Day/Night Display for Garmin GPS on 430N Help - JeepForum.com
post #1 of 13 Old 02-12-2011, 05:05 AM Thread Starter
Flynn77
2011 WK
I went to the built in help screen on the Garmin and found the section on changing the display. The directions told me to go to setting and then display and from there I could switch between day, night, and auto display. However, when I go to settings there is no option for display. Is there another way to access the day and night display settings for the Garmin GPS on 430N or do I need to go back to the dealer for an update? This is a custom built Jeep and I just took delivery on Wednesday.
Flynn77 is offline
post #2 of 13 Old 03-22-2011, 07:15 PM
JeepOrvis97
JeepOrvis97's Avatar
Hit the menu button, its in there.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #3 of 13 Old 03-22-2011, 07:46 PM
2011Hemi
2011 WK
Don't use the "settings" on the nav screen, push the "Menu" hard button then touch the screen button "display settings" on the upper right corner. From there you can select Day, Night, or Auto and the brightness level for each mode.
Also, make sure your dash dimmer switch is not in the override bright dimmer position.
2011Hemi is offline
post #4 of 13 Old 03-22-2011, 08:35 PM
LuckRider
LuckRider's Avatar
^That. I actually found that out today when just playing with the buttons. Displays happen to show on the right side of the screen when you hit the Menu hard button.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #5 of 13 Old 03-22-2011, 08:54 PM
Brady12
I like having the dash/gauges on the brightest settings at night. However then the auto function on the nav/radio screen does not change. I assume it is okay to keep the dash lights at the highest setting all the time?
Brady12 is offline
post #6 of 13 Old 03-23-2011, 04:48 PM Thread Starter
Flynn77
2011 WK
Cool. Thanks for the help.
Flynn77 is offline
post #7 of 13 Old 03-28-2011, 07:58 PM
bikerbill7
So, what is the purpose of the Auto Color Mode? This option doesn't change my display from day to night mode. It stays on day brightness all the time??
bikerbill7 is offline
post #8 of 13 Old 03-28-2011, 08:14 PM
JeepOrvis97
you need to turn the dimmer switch down, there is 2 detents at the top of the dimmer, one is for dome lights and the other is for keeping the radio, mileage, cluster lights bright at night, push it down below these two detents.
also stated here:
Current jeeps:
1997 ZJ Orvis
post #9 of 13 Old 03-28-2011, 08:17 PM
2011Hemi
2011 WK
Your dash light dimmer switch is probably in the overide position. Turn it down one notch, the detent position is max brightness override so you can have full brightness during daytime when the headlights are on.
2011Hemi is offline
post #10 of 13 Old 03-28-2011, 08:21 PM
JeepOrvis97
Its amazing that my 1997 ZJ automatically dims those lights when I have my lights on at night or leaves them bright when my lights are on during the day. I have no idea why they made this a manual setting in the WJ and now also the WK2.
Current jeeps:
1997 ZJ Orvis
post #11 of 13 Old 03-28-2011, 08:29 PM
2011Hemi
2011 WK
My Silverado works that way too. The cluster and radio/Nav lights work off of the photosensor instead of the headlight operation.
One thing I don't like on the WK2 is when all you have on is the radio (at night w/ engine off) and the screen is the only thing that lights up and at full brightness. On my truck the screen and buttons light up and at the night setting.
2011Hemi is offline
post #12 of 13 Old 03-29-2011, 03:14 PM
mjw930
When the setting is on the second detent it operates as you describe, the radio stays bright. Move the dimmer switch past the second detent and the radio will dim with the dash lighting.
mjw930 is offline
post #13 of 13 Old 03-29-2011, 05:06 PM
2011Hemi
2011 WK
Only if the Jeep is running. If your sitting in the Jeep with the engine off at night (waiting to pick someone up) and have the ignition in "acc" position the radio screen is all that lights up and it does so at full brightness no matter what position the dimmer is in. Now you could go in and change the setting on the radio from "auto" to "night" but who wants to keep doing that all the time since you will have to change it back for daytime driving.
2011Hemi is offline
iPods and the 430N vs. the 730N mjw930 WK2 Grand Cherokee Forum 59 05-30-2011 01:57 PM
Sirrus Travel link w/430N nav? Brady12 WK2 Grand Cherokee Forum 7 02-20-2011 12:14 AM
730N Nav display question bob13654 WK2 Grand Cherokee Forum 9 10-05-2010 07:39 AM
Garmin Nav System jsmith195 WK2 Grand Cherokee Forum 2 09-24-2010 01:12 PM
Factory Navigation with Garmin jonesark WK2 Grand Cherokee Forum 9 09-04-2010 06:21 PM
