Easter Eggs - Page 6 - JeepForum.com
 15Likes
post #76 of 433 Old 04-27-2012, 09:13 PM
Justal13
2012 WK
I like the space in the foam insert inside the spare tire that is there for storing your trailer hitch ball mount. I picked one up today and will take a photo to post tomorrow.
Justal13 is offline
post #77 of 433 Old 04-27-2012, 09:43 PM
txwest
2012 WK
That's where mine rides since the first week I got her.
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #78 of 433 Old 04-28-2012, 01:29 AM
JasonJasoff
2012 WK
Originally Posted by padgett View Post
Flipper Glass Button
I have a new WK2 Laredo V-6 with the towing package & spent about 20 minutes trying to figure out how to open the flipper glass on the tailgate. Owners Manual just says "push the button on the liftgate". After a call to the dealer a black rubber button was found on the outside of the lift gate under the chrome strip and next to the license plate light. Cannot see unless very short. Is there any way from inside the cabin or a manual release anywhere ?
BTW can confirm the the windows do not lower with the remote.
Thats awesome. Had no idea I had a "flipper glass door." Thanks for the post!
JasonJasoff is offline
post #79 of 433 Old 04-28-2012, 03:31 AM
nigelh
2012 WK
Wk
Originally Posted by JeepOrvis97 View Post
Just to confirm this since I've seen it talked about on another thread but this feature does not exist in 2012 WK2s.
I can confirm that this feature is still there, only the contact is missing from under the rubber button in the fob.
I pulled my fob apart and used one of the others to press the button and the rear glass opened, so all you need is to take apart an old computer keyboard or mouse take out one of the contacts and glue it onto the under side of the fob to make it work..
There are two other contacts on the fob as well, one seams to do nothing and the other, just flashes the lights.
Does any one else konw what they are for, the remote start feature, if instaled must be one of them??
Regards, Nigel
WK2 GC 2012 Overland
True Blue, Saddle Trim
Hemi 5.7 V8
Tow Pack
nigelh is offline
post #80 of 433 Old 04-28-2012, 07:02 AM
bowlzilla
This doesn't work on our 2012 JGCL 4x2 Base:
Front Windows: You can roll them down with the remote. Just unlock the Jeep, let go of the button, and them immediately push the button and hold. It takes about 2 seconds before they start going down, and then they go until you release the button (not everyone knows this)
bowlzilla is offline
post #81 of 433 Old 04-28-2012, 08:35 AM
KC135flyboy
2008 WK
I tried the procedure to lower windows with key fob and had no success. Anyone else make it work ? This was a feature Honda had and I would greatly appreciate it.
KC135flyboy is offline
post #82 of 433 Old 04-28-2012, 08:40 AM
Heath
2014 JK Wrangler
Works on my 2011 Summit
2013 JKU Rubicon
Heath is offline
post #83 of 433 Old 04-28-2012, 08:42 AM
KC135flyboy
2008 WK
Tried both key fobs on 2012 limited no luck. Thx for responding
post #84 of 433 Old 04-28-2012, 09:47 AM
bowlzilla
Maybe it's a 2011 only thing since the models dropped $3000 between 2011 and 2012.
post #85 of 433 Old 04-28-2012, 10:35 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Can you elaborate more on how you made your 2012 fob window feature enabled? I did not really understand the above. I looked in the fob and have no idea what I am looking for if it is even possible.
2011 Billet JKUS
Jackal01 is offline
post #86 of 433 Old 04-28-2012, 11:28 AM
Justal13
2012 WK
The 2X push to lower front windows feature was dropped for all 2012 GC models. There is no way to activate the feature on the 2012's.
To activate the flipper glass 2X push button on your 2012 Fob, purchase a 2011 Fob off eBay and swap the rubber insert only. This is much cheaper than purchasing a new Fob and having to have the dealer program it.
There are several Fob button styles out there, so you have to search for the correct one. You cannot buy just the rubber insert at the dealer (you have to buy the entire Fob, and it is not cheap).
The other (2) pushbuttons are for the power opening rear hatch (only if you have the option) and the power folding 3rd seats (Durango Only).
Justal13 is offline
post #87 of 433 Old 04-28-2012, 12:43 PM
plynn7
2014 WK
I beleive nigelh is talking about the rear flipper glass and how to open it from the fob. If you are talking about rolling down the two front windows with the fob, it does not work on the 2012's.
2014 JGC Overland V6
Tech Package
Deep Cherry Red
plynn7 is offline
post #88 of 433 Old 04-28-2012, 07:03 PM
Heath
2014 JK Wrangler
Originally Posted by peckmv
Weight balance? Really
Yeah. Weight balance. A battery here, a ECM there. Hanging a heavy *** AGM battery at hood height toward the front of the vehicle, vs setting it low in the floor and centered, makes a tremendous difference in handling. And before someone chimes in with some "it's not a sports car" nonsense, handling is about safety more than performance.
2013 JKU Rubicon
Heath is offline
post #89 of 433 Old 04-29-2012, 02:18 PM
bowlzilla
Wow, the ignorance is strong in this one.
post #90 of 433 Old 04-29-2012, 05:10 PM
Ungerer
So you can unlock the flipper glass & then open it by lifting it up . By using the fob ?
Ungerer is offline
Jeep's Easter Jeep Safari Pic's kkuntz01 WK2 Grand Cherokee Forum 1 04-19-2011 03:14 PM
