Dealers at work.... - JeepForum.com
post #1 of 18 Old 06-13-2013, 03:45 PM Thread Starter
boyvan
2012 WK
Dealers at work....
This is not Jeep related but thought to share anyways. Yesterday took my wife's Acura to an Acura dealer for a recall. Since her car has approx 180K now so I asked them to do a safety inspection as well. The guy called me from the dealership and listed few items that needed doing. One of those things was replacing battery. The guy said that battery failed the test. I told him No to everything.
I brought the car home and the battery failed test was still bugging me so I decided to call BCAA (AAA/CAA). The BCAA guy came and did three separate tests and all tests were fine. He said that its upto me if I still want him to change the battery but he doesn't see any issues with the battery. He said that I can get another 2 years at least out of it. So I called the dealer and he started talking in battery jargon and said that their tests showed it failed.
BCAA guy explained that if his readings (volt?) were below 9 then it is a problem. But all three test showed a lowest reading of 10.8 which tells him its fine. Can anyone explain what he meant by these numbers?
I thought to share because people often complain that Chrysler dealers are not honest but I guess its most dealers in general. I wonder if there is such thing as honest dealer out there.
_______________________________
2012 JGC Overland - Max Steel
boyvan is offline
post #2 of 18 Old 06-13-2013, 04:50 PM
eibyer
I just make them write the recommendation down and then I get a second opinion. If it is really needed then I would schedule it sometime later, unless they will tell me that the car might explode on the way home then I might say let me think about it for a minute.
eibyer is offline
post #3 of 18 Old 06-13-2013, 05:07 PM
NCJeepGC
2012 WK
Replace the battery. Wouldn't want my wife stranded somewhere because I second guessed replacing it. Batteries are relatively inexpensive. Even at 10 volts, that sounds a little low. Acura's engineers may have designed their systems to run at certain voltages. Not trying to bust your balls, just my honest opinion.
Sent from my Badass Nexus 7 using JeepForum
2012 Jeep WK2 Laredo 4X4
NCJeepGC is offline
post #4 of 18 Old 06-13-2013, 05:16 PM
jacko15
2014 WK
I've read basically the same thing elsewhere, but good explanation:
http://www.wikihow.com/Check-a-Car-Battery
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline
post #5 of 18 Old 06-13-2013, 05:16 PM Thread Starter
boyvan
2012 WK
They wrote the recommendations down and I will get a second opinion on the rest of the "issues". None of these issues were life threatening or would leave my wife stranded.
@NCJeepGC - I thought of it too. But I guess I was ticked off at the dealer especially after speaking to the BCAA guy. I probably will get it replaced in few months.
@Jacko - Thanks. I will read it when I have some more time.
boyvan is offline
post #6 of 18 Old 06-14-2013, 09:08 AM
henrysko
2011 WK
Could be the proverbial tip of the iceberg with that many miles.
Perhaps a newer car?
'11 G.C. Overland V6 Mineral Grey/Black Int. (Mine)
"12 G.C. Overland V8 Stone White w/Saddle Int. (Wifey)
henrysko is offline
post #7 of 18 Old 06-14-2013, 09:49 AM
nyrhockey23
if you don't trust dealers (no one can blame you for this) then why would you ask them to do a check up on the car anyways?
nyrhockey23 is offline
post #8 of 18 Old 06-14-2013, 10:32 AM
Carange334
1987 ford pick up truck. Still alive and kicking. Sold it to a friend who uses it for farm work. Odometer rolled over at 200K miles and then we put another 50K on it. Never replaced the battery. Was completely amazed by that truck. Just wouldn't DIE! lol. Could have been just a miracle the battery lasted that long but to each their own. For a daily driver I wouldnt risk it, but then again it did past/fail the test...
Carange334 is offline
post #9 of 18 Old 06-14-2013, 12:10 PM
Dabitz
2015 WK
I'm surprise that's the only thing they tried to sell you. If it was a Jeep dealership they would've said your engine is about to explode and needed a rebuilt worth $5K.
Dabitz is offline
post #10 of 18 Old 06-14-2013, 02:26 PM Thread Starter
boyvan
2012 WK
I was surprised too that nothing major had come up. There were other minor things but this was the biggest thing. We bought it brand new and I have been taking care of it regularly. I went to Acura simply because of a recall. They had a special on safety inspections so thought to get it done. And as soon as I told them to do a safety inspection the techs eyes lit up...lol. But later he agreed that car is in a good condition. I will still get the battery changed after all....just in case.
boyvan is offline
post #11 of 18 Old 06-15-2013, 09:17 PM
WhiteOut
WhiteOut's Avatar
Just to expand on this. Why are you taking the word of a roadside assistance person over a J-man? You do understand the BCAA people are not mechanics (or anything close to it) right?
WhiteOut is offline
post #12 of 18 Old 06-15-2013, 10:07 PM
Chris9674T
2011 WK
LOL Sounds like you have been to the dealer I bought my Jeep from!!
Chris9674T is offline
post #13 of 18 Old 06-16-2013, 07:29 PM
fumblefingers
2014 WK
not so funny. My jeep GC swallowed a valve at 175,000 and since it was an 01 the $5 K engine was more that my otherwise nice ride was worth. Now I am back buying a new GC that has so many bells and whistles I will spend more time reading the manual than driving.
fumblefingers is offline
post #14 of 18 Old 06-17-2013, 05:46 PM
zlieberman
battery readings
No one has answered the OP's question.
The readings that they are giving you is a load test from the sound of it, the batteries normal volts should be 12.6V when you place a load on the battery, like starting the car the Volt reading should not go below 9V. If it does the battery is no good. If the battery is sitting at 12.6V and you apply a load and the V drops to 10.8V this would indicate that the battery is doing just fine.
zlieberman is offline
post #15 of 18 Old 06-17-2013, 07:04 PM Thread Starter
boyvan
2012 WK
Thanks zlieberman. I appreciate your response. I guess having too many smart people answering one simple question makes it complicated....lol.
boyvan is offline
