Differential Fluid Change - JeepForum.com
post #1 of 10 Old 08-11-2015, 12:20 PM Thread Starter
mx71
2013 WK
I've been searching here and everywhere and the more I search, the less sure I am.
Are people changing the diff. fluid at 36,000, or is that more of a check interval over a change interval?
Also, I'm pretty sure I don't but how do I know if I have ELSD? MY codes are DR1P for the rear axle and DS8S for the differential. I don't see anything on my build sheet about a ELSD.
- 2013 Altitude/2014 Traverse
- 2005 CRF450x/2003 TTR125
- 1985 Elite 150/2013 C'dale Trigger 3
mx71 is offline
post #2 of 10 Old 08-11-2015, 12:36 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
ELSD only comes with quadra-drive, does your EVIC display Quadra-Drive when you push the start button? Does the rear diff have an electric motor hanging off it similar to the one hanging off the transfer case? You should see AWBP and DSFP on the build sheet for ELSD.
The 36,000 mile fluid change is for severe use. If you routinely take the Jeep off road through mud and water or tow heavy a lot, then change it, otherwise just check the level.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #3 of 10 Old 08-11-2015, 12:57 PM
Turbozcs2003
Change it you will be amazed at the amount of debris floating in the fluid. Gear oil is cheap and it is 10 minute job to change it, just buy a outboard fluid pump with threads onto a qt bottle.
Dont forget your t-case too. I wouldnt want to leave all the metal floating around in my diffs for 36K miles, no thanks!
Turbozcs2003 is offline
post #4 of 10 Old 08-11-2015, 01:35 PM Thread Starter
mx71
2013 WK
I have the QT2, so I guess no ELSD. Will any GL-5 75w-85 work? If so, those pictures are pushing me to just doing it for piece of mind.
mx71 is offline
post #5 of 10 Old 08-11-2015, 01:55 PM
Turbozcs2003
I used redline GL5 75w-90, technically the jeep comes with the 75w-85. The redline has the additive for the diffs in it.
Lots of pearl in those and that was the second change and my jeep only had about 1600 miles on it and the batch of gear oil only a 1000. Diffs shed a lot of metal breaking in. I will probably go another 5K or so and change it next spring and see what it looks like.
If your at 36K, I would change it with a good synthetic and your probably good to go for a while.
post #6 of 10 Old 08-19-2015, 10:44 AM Thread Starter
mx71
2013 WK
Anybody else? The dealer is stating it should be changed every 25-30,000, however my manual shows that as the taxi service interval.
They also are recommending a tranny flush at 30,000. That can't be right, can it?
mx71 is offline
post #7 of 10 Old 08-19-2015, 12:53 PM
hemispin
2014 WK
What does your owner's manual say about trans fluid change interval?
I had my front and rear diffs and the transfer case fluid changed at the dealership at about 30k miles.
hemispin is offline
post #8 of 10 Old 08-24-2015, 10:57 AM Thread Starter
mx71
2013 WK
I just went ahead and did it. I'm glad I did, the fluid that came out of the rear was pretty dark. I ended up getting the mopar fluid from ebay for what worked out to about $20/qt shipped.
mx71 is offline
post #9 of 10 Old 08-24-2015, 10:15 PM
ssgunner
You did it your self or had the dealer do it? I'm sure the charge an arm and a leg.
ssgunner is offline
post #10 of 10 Old 08-25-2015, 09:50 AM Thread Starter
mx71
2013 WK
I did it myself.
mx71 is offline
