Engine light on, ECO sign no longer displays - JeepForum.com
post #1 of 13 Old 02-24-2013, 09:04 PM Thread Starter
nyrhockey23
Had that happen on the way home last night. I think (and hope) it's because the oil change is due? had never seen this before.
nyrhockey23 is offline
post #2 of 13 Old 02-24-2013, 11:14 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
The check engine light does not come on when the oil change is due. You will get a text notice in the EVIC display area.
Could be something as simple as a loose gas cap, but can't tell without the fault code. You need to swing by an auto parts store and have them read the code, buy or borrow a ODB reader, or swing by the dealer.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 13 Old 12-10-2013, 09:33 AM
2cobras
I have a 2013 Hemi with 14,000 miles on it and I am having the same issue.
I heard my check engine light come on last night & noticed the ECO sign no longer displays.
Any word on what the problem was with yours?
Jeff
2cobras is offline
post #4 of 13 Old 12-10-2013, 09:38 AM
OverlandSummitt
Jeff
There is an option in the Setup menu that can deactivate the ECO symbol from being displayed. Check that out first.
OverlandSummitt is offline
post #5 of 13 Old 12-10-2013, 02:29 PM
2cobras
Thanks, I will check it out but I never turned it off. It went off when the check engine light came on & the gas mileage has dropped.
2cobras is offline
post #6 of 13 Old 12-10-2013, 04:05 PM
ColdCase
ColdCase's Avatar
2011 WK
What is the error code that is setting the check engine light? I'm not surprised that something wrong in the engine disables ECO mode, the check enging indicator means something is wrong..... unless I'm miss-reading the question.... .
ColdCase is offline
post #7 of 13 Old 12-11-2013, 06:54 AM
2kg4u
2014 WK
If your check engine light is on you need to have the vehicle scanned to see what the problem is. Any other symptoms you are experiencing are secondary, and quite possibly caused by the condition that is setting the CEL. I am new to Chrylser products and not sure what the onboard diagnostice capabilities are. I thought you could read DTC's (diagnositic trouble codes) yourself without a scanner, but if that is not the case take your vehicle to Autozone. They will scan if for free. Post the DTC's and there are all sorts of people on the forum that can tell you if they are critical or not, and suggest possible fixes.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #8 of 13 Old 12-12-2013, 08:34 AM
steveinaz
2011 WK
Try re-tightening the gas cap first, but it takes a few days to extinguish the check engine light---speaking from personal experience 1 week ago.
2011 Grand Cherokee Laredo 4X4
3.6L V-6 with Selec-Terrain
Off-Road Adventure package
Tow package
steveinaz is offline
post #9 of 13 Old 12-12-2013, 08:48 AM Thread Starter
nyrhockey23
This was due to the cylinder head issue that's not uncommon to '12 JGC's. Had it fixed, then reappeared a few days later and had it replaced. Been fine since.
post #10 of 13 Old 12-12-2013, 11:58 AM
WvTaco
2011 WK
i had a air leak in the filler neck its self, on my only c/e light.
but c/e light = no eco light.
for reference your oil change at 6 months on mine( 11 v6) will not display, but at the mileage it will tell you this with a chime.( i usually hit time before mileage )
WvTaco is offline
post #11 of 13 Old 12-12-2013, 01:28 PM
2cobras
Well I dropped it off at the dealer this morning and I am waiting for a call to let me know the status.
I hope it isn't anything major.
2cobras is offline
post #12 of 13 Old 12-13-2013, 02:38 PM
2cobras
Well I just picked up my Jeep and they couldn't find anything wrong, they think it was just a glitch.
They reprogramed the PCM and A/C control module per TSB's.
2cobras is offline
post #13 of 13 Old 08-18-2017, 12:58 PM
770michaelr
Attn: - nyrhockey23, When you say and I quote" - This was due to the cylinder head issue that's not uncommon to '12 JGC's. Had it fixed, then reappeared a few days later and had it replaced. Been fine since. - are you strictly referring to the fact that the reason why your ECO Indicator Light went out on yours & I presume 2012 JGC was that is was Cylinder Head Issue?
Again you stated that this seems to be a common thing on '12 JGC's is that correct? Or where did you read &/or be referred to about this type of problem on the 2012's?
Currently I have a situation where as the ECO - Fuel Saver Indicator in the instrument panel has gone-out and I'm really curious to know how serious this thing that you've mentioned about Cylinder Head problem does have a lot to due with cause....
Advise please
770michaelr is offline
