a year old yet, but my main fob that I carry quit allowing me to enter and start the car without a key. I tried my 2nd fob and it works fine. I bought a battery today to replace and see if that fixes it (haven't had a chance to try yet), but funny thing is... the buttons on the fob work fine to lock/unlock the doors, remote start, etc.
Rdrakea is offline
post #13 of 16 Old 03-28-2012, 12:15 PM
Iamnid
2011 WK
I have a similar problem... buttons on the fob work fine but the button on the door to lock only works 50% of the time and the jeep occasionally tells me the key isn't present
Iamnid is offline
post #14 of 16 Old 03-28-2012, 03:35 PM
MaineJeep11
2011 WK
Change the battery, mine did this too as I was leaving the key in the vehicle overnight in the cold and drained battery. It's been fine since battery was changed. It's likely not the button on the door but low battery in key.
post #15 of 16 Old 03-28-2012, 06:28 PM
Rdrakea
2011 WK
Replacing the battery solved my problem. I don't leave my key in the car or even in my pocket for long periods of time, so either the battery was old/weak to begin with or the thing really sucks the juice out quick.
Rdrakea is offline
Enter-N-Go Issue sdlimited WK2 Grand Cherokee Forum 2 03-02-2012 08:09 AM
Trailer Giveaway Ends Tomorrow - Open to All & Shipped to Winner - ENTER NOW! JF_Admin WK2 Grand Cherokee Forum 0 02-21-2011 11:49 AM
Viper Max Winch Giveaway Ends Tomorrow - ENTER NOW! JF_Admin WK2 Grand Cherokee Forum 0 10-19-2010 10:39 AM
Enter your Jeep in the October 2010 GCOTM Contest! GraKee99 WK2 Grand Cherokee Forum 2 09-23-2010 08:32 PM
Enter your Jeep in the September 2010 GCOTM Contest! Jones WK2 Grand Cherokee Forum 2 08-22-2010 02:48 AM
