Diesels - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Diesels
CCOR is your 1 stop source for everything Jeep!Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 05-24-2014, 08:46 AM   #1
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Diesels
This thread is a place for WK2 diesel descriptions, technical discussion, issues, and references to technical topics and modification threads. The advantages and disadvantages of one powerplant over another should be discussed in the main forum section as well a any common WK2 chassis and suspension components.
Technical Descriptions:
2011+ VM Motori V6 Diesel Engines
DEF and SCR FAQ
Discussion Topic Links:
At Banks for Tuning
Whats Better About Diesels
3.0L V6
DEF Injector Vulnerability
DEF Fluid Level on Delivery
The 2014 Ecodiesels Experience
Owners Reports
Ordering an Ecodiesel
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 05-24-2014, 08:47 AM   #2
ColdCase
ColdCase's Avatar
2011 WK
Reserved
Unread 06-30-2014, 09:43 PM   #3
dieseldoozy
Diesel Fuel
Anyone have suggestions, or tips on getting diesel fuel? I have a few locations that sell diesel, including a Kroger gas stop and shell station, but I wanted to make sure I was fully informed before just going to one down the street.
Thanks!
dieseldoozy is offline   Reply With Quote Quick reply to this message
Unread 07-19-2014, 04:00 PM   #4
leonbmx
2014 WK
Hi, I don't know if this is the right location for this question, so feel free to (re)move from this thread if not.
First off, this is my first Jeep/ off road capable vehicle and I am excited to go explore more. In the process, I am looking for some better off road tires than the Lattitudes that are stock on the DGC, and I came across a post about using the 2013-up Rubicon 17" wheels on a GC.
Now I know that the '14 DGC has the Heavy Duty (HD) brakes, but over the last few days, I have read conflicting stories about people being able to use the rubicon setup with minor adaptations. Another option I see a lot is the use of spacers, but I am a little concerned that the "aero" mode of the Quadra Lift Air Suspension may make the wheels rub.
My question is, does any DGC owner out here have first hand experience with running these particular wheels?
leonbmx is offline   Reply With Quote Quick reply to this message
Unread 07-22-2014, 07:09 AM   #5
diverb
Junior Member
diverb's Avatar
2014 WK
Thanks!
As a longtime diesel vehicle owner, I recommend only buying diesel from truck stops or gas stations that have high volume diesel sales. Reason being the less time diesel sits in the underground tanks, the less likely hood of water and other containments to form in the fuel.
2014 Jeep Grand Cherokee 3.0 diesel -BANKS Tuner, BANKS Exhaust, BANKS Single shot water-meth injection
diverb is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 09:37 PM   #6
chadg2
2014 WK
Anyone putting in Power Service w/Cetane booster when filling up? Should boost MPG. Company says "it's safe for the new diesels" Used it in my 06' Ram 5.9L Cummins mixed with Mystery Oil. Blew lots of black smoke.
chadg2 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 10:04 AM   #7
NDSU_Bison
2014 WK
Most people recommend going to a busy station since they are more likely to have fresh diesel. Algae can grow in diesel fuel although I' m not sure how long it has to sit before that happens.
When I'm out of town, I go to places near the freeways that are likely to be used by RVs.
Thanks!
NDSU_Bison is offline   Reply With Quote Quick reply to this message
Unread 11-05-2014, 07:53 AM   #8
Jason911
2014 WK
Have been running it in mine for the last month - haven't seen any gains per say, but with the rapid temperature flux its hard to gauge.
Jason911 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2014, 01:39 PM   #9
Bullheadbud
2014 WK
I have had many diesel cars and trucks over the 50+ years I've driven. I have tried numerous diesel additives and have come to the conclusion, additives do not provide any measurable difference in mileage or performance. Does provide quieter running engine in some diesel engines. Some I've owned: Ford power stroke, v.w. (several), Peugeot, Mercedes, 2006 Jeep Libby.
Bullheadbud is offline   Reply With Quote Quick reply to this message
Unread 11-24-2014, 01:22 PM   #10
DirtEmax-USMC
Fuel: great point mentioned above to picking up at truck stops. I have had a few diesels and my wife currently drives the ecodiesel while I drive my duramax. Pay the extra couple cents per gallon and make a difference.
Additive: I find the best thing is Amsoil additive. I put injector cleaner and cetain boost every third fill up. The cetain boost will give you a cleaner and more through burn and the injector cleaner keeps those expensive injectors working at peak performance. I would use it more frequently if I did a lot of city driving (every other fill up).
DEF: no need to pick up your DEF fluid from MOPAR. Blue Def works great. Wal-Mart sells it and so do a lot of local/national truck stops. Fill up at a diesel pump too if your truck stop has one. It's WAAAYYY cheaper.
Oil Changes on the VM motor:
Change it before it gets to 20%. I do 30% then I change her oil. Remember LOW SULFER EURO oil is the ticket. Filters are costly but do that with it of course. We have almost 18,000 mi on our jeep so we have done this a couple times. If you go the dealer route do your homework. 3 jeep dealers around here and 1 has done a jeep oil change (diesel) and still messed it up.
Fuel Filter: extremely important.
90% of fuel filters go by mileage. I would recommend changing the FF on these every 20k/mi
This is a labor of love and not a cheap one but if you do it right your diesel will last a whole (200k plus)
Sent from AutoGuide.com Free App
DirtEmax-USMC is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 10:16 PM   #11
volvite
My brother ordered a 2015 Diesel from the TX group buy. He just picked up his jeep on Friday evening and then drove it from TX to WA. He drove 2219 miles at 80+ MPH and averaged 27.9miles/gal. I'd say that's good considering the speed and the elevation climbs he made from TX to CO, and MT.
Proud member of PETA= People for Eating Tasty Animals
RC X-seris 4 inch lift/32 Inch tires/My Build: http://www.jeepforum.com/forum/f197/...hread-1158910/
08 Nissan Pathfinder LE
volvite is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 11:16 PM   #12
10Xk
2010 XK Commander
Some more links to discussions.
http://www.jeepforum.com/forum/f309/...lemon-2880753/
http://www.jeepforum.com/forum/f309/...often-2786394/
http://www.jeepforum.com/forum/f309/...iable-2861801/
10Xk is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 03:55 PM   #13
Jason911
2014 WK
Thanks!
Try the App gas buddy if you have a smart phone. Its crowd sourced, works wonders for pricing and locations.
Unread 12-30-2014, 09:05 AM   #14
cfb5dog
2014 FSJ Cherokee
D.e.f.
I am a proud owner of a '14 diesel. The Jeep has a display above the steering wheel which has a screen which shows the level of D.E.F. I think mine is defective as it never shows anything besides full. Have other owners seen this screen work? How many miles does it take to drain the D.E.F.? Without knowing when to do it, I fill at home with Blue DEF every month or so (I rarely go through a full tank in one month).
I am in the NYC area and would second Gas Buddy. While it's never too hard to find diesel, I currently have stations within five miles selling from $2.80/ gallon to $3.75/ gallon; almost a $25 per tank difference.
Given the widening spread between diesel and unleaded prices, the diesel engine will likely never pay back. However the spread may change in the future and the extra torque is worth it.
CFB
cfb5dog is offline   Reply With Quote Quick reply to this message
Unread 12-30-2014, 10:18 PM   #15
Morax
One Life. Live it!
Morax's Avatar
2014 WK
Congrads on your new GC. As for the DEF, I used half in over 5000miles, so don't worry about the gauges...it depends on wheater, driving conditions...Just make sure you are using good quality DEF...DEF has an expiration date...last thing you need is out of spec DEF in your thank...you can research the web and get some great info on this subject.... good luck!
2014 Overland Tech - ECO
2011 Overland - HEMi - Sold!
Morax is offline   Reply With Quote Quick reply to this message
