Did Discount Tire Overcharge/Rape Me? - JeepForum.com
post #1 of 15 Old 07-07-2014, 06:42 PM Thread Starter
hazards280
2011 WK
Unhappy Did Discount Tire Overcharge/Rape Me?
I went in to get my tires rotated on my WK2 and was informed by one of the service techs that my lug nuts were all swelled and brought one of the nuts to show me. He said that auto manufactures are now taking the standard open ended lug nut and wrapping them with the steel casing to make it look good on the outside. Apparently as the years go by the salt and water getting in the small openings makes the lug nuts swell.
He said all of the lug nuts were hard to get off and had to be replaced. It almost looked like he used the wrong size socket but regardless they were all messed up to the point of no return.
They charged me $96 dollars for all new lug nuts and showed me the quality of the new ones compared to the old ones. The new ones had steel threads going all the way through the plug and not just the 1/4 inch that the OEM ones had. I could visibly tell they were better but almost $100 for lug nuts has me questioning the sale.
Any opinions?
2011 Jeep Grand Cherokee Overland Summit - Black, Stock. Daily Driver
2009 Pontiac G8 GT - Not even close to stock. Weekend Fun
2008 Kawasaki KFX450R - Stock
hazards280 is offline
post #2 of 15 Old 07-07-2014, 06:44 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Well if you didn't get a steak dinner & a goodnight kiss afterward, I'd say you were forcibly intercoursed.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 15 Old 07-07-2014, 06:47 PM
tjkj2002
2002 KJ Liberty
Any opinions?
Yeah sounds about right,try pricing out the OEM lugnuts there like $8-$12 each and you need 20 of them.
tjkj2002 is offline
post #4 of 15 Old 07-07-2014, 07:56 PM
Butterjeep
2015 WK
I've always had a great experience at Discount Tire. I'd say $100 for a fresh set of higher quality lugnuts is a fair deal.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #5 of 15 Old 07-07-2014, 07:59 PM
LibGrandCher
2012 WK
Any opinions?
Can I ask....do you have your tires rotated often?.
LibGrandCher is offline
post #6 of 15 Old 07-07-2014, 08:05 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
They used the wrong wrench size and buggered up your lug nuts.... then had you pay for the replacements. Lug nuts don't usually swell but are easily damaged by worn or improper sockets... or after numerous loosening/tightening cycles... or misshandling. Tire shops deal with lug nuts that lost their cosmetic cover all the time. They just put the wheel nuts back on without the covers. Jeep has been using cosmetic covers for 15-20 years now, nothing new. I used to have to replace a couple annually on our WJ. There are solid lug nuts available for about $5 a piece, capped for $2. So 20 solid nuts for ~$100 is about right.
Hope the replacement lug nuts have a long enough tread to fit the longer studs on the WK2. Many WK2 studs have been damaged by using common aftermarket lug nuts as they bottom out... or worse.. they seem tight but, because they bottomed out, they are not holding the wheel on. Discount tire should know what they are doing but I'm skeptical about the shop you visited because of the BS they fed you. Sounds like they had a sales quota to meet to get their bonus for the week... or was covering for a tech's screw up.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #7 of 15 Old 07-07-2014, 08:16 PM
slayer6x6
Yes, those type of lug nuts can swell over time. Some of the tool manufacturers started making sockets in half sizes for this issue 19.5 21.5 22.5 etc.
slayer6x6 is offline
post #8 of 15 Old 07-07-2014, 09:48 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
This kit should fit the Jeep the same way the replacement nuts that you purchased fit. The kit contains 20 pieces, enough to replace all of the lug nuts on your Jeep, and it sells for $25.
http://www.summitracing.com/parts/rp...-set/overview/
Max
Mean Max is offline
post #9 of 15 Old 07-08-2014, 11:54 AM
46er
2014 WK
The only time a nut will swell is if you get kicked. It appears you did Metal lug nuts do not swell; they can rust, corrode, get deformed by using the wrong size tools, but they don't swell.
46er is offline
post #10 of 15 Old 07-08-2014, 02:18 PM
tjkj2002
2002 KJ Liberty
The cheap chrome covers will swell after time.
tjkj2002 is offline
post #11 of 15 Old 07-08-2014, 07:36 PM
slayer6x6
post #12 of 15 Old 07-09-2014, 08:22 AM
FreeJersey
2014 WK
You can get a nice set of gorilla lugs for less than half that price.
FreeJersey is offline
post #13 of 15 Old 07-09-2014, 08:38 AM
Jonathanjr1
The lug nuts that the discount sell over here are gorilla. The metal caps on the factory lugs will spin if you use a impact on them. I know this from my aunts chrysler 300 that me and my uncle to change brakes every six mounths.
Jonathanjr1 is offline
post #14 of 15 Old 07-09-2014, 08:43 AM
FreeJersey
2014 WK
Seems like a healthy mark up.
post #15 of 15 Old 07-09-2014, 07:36 PM
slayer6x6
Well they can't keep the lights on breaking even. Did the OP get "raped"? No, I don't think so. They have to make something on the parts and pay somebody the labor to put them on. I know it's not a lot of labor but nobody should work for free, and somebody has to buy the tools to be able to perform the work. Could the OP saved money if he ordered his own parts online and installed them himself? Of course, and you'd be silly to think you could pay somebody to do it any cheaper.
Did I just answer my own questions?
Yes I did.
