Check engine on 2011 Jeep Grand Cherokee Laredo - JeepForum.com
post #1 of 5 Old 01-16-2011, 05:28 PM Thread Starter
Davidson881
It's been cold, but I had the block heater plugged in and when I started it up, the check engine light came on.
Is there any way to get the code without a scanner on the new Jeep Grand Cherokees?
Thanks.
Davidson881 is offline
post #2 of 5 Old 01-16-2011, 05:32 PM
volvite
Brand new. Take it to the dealer.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #3 of 5 Old 01-16-2011, 05:45 PM Thread Starter
Davidson881
That would be my instinct, however I'm about 3000km away from the dealer right now, in the Yukon...
post #4 of 5 Old 01-16-2011, 06:55 PM
ecupip
I thought someone had mentioned you could still get the codes like the WKI, not sure of that process though. It is just an emissions function that has malfunctioned anyways, you will be fine to drive the car until you can make it to the dealer.
ecupip is offline
post #5 of 5 Old 01-16-2011, 07:23 PM
Texas WJ
Texas WJ's Avatar
2005 WK
You could try this:
Retrieving codes (2005-2010 Grand Cherokee): Insert and turn the ignition key from "Off" to "On" three times, moderately fast and without pausing ("ON" is when the digital odometer displays):
Tip: use the "count to 5" method, where "1" is the first "On":
Off > On > Off > On > Off > On
0 1 2 3 4 5
0 - Insert key (Off)
1 - On
2 - Off
3 - On
4 - Off
5 - On
At the third "On" the odometer display will read "DTC REPORT" and list the codes. If no codes are present the message "Done" will appear.
It can take several times to get it right. Also, make sure to do this with the door closed.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
new rims on my 2011 grand cherokee! check it out rolexjake WK2 Grand Cherokee Forum 46 02-11-2013 07:08 AM
2011 Jeep Grand Cherokee MYGIG Upgade jsmith5915 WK2 Grand Cherokee Forum 5 10-26-2011 09:06 PM
2011 Grand Cherokee or 2011 Lincoln MKX Theodore42 WK2 Grand Cherokee Forum 70 01-21-2011 01:28 PM
Have a burning question about the 2011 Jeep Grand Cherokee? bradbb2005 WK2 Grand Cherokee Forum 9 10-19-2010 09:50 AM
2011 Grand Cherokee sost1sg WK2 Grand Cherokee Forum 218 10-08-2010 11:56 AM
