changing reverse light to led - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > changing reverse light to led
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 05-14-2015, 09:10 AM   #1
jkclbk
do you need 2 bulbs for each side?
The backlight is of two parts.
One part on body and theres another part on the trunk?
Is it on bulb or two? 1 on the body and 1 on the trunk?
or is there no bulb in the trunk?
jkclbk is offline   Reply With Quote Quick reply to this message
Unread 05-14-2015, 10:55 PM   #2
n666z
4 bulbs all together.
2 for the outer taillight housing,
2 for the inner tail light housing.
They are not the same bulb number either. Putco makes a great drop in LED for us.
not sure what year you have but this info is for 2014+:
For the reverse LED's you need 2 of each of these:
(2x) 7440 (white without canbus)
7440 Putco Plasma LED Replacement Bulbs
(2x) 921 (white without canbus)
921 Putco Plasma LED Replacement Bulbs
n666z is offline   Reply With Quote Quick reply to this message
Unread 05-14-2015, 10:59 PM   #3
n666z
Here is how they look on mine.
Unread 05-15-2015, 06:14 AM   #4
jkclbk
they are different 7440 bulbs?
The same 4 bulbs wont fit?
Unread 05-15-2015, 09:52 AM   #5
n666z
You need 2 921's and 2 7440's. (At least on the 2014+ not sure about 11-13)
Unread 05-15-2015, 10:22 AM   #6
jkclbk
thats what i thought also. Is it hard to get around the liftgate part? I opened the part on the body but not sure if the liftgate part would be easy also
Unread 05-15-2015, 10:54 AM   #7
n666z
Yea you just have to pop off the plastic cover on the inside of the tailgate and disconnect the lights for the cargo area .
Unread 05-15-2015, 10:59 AM   #8
jkclbk
so the process is the same
Unread 05-15-2015, 11:19 AM   #9
n666z
Yea it's very straight forward once the plastic covering is removed from the tailgate. It is held in by Pop off clips they require a nice solid tug to Pop loose.
