DEF Injector Vulnerablility - JeepForum.com
post #1 of 70 Old 05-11-2014, 03:15 PM Thread Starter
fun2drive
Fellow JGC diesel drivers. I am on this forum and the other forum as well. The DEF injector has caused issues by being broken off simply by going on mild trails or even unpaved roads. This is a real vulnerability for our rides and will stop you pretty fast if that injector breaks off. Once all the DEF leaks out you get a warning which can eventually shut your ride down.
I hope Jeep addresses this in the 2015 model but since I don't think they will and retrofit the solution back to the 2014 models some of us have been working on ideas for a protection panel.
The other forum has developed a prototype protection panel which should keep the DEF injector and wiring harness from being compromised.
I will not mention the name of the other forum to abide by protocol rules but if you google DEF Injector Vulnerability you should find that thread.
Does anyone on our forum know of a member of members working on a DEF injector and wiring harness protection panel?
I don't know how Jeep can give the diesel an off road rating given where this injector and wiring harness lives. Any small branch or road pitched up can snap this plastic injector off.
Hope this helps diesel drivers not aware of this problem. Be sure to check your ride over and decide if you can go off road where you wish after seeing the injector location...
fun2drive is offline
post #2 of 70 Old 05-11-2014, 03:27 PM
jaje
2007 WK
Mine was damaged and I never even went off road - just happened when driving through some puddles (that's how I think mine broke).
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #3 of 70 Old 05-12-2014, 08:31 AM Thread Starter
fun2drive
I am concerned that road debris could easily break this off. The other forum has a group buy started for a cover to protect the wiring and the injector. I am signed up to buy one. I can't wait on Jeep to correct things...
post #4 of 70 Old 05-13-2014, 01:48 PM
10Xk
2014 WK
Well you know that they are not trail rated! If you can't drive down a road with breaking it what good is it?
Good luck with that! People still have 4wd low problems ever since the N23 recall.
How much does that repair run since it shouldn't be covered under warranty?
10Xk is offline
post #5 of 70 Old 05-13-2014, 02:33 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yeah that N23 recall fix (inadvertent neutral, affects only vehicles with the transfer case used through 2010) may have uncovered a previously undetected electrical issue in some vehicles, which has complicated maters. In other words, there seems to be an electrical gremlin that, because of the way the controller software was written, didn't matter. It seems to matter after the software was updated, however (folks lose 4wd low). I hate when that happens... dunno when things will be completely cleared up on that one
Seems like Jeep corrects some issues quickly, but others (i.e. fishbite which is more relevant to the WK2 community) are more complex.... in that one thing is fixed but two others break...
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #6 of 70 Old 05-13-2014, 07:09 PM
onebluemcm
2015 WK
Thanks for the heads up fun2drive - looks like a good idea going on there. Just hoping it's more toward the $100 than the $200 range - 2 bills to deal with a design/engineering f-up, ouch.
'15 Overland Diamond Black, 3.0L Turbodiesel, Quadra-drive II
onebluemcm is offline
post #7 of 70 Old 05-13-2014, 07:37 PM
10Xk
2014 WK
$285 at mopar.com good luck finding it aftermarket
10Xk is offline
post #8 of 70 Old 05-13-2014, 07:46 PM
onebluemcm
2015 WK
Someone is fabing a custom unit up. What's the P/N for the $285 piece?
post #9 of 70 Old 05-13-2014, 07:48 PM
10Xk
2014 WK
If this is the correct part-
Diesel Exhaust Fluid System - INJECTOR KIT, Dosage Module
Part # 68232842AA
10Xk is offline
post #10 of 70 Old 05-14-2014, 09:01 AM
DRKRED12
If I am reading this right they were looking for the factory cover part # and not the injector part # as I do not think a factory cover exists as of yet.
DRKRED12 is offline
post #11 of 70 Old 05-14-2014, 10:19 AM Thread Starter
fun2drive
There is a factory part number but not that covers the vulnerable DEF injector which sticks down like a sore thumb. This was clearly an after thought by Jeep. I am curious if the RAM 1500 will have a fix for this. I could give a flip for "Off Road Rating" but if I can't even drive down a gravel lane then shame on Jeep.
The protective cover has been fabbed and a couple versions are being looked at for more than just protection but also when regeneration occurs to be sure that nothing over heats.
The member at the other forum is a member of SEMA and does this type of thing as part of his livelihood and his fabricators do this often so this is not some back yard bolt on but something with a lot of thought put in it.
For 50 plus large I for one want to protect my Jeep weak points. My plan is to do AlCan next year but my Outback is better prepared than my JGC diesel until this is corrected. There have been numerous cases of the plastic injectors snapping off and draining the tank throwing a code that tells you the engine will shut down in XXX miles...
post #12 of 70 Old 05-14-2014, 02:03 PM
Will-X
2014 WK
Part # 68232842AA
Every one I have seen with an issue, the dealer just replaced under Warranty. Haven't seen any push back.
Will-X is offline
post #13 of 70 Old 05-14-2014, 05:18 PM Thread Starter
fun2drive
Update
The panel is aluminum for faster heat dissipation and to keep the weight down. The DEF area was tested today in California with panel on and off. There was no difference in temperature readings. The prototype is getting closer to being ready for production once the testing is complete...
post #14 of 70 Old 06-10-2014, 06:42 PM
Enjoyrv
2014 WK
Can anyone tell me where specifically is it locales under the vehicle. A picture would be wonderful.
Rich
2014 GC Summit Ecodiesel
Enjoyrv is offline
post #15 of 70 Old 06-11-2014, 04:26 PM
Dave2002ti
2012 WK
Report it to NHTSA
And maybe it will become an issue that Jeep and Fiat will have to deal with with a recall and force Jeep to design a protection panel. It sounds more complicated than that though like the mounting is weak also.
Dave2002ti is offline
