Determining Build date.... - JeepForum.com
post #1 of 6 Old 10-06-2013, 12:53 PM Thread Starter
falcon2014
The plate on the door jamb gives the month/year, is there a more precise way?
TIA!
falcon2014 is offline
post #2 of 6 Old 10-06-2013, 02:01 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
You used to be able to sign in as an owner at jeeps.com, register your VIN and request a build sheet.
Otherwise a dealer can run the Vin and get the day and hour it rolled off the line.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 6 Old 10-07-2013, 04:45 AM
tjkj2002
2002 KJ Liberty
TIA!
If they still do it there is another # on that same sticker that gives the month,day,and hour it rolled off the line.
tjkj2002 is offline
post #4 of 6 Old 10-07-2013, 08:46 AM
plynn7
2014 WK
For the build date/time you need two entries both on the door jamb sticker. At the top left is the month and year. On the bottom right is an entry marked MDH. That is Month/Day/Hour.
2014 JGC Overland V6
Tech Package
Deep Cherry Red
plynn7 is offline
post #5 of 6 Old 10-07-2013, 11:07 AM
ColdCase
ColdCase's Avatar
2011 WK
How precise do you want the actual build date/hour? Depending on how you define the build date, the door jam MDH stamp may be a couple days off real time, if it matters (mine was off near 2 days from the production barcode scans). It is what Jeep uses for TSB and recalls, however.
ColdCase is offline
post #6 of 6 Old 10-08-2013, 09:04 AM Thread Starter
falcon2014
That worked perfectly, it was exactly what I needed.
Thanks to everyone!
