Cargo carrier ever interfere with backup sensors? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Cargo carrier ever interfere with backup sensors?
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 06-21-2015, 05:30 AM   #1
HSTNJEEP
2015 WK
Thinking of installing a curt hitch on my 2013 that does not have a factory towing package. I did I the same on my 2004 WJ. Having done this, I know the hitch will be lower than a factory installed one. Anyone ever have an issue using a cargo carrier (with cargo in it) triggering the backup sensors? I imagine the items being hauled will sit lower than the sensors. Just curious though.
HSTNJEEP
2015 WK2 Limited 4x4, 3.6, Granite Crystal Metallic
2013 WK2 Laredo, 3.6, Mineral Gray
HSTNJEEP is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 06:46 AM   #2
TJSport97
2014 WK
Just put a Curt hitch on my daughter's X3. Nice unit for sure. Do you have a button to disable the back up assist? My '14' Overland does but it also has factory tow package.
Have a nice day. Gary
TJSport97 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 07:34 AM   #3
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
If your carrier is sitting low enough to be out of view of the park sensors, I think its going to be dragging on the ground. I always turn my sensors off when using a carrier or towing.
There will be a button on all Jeeps with parking sensors, some of us don't like to be beeped at when backing out of the garage and just keep them off
The carrier does not seem to interfere with crosspath detection.
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 07:48 AM   #4
HSTNJEEP
2015 WK
Thank you both-I did not think about that. May need to just turn them off. Judging from your responses I assume others have likely had to do the same when using a cargo carrier with cargo stacked up. Makes sense.
HSTNJEEP
Unread 06-21-2015, 08:46 AM   #5
Nonstop
The carrier absolutely interferes with the sensors with the factory height. Easy to assume since the non OE is lower by +/-2.5" that would be a definite yes as your cargo is right there..
2000 WJ 5.2 V8 4x4...yup
2011 WK2 V6
Nonstop is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 08:49 AM   #6
jacko15
2014 WK
Just want to add that I frequently haul my bicycles on a hitch rack, and need to turn the sensors off. Easy to do with button on dash.
Hers: 2008 Jeep Compass Sport
Mine: 2014 Jeep Grand Cherokee Overland V/6 ORA II
Michelin LTX M/S 2's
jacko15 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 10:14 AM   #7
mx71
2013 WK
Bicycle rack and dirtbike rack trigger the beep. Trailer doesn't. Just turn off the sensors.
- A Jeep product
- Other vehicles
- Motorcycles
mx71 is offline   Reply With Quote Quick reply to this message
Unread 06-21-2015, 01:16 PM   #8
TJSport97
2014 WK
Yeah, that's why I put the hitch on my daughter's X3. Didn't even bother with wiring for lights.
Unread 07-28-2015, 12:18 PM   #9
HSTNJEEP
2015 WK
Do the sensors ever sound when backing out of your garage (if it is a one car garage)?
HSTNJEEP
Unread 07-28-2015, 12:51 PM   #10
jacko15
2014 WK
Yes, if you come close to the door jamb.
Unread 07-28-2015, 12:53 PM   #11
ColdCase
ColdCase's Avatar
2011 WK
Mine will sound on occasion, but I think it's the cross path detection doing it.
Unread 07-29-2015, 08:25 AM   #12
goodburbon
1997 XJ Cherokee
Yep, it beeps. Since i dont spend much time in reverse its a non issue.
goodburbon is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 01:05 PM   #13
akinney
I'm probably an idiot, but where is the button to turn off the backup sensors? Mine sound continuously when backing up with my hitch cargo carrier. I just turned the volume down, but it was annoying and I couldn't find a way to turn it off.
akinney is online now   Reply With Quote Quick reply to this message
Unread 07-29-2015, 02:53 PM   #14
dcorn
Bottom of the center console toward the drivers side. Should be right above the hatch where the usb and power point is.
My front/rear sensors go crazy when going in or out of my 1-car garage. They are basically beeping the entire time I'm parking.
2014 Jeep Grand Cherokee Summit
dcorn is offline   Reply With Quote Quick reply to this message
Unread 07-29-2015, 03:58 PM   #15
lurtonk
Drive it like u stole it
2015 WK
To the left of the Eco Mode switch
lurtonk is offline   Reply With Quote Quick reply to this message
