Coolant leak - JeepForum.com
post #1 of 6 Old 09-28-2012, 09:45 AM Thread Starter
TheSiltSurfer
2012 WK
Just dropped my baby off at the dealership, noticed it leaking coolant this morning popped open the hood & it was dry in the reservoir. it appeared to be leaking from water pump? Possibly the thermostat housing ?fluid was everywhere . Anyhow Godbless warranties well have to wait till next week keep y'all posted
Infinite Patience Produces Immediate Results
TheSiltSurfer is offline
post #2 of 6 Old 09-28-2012, 12:18 PM Thread Starter
TheSiltSurfer
2012 WK
Dealer called me & said the water pump "had ***** the bed" ��so it failed in other words. Ordering me a new one should have her back Monday +) all praises to warranty. Then again I'm only at 10 thousand miles and it already went threw one water pump **** son!
post #3 of 6 Old 09-28-2012, 03:28 PM
MaineJeep11
2011 WK
Glad they caught it and fixed it now instead of when you're out in the mountains or in the dunes at least. Not fun to have such an important component fail at 10k though. Like you said, good thing for the warranty!
2011 Laredo V6, OR1, RR 2.5" lift, ProComp 7036 wheels, 265/70/17 Toyo Open Country AT's - SOLD
MaineJeep11 is offline
post #4 of 6 Old 09-29-2012, 01:23 PM
padgett
2012 WK
That is an early failure but past the bathtub curve. Need to check for a belt misalignment, that can torque the water pump shaft and make the seal fail prematurely. If so should see wear on one edge of the sepentine belt. Other possibilities but is the most likely.
One of these is a turbo diesel.
We take in orphans. Notary Sojac y'all.
padgett is offline
post #5 of 6 Old 09-29-2012, 01:40 PM Thread Starter
TheSiltSurfer
2012 WK
Good points! I'll let them know Monday to check the belts ect, it's under warranty so doesn't bother me if I have to leave it a week and let them fix everything correctly besides I have a WJ and I can drive on the side so I'm good. Thanks !
post #6 of 6 Old 04-06-2013, 11:10 PM
hobbie1
2015 WK
Interesting - mine is failing at 29,000 miles. Called the dealer and the water pumps are on hold - none available. They have to call Chrysler on Monday. Also found out that my left front CV axle boot has failed, grease is everywhere. This is my sixth Jeep and seems to be the worse. Transfer case, water pump and CV boot. Not good for a unit that is garaged and attended to.
15 Summit 4X4 Eco Diesel
14 RAM 2500 Cummins 4X4 Laramie CC
13 Mustang GT
66 Mustang Cp - 306 5sp
hobbie1 is offline
