Day time runing lights - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Day time runing lights
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-09-2013, 09:57 AM   #16
Jeep_addicted
2011 WK
Some of the GM Trucks used to have this problem
They the developed a new bulb that was more stout
It is the 4114 bulb it essentially a 14v bulb so it lasts longer.
There is also a variant called the 4157 which has an operating voltage between 12.8 and 14v
Give these a shot.
Or the other option maybe LED bulbs
Jeep_addicted is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 05:55 PM   #17
txwest
2012 WK
Give these a shot.
I will look into these. Thank you!
Sent from my S-III using JeepForum
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 08:16 PM   #18
5-90
1988 XJ Cherokee
DRL - if it's such a good idea, why hasn't it helped, and why are they still screwing it up?
I take exception to systems that are little more than justifications for drivers to abdicate responsibility - moreso once they become codified into law...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2013, 09:45 AM   #19
txwest
2012 WK
Finally got by the auto store. The bulb is just fine, the plastic melted over the metal contact. Could have just trimmed it without buying a new one, but I want to see if these 4114 are more resilient. I'll keep y'all posted.
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
Unread 07-01-2013, 05:58 PM   #20
Ungerer
Give us heads up how it gos for you
Ungerer is offline   Reply With Quote Quick reply to this message
