Center Console 115v removal - JeepForum.com
 1Likes
  • 1 Post By ColdCase
post #1 of 4 Old 05-02-2017, 04:11 AM Thread Starter
Rudy046
Hi, Gang!
I have a 2014 JGC Overland with a 115v plug in the center console facing the rear.
The plug mount has somehow broken and I was wondering how to get it out.
I know there is a wiring harness at the bottom of the plug mount, but I can't get at it.
Does anyone know how to remove this part (and get it back in there once the new one has the wiring harness installed)?
Cheers,
Rudy
Rudy046 is offline
post #2 of 4 Old 05-02-2017, 03:09 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I've not been there, but if its like a 2011, the FSM says you use a trim stick to remove the rear center console bezel. Then remover the retainers securing the duct work to the rear center console panel. Then you should be able to reach the outlet. There are clips holding the outlet, which normally you'd release and push the outlet through the panel. Dunno whats up in your case, however.
I think the trim removal PDF referenced in one of the sticky threads provides some detail of the console.
Rudy046 likes this.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 4 Old 05-03-2017, 11:52 AM Thread Starter
Rudy046
Hi, Cold Case.
Thanks for the information!
In your post you mentioned "Sticky Thread" regarding a "trim removal PDF".
How would I go about finding a "Sticky Thread" on trim removal?
Thank you
Rudy046 is offline
post #4 of 4 Old 05-03-2017, 12:07 PM
ColdCase
ColdCase's Avatar
2011 WK
The link is indexed in the following thread, although I don't think it will be much help.
http://www.jeepforum.com/forum/f309/...e-ups-1325215/
ColdCase is offline
