Buy Bright Roof Rails for 2014 Laredo (base)? - JeepForum.com
post #1 of 7 Old 11-06-2013, 11:42 PM Thread Starter
pt2005
2014 WK
Hi all,
I have a Laredo base without the bright roof rails. I've been searching online (eBay, Amazon, and even Mopar) to purchase the bright roof rails (those in the Larado X, or Limited, etc that would fit into the Laredo) but no success. The Laredo I have already has the housing attached to the roof. Looks like I can screw the bright rails into the housing if I can find them.
Any pointers are much appreciated. Thanks
2014 Grand Cherokee 3.6 Laredo 4x2
pt2005 is offline
post #2 of 7 Old 11-07-2013, 06:54 AM
kstt
I think Mopar missed the boat on this. When I bought my base 2013 Laredo, it was, "okay, throw in a factory roof rack, and we have a deal." I had the black rails, which are essentially just skids. The dealer ordered the rack, and couldn't make it fit. They ended up buying me an after-market Thule, which lips behind the tops of the door frames. I which I'd had them throw in a tow hitch, instead!
Why would Chrysler make a $30 thousand dollar Jeep that WON'T accept there roof rack?
kstt is offline
post #3 of 7 Old 11-07-2013, 07:13 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
I wonder if the 2014s changed roof rails? It was pretty easy to swap in 2011-2013s if you used a couple tricks posted here awhile ago. The Jeep procedure has you drilling out riv nuts, which turns out to be unnecessary. It is bolt on, maybe takes 30 minutes a side.
Mopar used to sell a kit, but you may be able to buy the rails at moparparts or some other outlets. The rails seem to be ~$95 each.
http://moparonlineparts.com/repair-parts.php
On a 2011-2013 the part numbers were 55079172AG and 55079173AG The G is the rev number and may be higher now. You could try to search for those part numbers.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 7 Old 11-07-2013, 08:24 AM
ColdCase
ColdCase's Avatar
2011 WK
post #5 of 7 Old 11-07-2013, 09:40 AM
MickinNY
2013 WK
I agree on them missing the boat & IMHO, they did it by using these flush mounted rails, instead of going with raised rails. I've found the raised rails to be much better for using either Thule or Yakima towers that I've used in the past on other vehicles. Yakima has towers for these flush rails, but I find them more difficult to install & not quite as secure as the old towers. Plus you need an adapter kit for the Jeep, which Yakima will send for free. Not Yakima's fault as I see it. The problem is Jeep going with flush mounted rails.
That's my only nitpick so far, otherwise I love my Jeep. IMO they should have gone with raised rails. And they could/should have extended the rails another 6" or so towards the front, as there is room to do that.
MickinNY is offline
post #6 of 7 Old 11-07-2013, 10:16 AM
ColdCase
ColdCase's Avatar
2011 WK
Most folks don't use roof rails. We never did on our WJ. Why saddle those looking for a base cost leader with $200 excess baggage. But its probably just marketing, an enticement to move customer up from the cost leader model to a higher line model. There are a few of them. Its a marketing thing done my just about all companies for... oh... 100 years or so. Thankfully the rails are an easy thing to add.
post #7 of 7 Old 11-07-2013, 10:45 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I'll piggy back on this albeit slightly off topic - Do Yakima/Thule have towers that fit in the flush rails or does Jeep have special towers for them?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
