Easter Eggs - Page 20 - JeepForum.com
 12Likes
post #286 of 432 Old 06-02-2014, 10:40 PM
GoPlzGo
formerly 14summithemi
GoPlzGo's Avatar
2015 WK
Originally Posted by Aquaforest View Post
Is there any benefit to that in the real world or is it simply a side-function of the engineering.
I guess it could use a daytime cutoff loop in it's logic/code.
GoPlzGo is online now
post #287 of 432 Old 06-02-2014, 11:48 PM
Heath
2014 JK Wrangler
It's not washer fluid. It's not the RF.
The water from the water hose he washing the Jeep with "tricks" the sensor in the actual door handle into thinking a hand is touching it.
As for a "benefit", I'm not sure I understand the question.
2013 JKU Rubicon
Heath is offline
post #288 of 432 Old 06-02-2014, 11:50 PM
Heath
2014 JK Wrangler
Huh?
2013 JKU Rubicon
Heath is offline
post #289 of 432 Old 06-03-2014, 05:09 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
Originally Posted by Heath View Post
Huh?
He quoted the water setoff thing and asked if there was any real world benefit so I just took him literally and of course there is no real world benefit ro lights coming onnduring day so I made my suggestion....that's all
White '15 JGC SRT Red Vapor...Borla ATAK Cat-back w/ ceramic coated axle-back, aFe Momentum GT Pro 5R Stage-2 Intake & Billet Tech Oil Catch Can
post #290 of 432 Old 06-03-2014, 08:58 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
So why is it only when the key FOB is in your pocket while spraying does the vehicle think you are touching the handle ? .... unless thats something else changed in 2014... Think about it, has to be more to it than simply water touching the inside of the handle, otherwise every time it rains the lights would flash and doors unlock
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #291 of 432 Old 06-03-2014, 09:10 AM
Aquaforest
I agree. The reason I asked if it was a 'benefit' was it designed to possibly be a touch alertness type reaction (not a human hand, but any object), but I never read anything about that.
Also yes if I'm in the city and a guy comes up to the car with a squeegee to clean the windshield I don't want the doors unlocking
Aquaforest is offline
post #292 of 432 Old 06-03-2014, 10:12 AM
GoPlzGo
GoPlzGo's Avatar
2015 WK
Its your proximity to the non running vehicle, it assumes you intend to drive it do it gives you lighting.
post #293 of 432 Old 06-03-2014, 11:36 AM
ColdCase
ColdCase's Avatar
2011 WK
True, but the point was that Heath said there was no RF involved, but there is.
I've either turned my approach lights off or don't have the feature. I just have the light flash for unlocking, whether the doors are locked or not.
"The smart key allows the driver to keep the key fob in their pocket when unlocking, locking and starting the vehicle. The key is identified via one of several antennas in the car's bodywork and a radio pulse generator in the key housing. Depending on the system, the vehicle is automatically unlocked when a button or sensor on the door handle or trunk release is pressed."
http://en.wikipedia.org/wiki/Keyless_Go#Keyless_Go
post #294 of 432 Old 07-06-2014, 10:39 AM
DUHockey9
Really dumb question. How the heck do you open the storage bin under the driver's seat? I can't find a latch or anything anywhere.
DUHockey9 is offline
post #295 of 432 Old 07-06-2014, 10:48 AM
ColdCase
ColdCase's Avatar
2011 WK
Its not a storage bin technically, there is no latch. If you have a fully optioned vehicle the area is full of modules.
Motor your seat all the way forward. Lift under the rear edge of the cover and it should "pop" right up. It is not a place you want to store anything you need to get at frequently or in a hurry, but some find it a useful hide away.
post #296 of 432 Old 07-14-2014, 08:45 AM
dcorn
My BMW with comfort access would do this as well. The car has proximity sensors telling it where the key is. If the key is close to the car (5-10 ft) and you grab the door handle, it'll unlock or lock, depending on what you're trying to do. It very well might do it with rain, but the key has to be close to the car. I always left the keys in the garage when I washed my car in the driveway to prevent this.
The BMW would only start with the key inside the car and would warn you if the key left the car when it was running. It knew when it was in the trunk because then the trunk doesn't latch to prevent you from locking the keys in there.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #297 of 432 Old 07-17-2014, 02:53 PM
ScottyNorq
2014 WK
I cant get the windows to roll down using the fob.
ScottyNorq is offline
post #298 of 432 Old 07-17-2014, 03:58 PM
2kg4u
2014 WK
That feature does not work on the 2014.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #299 of 432 Old 08-06-2014, 04:27 PM
Muzzy73
2013 WK
How to reset "Oil Change Due" message
Found this on another Jeep site and tried it on my ride that was giving message much before the due mileage.
"Turn the ignition switch to ON (do not start) and fully depress the accelerator pedal slowly 3 times within 10 seconds and then turn the ignition switch to OFF, then start the Jeep. The message should be cleared."
Muzzy73 is offline
post #300 of 432 Old 08-06-2014, 05:44 PM
GoPlzGo
GoPlzGo's Avatar
2015 WK
Sorry, easter egg denied! Its on page 99 of your User Guide
Jeep's Easter Jeep Safari Pic's kkuntz01 WK2 Grand Cherokee Forum 1 04-19-2011 04:14 PM
