Diff fluid change - JeepForum.com
post #1 of 12 Old 02-16-2014, 03:07 PM Thread Starter
Smurphymurphy89
Diff fluid change
Hey guys I'm looking to change my moms front and rear diff fluid does anyone know how much diff fluid goes into the front and the rear diffs.. I'm guessing there is a fill and a drain plug is that correct? Thanks for any response 2011 jeep grAnd Cherokee
Smurphymurphy89 is offline
post #2 of 12 Old 02-16-2014, 04:10 PM
ColoradoGrand
2015 WK
My 5.7 laredo X took 1.25 quarts in the rear and 1.1 quarts for the front they both have a fill and drain plug. Changing the fluids and refilling was very easy. I recommend that you purchase the gear lube from the dealer even though it will be more expensive.
ColoradoGrand is offline
post #3 of 12 Old 02-16-2014, 10:54 PM Thread Starter
Smurphymurphy89
Thanks.. The gear lube is the diff fluid that you use? because I was planning on getting that from the dealer anyway and what size socket is the fill plug? Drain plug? Appreciate the response.. I have a 05 BMW myself that I do all my own work on but I'm just learning on jeeps
post #4 of 12 Old 02-21-2014, 06:07 AM
spinxt
I believe I used three quarts for the front and rear combined. You just basically pump it in with a hand pump until it begins to seep back out.
Make sure you use the correct lube. It's not just straight up gear lube. Especially if you have one of the more advanced 4wd systems.
spinxt is offline
post #5 of 12 Old 02-21-2014, 12:45 PM
2k2wranglerx
before i drop $50+ a qt. is there an acceptable alternative?
mine are due. and on my wk1 i used all mopar fluid in it. there are alternate synthetics listed for the wk2 but i wanted to make sure they didn't need an additive or anything.
Thanks guys. search just came up with random threads. not sure why.
93 yj. 355 chevy, heads, cam, intake, etc. 35's, bumpers, winch, lights, and a killer stereo.
2k2wranglerx is offline
post #6 of 12 Old 02-22-2014, 05:44 AM
spinxt
What drive system do you have? I know there is no alternative for QD II. Browse Amazon, sometimes you can find it on sale.
This isn't something you want to cheap out on. These 4wd systems are very advanced. Even of you found a cheaper fluid that would theoretically work, it would probably be noisy in 4wd operation.
spinxt is offline
post #7 of 12 Old 02-22-2014, 08:15 AM
2k2wranglerx
The base awd system in a laredo
Lots of times there's perfectly acceptable mon mopar fluid. Like the manual transmission fluid in my tj.
It's not about cheaping out. I'm pretty sure there's no clutch packs or anything in the diffs for the base 4x4 system.
Assuming you HAVE to use mopar fluid is one thing. I didn't know if anyone had cross referenced the part numbers.
post #8 of 12 Old 02-22-2014, 11:00 AM
loveracing1988
If anything the wrong fluid would take the bearings out, if you had qd2 and used the wrong fluid it would result in more than noisy operation.
loveracing1988 is offline
post #9 of 12 Old 02-22-2014, 04:32 PM
2k2wranglerx
Chrysler uses different bearings than the rest of the world?
(Rhetorical question)
So nobody knows if there's a cross over gear oil?
post #10 of 12 Old 02-22-2014, 05:00 PM
loveracing1988
No, I mean if you use the wrong viscosity.
post #11 of 12 Old 02-22-2014, 05:42 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
A quick forum search for "diff fluid" indicates a variety of 75w-85 oils will work, Amsoil, RedLine, Mobil... The owners manual spells out the minimum requirements, and there are several that satisfy. I don't recall seeing a single page cross reference... I think because just about any modern 75w-85 diff oil will work. Pick your favorite brand. Those that have ELSDs should use the mopar fluid, however.
This page has some detail on capacities and schedules
http://www.wk2jeeps.com/wk2_maintenance.htm
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #12 of 12 Old 02-22-2014, 11:32 PM
llahtjp
while in the neighborhood, R&R the transfer case... ATF+4 for QT1
llahtjp is offline
