Block Heater and Coolant Temp - JeepForum.com
post #1 of 6 Old 12-10-2013, 10:28 PM Thread Starter
TPR021
2013 WK
I did some searching, but didn't find what I was looking for. It's been cold here like most everywhere lately, plugged the rig in, once for about 2 1/2 hours, and 4 hours respectively, never heard the expansion of heating metal, and checking the coolant temp upon start it said 100. I don't know what it should be temp wise, just seemed like it should be warmer. Any insight from those w/block heaters? Normal?
Thanks
WK2,Summit,Mineral Grey,Saddle/Black
TPR021 is offline
post #2 of 6 Old 12-10-2013, 10:53 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Why do you need a block heater in Texas? Granted I am not used to heaters myself, but 100 is pretty warm for a starting temperature IMHO.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 6 Old 12-11-2013, 07:09 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
They don't get that hot, just warm. The most obvious thing when using them is that you get heat out of the heater almost immediately, unless it below zero. In that case its obvious the engine is turning over easier.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 6 Old 12-11-2013, 08:14 AM Thread Starter
TPR021
2013 WK
Yeah, I kinda expected that just warm was going to be it. I just didn't hear the expansion like I do on my diesel truck. After all a cold start should read, well, colder!!
Forgot to update my profile,
Washington, St.
Thanks you
TPR021 is offline
post #5 of 6 Old 12-11-2013, 08:26 AM
fun2drive
I will be thrilled in cold temps to see 100F.
That is more than sufficient for starting...
OP what was the ambient temperature?
fun2drive is offline
post #6 of 6 Old 12-11-2013, 09:04 AM
2kg4u
2014 WK
If you really want to see what the block heater is doing for you, try not using it one night and using it the next. To me, the quicker heat in the cabin is nice, but the real benenit is reduced wear and tear on the engine.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
