Daytime running lights keep burning out - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Daytime running lights keep burning out
Rear Disc Brake Conversion Kit- TJ,YJ,XJSWAG 50 Cal Ammo Can Mount With M2A1 Can~Artec JK 1 TON SWAP~
Unread 06-02-2014, 08:42 AM   #1
tednbauer
My 2011 GC overland Hemi keeps burning through daytime running lights. I've had to bring it in 5 times now. Currently I just burned out my 3rd left one and have replaced 2 on the right. The entire thing burns out not just the bulb they tell me. Warranty has covered it each time but now I have 40k miles. Anyone else getting this. Is there a fix.
tednbauer is offline   Reply With Quote
Unread 06-02-2014, 09:14 AM   #2
bocajrs
2012 WK
No problems with the DRL's on my 12 GC Limited.
bocajrs is offline   Reply With Quote
Unread 06-02-2014, 02:58 PM   #3
drsvelte
We've had at least two (maybe three) burnouts on our 2011 Overland.
drsvelte is offline   Reply With Quote
Unread 06-03-2014, 09:24 AM   #4
nubby105
2011 WK
At least the bulbs are cheap.
nubby105 is offline   Reply With Quote
Unread 06-03-2014, 03:11 PM   #5
2kg4u
2014 WK
Any time I experienced bulbs burning out at a higher than normal frequency it was the result of corroded sockets. Sometimes corrected by scraping them clean with whatever will fit in there, other times just replaced the sockets. Sockets that had to be replaced looked everheated, likely caused by the poor contact causing arcing.
Clean the contacts on the socket where the bulb is inserted, and put some dielectric grease in the socket to keep moisture out.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote
