Can one convert a qt2 to a qd2? - JeepForum.com
post #1 of 10 Old 02-18-2014, 09:18 AM Thread Starter
Tlacuache
(2014, GC Overland) Is it possible/feasible to convert a qt 2 system to a qd 2? If so, what is the expected cost?
Tlacuache is offline
post #2 of 10 Old 02-18-2014, 09:21 AM
jim_in_PA
2012 WK
If possible, you'd be replacing a substantial portion of the drive train and also entering into potential challenges with the vehicle electronics. And it would be major expensive. If you want/need QD, it may be less expensive to trade in what you have now for a vehicle that's equipped the way you want it. This is not a simple conversion; it's more of rebuilding the vehicle. Now if you win the PowerBall...
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #3 of 10 Old 02-18-2014, 09:41 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Its been discussed here before, the consensus is it would be less money to trade the QT vehicle for one with QD, probably be more reliable to.
As a minimum the entire rear diff assembly would be replaced, a QD control module added, some wire harness work, the traction control computer updated, the ECU and ABS computers reprogramed with the new capability (and to turn rear brake traction control off)... if you can find a dealer that knows how to do that and is willing to.
If you are thinking about just replacing the diff from a donor vehicle and not integrating the diff control with traction control (e.g. a separate diff control switch), the ELSD diff uses a stepper motor and you need a more sophisticated controller than a simple switch to operate it. The OEM controller operates off the CAN bus. Someone clever may be able to hack something, but it won't be integrated.... and I dunno how you would disable just the rear brake traction control without throwing codes. That seems to be the one of the biggest hurdles with many of these mod attempts, getting rid of the fault codes.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 10 Old 02-19-2014, 07:41 AM Thread Starter
Tlacuache
Thank you both very much. It appears that I would have a better shot winning the power ball than successfully converting over from a qt2 to the qd2 system. I also do appreciate the detailed technical explanation...
post #5 of 10 Old 02-20-2014, 07:20 AM
loveracing1988
Would you really need to disable the brake traction control for the rear? It needs a decent amount of wheel spin to operate so in theory the ELSD should kick in before the traction control has a chance to. That is just one of the problems anyways but just a question.
loveracing1988 is offline
post #6 of 10 Old 02-20-2014, 09:43 AM
ColdCase
ColdCase's Avatar
2011 WK
I dunno, may work. They do go to a lot of effort to disable the LSDs when ABS is activated, so there may be some unwelcome vehicle dynamics. Axles locked together while ABS is trying to stop one or both wheels.... you have the engine trying to spin the drive shaft but can't because the ELSD is locked and brakes are applied... something is gonna give maybe.. although the torque converter may prevent damage... it could get ugly.
I suppose for off road slow speeds it may not be a problem.
Oh, by the way I played powerball yesterday and won $7..
ColdCase is offline
post #7 of 10 Old 02-20-2014, 10:26 AM Thread Starter
Tlacuache
Congrats ColdCase on your power ball winnings.
Although both systems can get you where you need to go, both off road and in slippery conditions, if qd 2 was rated a perfect 10 in the worst case scenario (meaning that the qd2 can bail you out without any additional assistance), were would qt 2 rate? 9 out of 10...8 out of 10...7 out of 10...?
post #8 of 10 Old 02-20-2014, 02:26 PM
ColdCase
ColdCase's Avatar
2011 WK
I don't think there is a simple answer. In my opinion there are bad situations where a good driver and QTI is better than QTII and QTII better than QD.
QD's advantage is preventing wheel spin before it happens, important when you are stoplight-stoplight racing (no rear wheel spin and without power robbing BTC), on rocks with several tires off the ground, or when starting from a stop in a slippery situation. QD just doesn't spin the tires as much. QTII and QTI is better where you don't want both rear tires spinning for stability. QTI can be smoother than the others, as QTII/QD clutch operation seems to be abrupt in many situations.
If you are in so deep that QTII is not going to bail you out, QD is probably not either. The low range in QTII and QD will probably make it easier to get out of a really tough situation than QTI, or make it easier to modulate the engine power to creep along at a slow rate. All in all there are probably many more likely situations where QD has just a bit of advantage over a QTII vehicle other things being equal.
ColdCase is offline
post #9 of 10 Old 02-22-2014, 11:25 PM
xJoshxx
2012 WK
I just scream america and stomp the gas on the SRT let SRT system do it's werk Basically a modified QT1. even in 6-8 of stuff .
Basically trade it in for a QD model.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #10 of 10 Old 02-22-2014, 11:48 PM Thread Starter
Tlacuache
That seems to be the con census...
