Did you install your CB/Ham atenna this way? Pics please :) - JeepForum.com
post #1 of 21 Old 10-14-2013, 11:50 AM Thread Starter
eibyer
I'm trying to follow how SiltSurfer installed his CB antenna and wanted to check if anyone's done it the same way. Where did you route your cable, pics would be appreciated. Thanks!
Here are SiltSurfer's pic of the install... not much detail except for the mounting bracket. Heading off to the hardware store to get some angled brackets to try and replicate it.
http://www.jeepforum.com/forum/attac...3255510071.jpg
http://www.jeepforum.com/forum/attac...4058785681.jpg
http://www.jeepforum.com/forum/attac...2345235964.jpg
eibyer is offline
post #2 of 21 Old 10-17-2013, 02:21 PM
BlueSteelJP
2005 WK
Is this for a 2 meter? If so I would have gone with the magnetic mount tuned and cut to your mobile. Your setup isnt a bad idea until you go through a carwash and Im not sure about it being in the way of the hatch?
N1QWU.
Blue WK Club Member #10
2005 Jeep Grand Cherokee Limited, 5.7 Liter Hemi no Mods So Far.
BlueSteelJP is offline
post #3 of 21 Old 10-18-2013, 10:33 PM Thread Starter
eibyer
The mount is for a 4ft firestik and not a full time install. I will be removing the antenna for city driving. The only thing that will be left out is the mount and the stud, hopefully that is not an issue for drive through car wash. It will definitely clear the hatch.
eibyer is offline
post #4 of 21 Old 10-19-2013, 01:30 PM
alan93
2011 WK
I was looking for how to do this recently as I have an old brand new CB radio I never used but want to now.
I would have liked to see a close up of your door jam mount. i can't see past the lip in the first pic.
I am trying to decide on an antenna and mount. Got some ideas today, including drilling a 3/4" hole in roof but want to research that more. The higher the better and the guy a the radio shop said that centering it on the top would provide a wide "ground base" which improves reception.
Still looking though.
alan93 is offline
post #5 of 21 Old 10-21-2013, 08:26 AM Thread Starter
eibyer
That pic wasn't my install, it was SiltSurfer's. The area where the mounting plate is screwed into is not metal so for the install I will be needing a No Ground Plane (NGP) mount, antenna and coax cable. I was at the hardware store the other day and couldn't decide on the different angle brackets they had available, something that would require a little less grinding was preferable but no luck. I'll go again sometime this week and just pick the smallest bracket and grind away.
No drilling into the roof for me, the area by the hatch is perfectly fine and a 4 foot firestik would clear the roofline.
eibyer is offline
post #6 of 21 Old 10-21-2013, 11:49 PM
ChrisOC
CB radios antennas should be able to be mounted on the inside of cars these days.
Back on point though, why not get a magnetic one and when u need it, run the cord through one of the doors or a window. I would hate to cut into my roof.
ChrisOC is offline
post #7 of 21 Old 10-23-2013, 06:13 AM
KickRocks
2013 WK
I run my Wilson 1000 through the hatch with no issues.
KickRocks is offline
post #8 of 21 Old 11-08-2013, 07:57 AM Thread Starter
eibyer
I found some pics of an install on another forum.
http://www.jeep garage .org/f73/cb-radio-install-64048-2.html#post878008 (remove the spaces in the URL)
http://www.jeep garage .org/f73/cb-radio-install-64048-2.html#post877864 (antenna is a little short?)
The mount used is this (there are two versions, SS204 and SS204A):
http://www.amazon.com/gp/product/B00...A1BQRFMETCR3G1
eibyer is offline
post #9 of 21 Old 01-06-2014, 05:20 PM Thread Starter
eibyer
Playing with mount location, the best (imo) would be in the gray area of the tail light housing.
eibyer is offline
post #10 of 21 Old 01-09-2014, 09:30 AM
alan93
2011 WK
Looks good but would have liked to see the mount with the hatch up.
I ended up getting a K40 36" with magnet though it seems to be scratching the paint on the roof during add/remove. It got stuck in the garage door once when I tried to leave it on. It works good though. Getting great rx range, haven't tested tx fully yet.
alan93 is offline
post #11 of 21 Old 01-09-2014, 09:40 AM Thread Starter
eibyer
It's not mounted yet. I just stuck it there while trying to figure out the best location without looking cheap.
eibyer is offline
post #12 of 21 Old 01-09-2014, 10:03 AM
Jackal01
Jackal01's Avatar
2011 JK Wrangler
I would mount it as low as you can while still having at least a foot above the roof otherwise your reception will be even worse. I am sure there is a specific requirement for each antenna about how much clearance it needs but from my experience having at least a foot above the roof and clear all around is the best.
I like the area below the taillights that you chose.
2011 Billet JKUS
Jackal01 is offline
post #13 of 21 Old 01-09-2014, 10:52 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
1' above roof line
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #14 of 21 Old 01-09-2014, 01:34 PM Thread Starter
eibyer
The 4 foot Firestik would definitely clear the roof line. I'm cutting up some pieces of round dowels later to see how much room I have to play with. I'm putting in a quick disconnect so that will add 2" or so.
eibyer is offline
post #15 of 21 Old 01-12-2014, 07:53 AM
JMP8562
IMO the Lower Mounting looked the best When you get it mounted will you take the time to give a wright up on it and the version you ended up going with "SS204 or SS204A I have been wanting to put my CB in but the WK2 has been a pain to get a Clean looking location for the mount. But looking at the mount you have thanks for sharing
89 lifted wrangler to 95 lifted cherokee to 01 GC now 07 JK 4 DOOR X WITH HIGH ROCK FRONT WINCH BUMPER APPROACH ROLLERS/WARN 9.5TI WINCH WITH UNDER THE HOOD CUT-OFF SWITCH/2.5" SS lift/1"M.O.R.E BL/33" BFG KM2 ON STOCK 17"/RIVER RAIDER ROCKER GUARDS-SLIDERS/OFF ROAD HEROS FASTBACK SOFT TOP/GIBSON DUEL EXHAUST/CUSTOM MADE TRUNK/HELLA FF300/HELLA500 W-WINDSHIELD MOUNTS/DELTA SKYBAR/CARBON FIBER DASH KIT/DUEL AND SINGLE GUAGE PODS WITH VOLT-OIL PRESSURE-OIL TEMP GUAGES/COBRA 75 CB/AND A LOT OF RECOVERY GEAR
JMP8562 is offline
