Chrysler Pentastar V-6s to get turbos and direct injection, sources say - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Chrysler Pentastar V-6s to get turbos and direct injection, sources say
Metalcloak: Celebrate Freedom with Free ShippingThe Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 04-21-2015, 11:18 AM   #1
matthewh
http://www.autonews.com/article/2014...ection-sources
http://lmgtfy.com/?q=Chrysler+Pentas...2C+sources+say
So will a turbo 3.6 be an option for the 2016 GC?
matthewh is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 11:43 AM   #2
Bent8
2011 WK
Looks like they are going the way of Ford and the eco-boost line.
Lots of horses from smaller displacement means the power comes screaming at higher RPMs. I prefer my Hemi where lower RPMs gives similar, yet less noisy power.
Bent8 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 11:50 AM   #3
lurtonk
Drive it like u stole it
2015 WK
Those articles are from 2014!!!
lurtonk is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 02:27 PM   #4
2kg4u
2014 WK
They are developing a turbo 4 cylinder, and twin turbo 6 cylinder.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 02:39 PM   #5
divisionbell77
Torque hits far lower, 'power' comes from far lower RPM.
divisionbell77 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 02:53 PM   #6
wyat72
2011 WK
I don't think the grand cherokee will get the ttv6 next year.
I think the di 3.6 has been basically confirmed for next yeae though.
2011 Grand Cherokee Laredo X, Pentastar, Qudra Trac I.
wyat72 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 02:56 PM   #7
matthewh
What does direct injection get you?
Unread 04-21-2015, 02:59 PM   #8
wyat72
2011 WK
Usually about 5% gains in hp and mpg.
Unread 04-21-2015, 06:28 PM   #9
Bullheadbud
2014 WK
Pentastar V6 turbo would be great and I'd be one to seriously think about replacing my 14 G.C. when/if it comes to be true. My guess is they probably will in order to offer something to compete with Ford's eco boost v6.
Bullheadbud is offline   Reply With Quote Quick reply to this message
Unread 04-21-2015, 08:05 PM   #10
GreatDaneLvr
2011 WK
In FCAs 5 year plan, the next-gen JGC(2017 on sale late 2016) will be the first to receive the new 3.0tt Pentastar. Many details remain scarce, but I find it ironic that this is also when the new Maserati 3.0T goes into production as well.
Most sources indicate to expect well over 400hp. What is not readily available is whether or not the Hemi will be replaced(could go the Ford route and keep it around to please must have V8 buyers). I do know the 3.6 is due to receive new internals as well as DI for improved power and efficiency. Probably look for updates to the E.D. with more power and efficiency gains. Another biggie: What will become of the SRT? It is still the number one selling SRT product. But FCA has indicated Dodge to have SRT all to itself. ZF is close to releasing the faster, more efficient 8HP. The good news is that the next gen JGC is supposed to be far lighter and stronger, with high-tensile steel and use of aluminum for weight reductions.
2011 JGC Overland Summit Rugged Brown/Saddle OFII 5.7 HEMI
GreatDaneLvr is offline   Reply With Quote Quick reply to this message
Unread 04-22-2015, 07:18 AM   #11
lurtonk
2015 WK
They could change the JGC SRT name to the new TrackHawk name and offer it with the 6.4 and/or the 6.2 Hellcat engine.
Unread 04-22-2015, 08:32 AM   #12
GreatDaneLvr
2011 WK
True. Jeep did trademark that name specifically for JGC. Can you imagine a Hellcat V8, and a stout enough AWD system to handle the 650lb-ft of torque? Cayenne Turbo S...who?
If Jeep is able(and Im sure they are) to develop an AWD system that can handle that power, the JGC could end up being faster in the 1320 than the LXs, albeit much lower top speed.
Unread 04-22-2015, 08:42 AM   #13
lurtonk
2015 WK
I think the articles have indicated that a Hellcat JGC would be 2WD only. They all ready have the drive train for that.
Unread 04-22-2015, 08:59 AM   #14
Kev M
2012 WK
Unfortunately in a lot of cases it also gets you carbon deposits on the intake valves.
Right now I'm thinking I'd like to avoid any new Direct Injection motors for a while (unless they have a specific strategy to avoid/deal with deposits or a proven track record that they don't suffer them).
Kev M is offline   Reply With Quote Quick reply to this message
Unread 04-22-2015, 09:11 AM   #15
GreatDaneLvr
2011 WK
D.I. is hit and miss. Ford's 4cyl Ecoboosts are plagued with carbon build up, although they won't admit. We've had 4 Fusion 1.6L Ecoboosts company cars at the dealer for carbon-related issues.
GM has had some success with their later model 3.6L V6s and 2.0Ts. I believe 2011 and later engines are better at fuel burning than first gens.
Hopefully FCA will employ the latest technology in direct injection. I believe that is why they are so "late" to the game. However, the 3.6 employed now is very competitive in power and efficiency.
