Cannot add files to HDD - JeepForum.com
post #1 of 6 Old 02-18-2013, 08:21 PM Thread Starter
idaho04
2011 WK
2011 Limited 5.7, RHR entertainment.
I have added my music to the HDD in the past using the USB from my smartphone. Recently, when I connect my smartphone via USB it does not see it, it can see only CD. Anybody has a clue why that is?
idaho04 is offline
post #2 of 6 Old 02-19-2013, 09:21 AM
boyvan
2012 WK
Memory full? Simple question but often overlooked especially in computers
_______________________________
2012 JGC Overland - Max Steel
boyvan is offline
post #3 of 6 Old 02-19-2013, 10:37 AM Thread Starter
idaho04
2011 WK
No plenty space, checked that. It should still see the USB.
idaho04 is offline
post #4 of 6 Old 02-19-2013, 12:20 PM
Stratcat70
2014 WK
Some Smartphone's have a setting how they 'appear' on the USB bus. You might check if there is some setting within the phone so that it appears as a mass-storage device. Do you have a thumb drive with music on it that you could try instead, to see if it is recognized?
Jeep Engineer from 1998-2001 on the WJ
2014 Limited V6 True Blue Pearl coat
Stratcat70 is offline
post #5 of 6 Old 02-19-2013, 09:29 PM
Dr. Internet
From my experience:
Phone must look like a disk drive to the radio. When you connect it, the display will ask about charging, pass through, disk drive or something similar.
When using a thumb drive, it wants to see FAT formatting, not NTFS.
Don't copy when driving. My first attempt resulted in recording a lot of skips and jumping around.
Good luck
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #6 of 6 Old 02-21-2013, 09:50 AM
superserialMBP
2012 WK
Just use a thumb drive, as others suggested and plug it into the USB port on the radio face.
2012 Laredo X : QTII, 430N nav, true blue pearl
superserialMBP is offline
