Brakes on 2014 Grand Cherokee Summit - JeepForum.com
post #1 of 8 Old 10-24-2013, 04:07 PM Thread Starter
fmesposito
Curious if anyone has put the SRT8 Brembo Calipers on there 2014 GC with 20" wheels/tires? Did you replace just the calipers, pins and clips or did you have to do other brake parts as well?
Also, does anyone know the part number and list price for the OEM Summit Calipers? I wanted to try to negotiate a trade when buying a new 2014 GC with the dealer (trade the OEM Calipers for Brembo) and wanted to know the price difference.
fmesposito is offline
post #2 of 8 Old 10-24-2013, 04:14 PM
Dave2002ti
2012 WK
Why
Other than looks you can achieve better braking with a better pad, better brake fluid, and a nice set of Earl's brake lines. Also routing air to brakes will help with braking. Multi piston pretty brake calipers dont always result in shorter stops and better braking. You probably also need rotors if you are going to this. Then we can discuss why drilled rotors are worth the money.
Dave2002ti is offline
post #3 of 8 Old 10-24-2013, 04:46 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
You can look up list and discount prices for parts fairly quickly on Moparonlineparts.com (a forum sponsor). They should be able to find part numbers for the SRT and Overland brake components and compare. Dunno if rotors are different.
I have read of someone doing this, but I don't recall where.... sorry no help there. Dunno if the ABS needs reprogrammed.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 8 Old 10-24-2013, 06:04 PM
Raptor
You mean swapping the SRT Brembo calipers onto a 2014 Summit? Right..... I'm pretty sure the OEM Summit calipers are the same as the HD Limited and Overland calipers.
This swap has been done before but...............
You do know that although the SRT Brembo calipers will bolt right up to your spindles they will not clear the OEM Summit, Overland, or Limited 20" wheels. You would of course have to swap the SRT OEM 20" wheels as well for this to work. Definitely won't work for the massive front OEM Brembos w/15" rotors without changing the wheels, but on the rear, the OEM Brembos may actually clear the smaller OEM 20" wheels found on non SRT trim levels.
You would need;
The Brembo calipers, SRT 20" wheels, new pads, new rotors, (2) front caliper pins & (2) front anti rattle clips.
Your OEM brake lines, caliper mounting bolts, & OEM M/C can be reused & will all work with the swap.
Raptor is offline
post #5 of 8 Old 10-24-2013, 07:32 PM
CIEGOS
2011 WK
Unless the 2014 20" summit wheels have a different inner diameter compared to the 2011 20" Overland wheels the brembos should fit. The 18" wheel will not. Also, I believe the rotors are 15" but I could be wrong about that.
CIEGOS is offline
post #6 of 8 Old 10-25-2013, 03:22 PM
Raptor
The 2014 20" Summit wheels will not clear the SRT Brembo calipers.
Raptor is offline
post #7 of 8 Old 06-29-2014, 08:55 AM
RangerRon
2014 WK
SRT brakes on Summit
What spacer thickness would allow use of Summit wheel, offset dimensions for both?
RangerRon is offline
post #8 of 8 Old 07-01-2014, 08:04 AM
David1
2014 WK
You know you wont stop any better right? Or do you just want the look?
David1 is offline
