Block heater cord. - JeepForum.com
post #1 of 15 Old 12-06-2013, 05:32 PM Thread Starter
bpbpimajeep14
Block heater cord.
Does anyone else find the length of the block heater cord on the new diesels to be a little short. It does not even stick out of the hood, therefore the hood needs to be open rendering the command start useless. Poor design. My only real complaint so far.
Sent from AutoGuide.com App
bpbpimajeep14 is offline
post #2 of 15 Old 12-07-2013, 09:51 AM Thread Starter
bpbpimajeep14
Am I the only one that lives where these things NEED to be plugged in.
post #3 of 15 Old 12-07-2013, 10:51 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
There was a post a few weeks ago where missing block cords and routing was discussed. I have the V8 and its cord is plenty long for me. I like plugging them in outside the hood as there has been more than once I've backed out forgetting to unplug. Makes you look kinda foolish when you trail a yellow snake down the road
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 15 Old 12-07-2013, 01:42 PM
AKHLK
Originally Posted by bpbpimajeep14
Does anyone else find the length of the block heater cord on the new diesels to be a little short. It does not even stick out of the hood, therefore the hood needs to be open rendering the command start useless. Poor design. My only real complaint so far. Sent from AutoGuide.com App
Hubby and I have a 2012 V8 GGC. Once we located the cord and un-bundled it we realized that our cord was also too short to be routed outside the front. We had to add a short extension cord and pull it through near the tow hook to be able to use it easily.
AKHLK is offline
post #5 of 15 Old 12-07-2013, 03:05 PM
6.5kev
2014 WK
I'm glad I saw this. We just got ours and I didn't even want to try starting it since it was 25 below last night. Too bad it doesn't have the right length cord. Maybe I'll add a battery warmer and connect them together before going out the front.
6.5kev is offline
post #6 of 15 Old 12-07-2013, 03:16 PM Thread Starter
bpbpimajeep14
I noticed this morning that even though it was plugged in it struggled a little to start this morning. Granted it was -30 but still it should start relatively easily when plugged in no? I have an 03 cummins that would start even not plugged in.
post #7 of 15 Old 12-07-2013, 04:09 PM
WvTaco
2011 WK
How long was it plugged in?
2-3hours?
Does the wk2 have two batteries like the ram?
WvTaco is offline
post #8 of 15 Old 12-07-2013, 07:12 PM
ColdCase
ColdCase's Avatar
2011 WK
No, one battery.
ColdCase is offline
post #9 of 15 Old 12-07-2013, 10:01 PM Thread Starter
bpbpimajeep14
It was plugged in overnight. I will see again tomorrow morning if it's the same or different. Almost seemed as If the block heater wasn't working.
post #10 of 15 Old 12-09-2013, 05:21 AM
Shibodo
2012 WK
I don't know where I got this, but I have in the back of my mind that the block heater only runs for 60 minutes then shuts off automatically. Gotta check the book when I'm off work.
Shibodo is offline
post #11 of 15 Old 12-09-2013, 07:54 AM
eibyer
Interesting, I just noticed my build sheet includes engine block heater. Never had to use it here in AZ but that was good to know just in case we ever need it. Have to find out where the cord is first
eibyer is offline
post #12 of 15 Old 12-09-2013, 07:53 PM Thread Starter
bpbpimajeep14
The cord is located up by firewall on passenger side kind of wrapped up.
post #13 of 15 Old 12-10-2013, 07:49 AM
2kg4u
2014 WK
The block heater is a simple electric cord leading to a heating element immersed in engine coolant. I am not sure on the JGC, but they are usually installed where a frost plug would go in the engine block. It will heat as long as it is plugged in. I use an external timer on mine to come on in the morning 2 hours before I leave for work.
I have not used the block heater on my new GC yet, but on my previous car you could hear a sound like a kettle of water just before it comes to a boil when the block heater was plugged in. For those of you that use this, if it is quiet enough can you hear a similar sound? If so, it would help to diagnose if the block heater is working or not.
Failing that, a simple continuity test with a multi meter across the two prongs of the plug should tell you if there is a circuit or not. I will check mine and see what the resistance reads as a point of reference for others.
2kg4u is offline
post #14 of 15 Old 12-10-2013, 08:56 AM
eibyer
Possibly from the manual where it says it has to be connected at least an hour for it to help keeping the engine warm.
eibyer is offline
post #15 of 15 Old 12-10-2013, 02:16 PM
Shibodo
2012 WK
Yep, that would be right.
Shibodo is offline
