Blind Spot and garage door opener question - JeepForum.com
post #1 of 12 Old 04-02-2011, 09:32 AM Thread Starter
superdavid
Hi,
I am new in this forum, I bouth a new Grand Cherokee Overland 4x4, Is my first Jeep I like a lot, for the price has many features, but the problem is with the door opener not working and the blind spot . Maybe need a special programming? My other car is Mercedes C63 with similar garage door opener and is working without problem I follow the instructions.
Thanks,
superdavid is offline
post #2 of 12 Old 04-02-2011, 11:32 AM
2011Hemi
2011 WK
Originally Posted by superdavid View Post
Hi,
Thanks,
You can turn the Blind Spot Monitoring on or off in the EVIC controls.
Customer-Programmable Features (System Setup)
Personal Settings allows you to set and recall features when the transmission is in PARK. If the transmission is out of PARK or the vehicle begins moving, a warning message SETUP NOT AVAILABLE, is followed in three seconds by, VEHICLE NOT IN PARK.
Press and release the UP or DOWN button until Setup displays in the EVIC.
Use the UP or DOWN button to display one of the following choices.
Blind Spot Alert
There are three selections when operating Blind Spot Alert. By pressing and releasing the SELECT button once, the Blind Spot Alert feature can be activated in “Blind Spot: Lights Only” mode. When this mode is selected the Blind Spot Monitor (BSM) system is activated and will only show a visual alert in the outside mirrors. By pressing and releasing the SELECT button a second time “Blind Spot: Lights/CHM” mode is activated. In this mode the Blind Spot Monitor (BSM) will show a visual alert in the outside mirrors as well as an audible alert when the turn signal is on. When “Blind Spot: Off” is selected the Blind Spot Monitor (BSM) system is deactivated.
2011Hemi is offline
post #3 of 12 Old 04-02-2011, 08:18 PM
fleuger99
2011 WK
Hi,
Thanks,
I got my garage door opener working without any hassles. I reset the car opener by holding the two outboard buttons until the light flashed rapidly, about 5 seconds.
Then I hit the garage remote button holding it down while also holding down the Jeep garage door opener. I held them both down until again the Jeep opener flashed rapidly. Then I repeated holding both openers down again until the light flashed rapidly. Then it worked perfectly. An FYI. To open the garage door once programed one must hold down the Jeep door opener button for like 2 seconds for it to work. Simply hitting the button won't open the garage door.
2011 JGC Overland V8 in Dark Charcoal On Black
fleuger99 is offline
post #4 of 12 Old 04-03-2011, 04:48 AM
hammer1234
2011 WK
I have a universal garage door opener on my 2001 Toyota Highlander (now my son's beater car) and we also have to hold that one for a bit to work.
hammer1234 is offline
post #5 of 12 Old 04-03-2011, 06:49 AM Thread Starter
superdavid
Blind Spot Alert
Thanks, but some reason this option blind spot is not availble, can verify which option is before and after of Blind Spot.
post #6 of 12 Old 04-03-2011, 07:20 AM
2011Hemi
2011 WK
I don't know what is before or after it in the menu since I don't have that option. The Jeep has to have the ACC (adaptive cruise control) package in order to have the blind spot monitoring.
2011Hemi is offline
post #7 of 12 Old 04-03-2011, 10:41 AM
khuon
2011 WK
Some garage door openers (mainly newer ones) use rolling security codes. In order for me to get mine to work, I first had to "seed" the system by programming a garage door remote. This involved hitting the "learn" button on the opener unit until a learn LED indicator started flashing and then hitting the button on the remote. Then the learn LED went steady. Then I hit the button on the remote again and the LED went off. Now the remote is programmed and synced to the opener.
Next I then used the remote to seed the HomeLink system in the Jeep. I did this by following the "dumb" programming procedure which involves first holding down the button on the remote and then holding down the button on the Jeep's HomeLink system until the HomeLink indicator LED starts flashing. Now the HomeLink is seeded and can be programmed to sync with the rolling code.
The final step is the same as programming the remote. First you hit the "learn" button on the opener unit and wait for the learn indicator to flash. Then you go to the Jeep and hold down the HomeLink button. The learn indicator on the opener should go steady but of course you probably won't see this as you're inside the vehicle. So if you want to verify that this happens then have another person observe the opener. Then you have to release and push the HomeLink button again in order to "confirm" and end the programming procedure. The "learn" indicator should go out at this point.
If you have multiple garage door openers then pay attention as to which one gets programmed to which door. I have two openers and to make it easy, on all my HomeLink equipped vehicles I simply go from left to right with the left door being door one linked to operate with HomeLink button #1 and right as door two linked to operate with HomeLink button #2.
Note - do not park the Jeep directly under the door since this procedure will most likely result in the door going up and down.
khuon is offline
post #8 of 12 Old 04-03-2011, 10:50 AM
khuon
2011 WK
In my Jeep, the BSM setting is nestled between Park Assist just before and Auto-lock Doors just after.
khuon is offline
post #9 of 12 Old 04-10-2011, 08:45 PM Thread Starter
superdavid
I went to the dealer, and they said that my overland have not the option of the blind spot, however the saleman said that all the overland had the option, but is not true
post #10 of 12 Old 04-11-2011, 03:51 AM
IndyBob
2011 WK
Another case of a so called salesman not knowing his product. Some of these folks are just order takers!
IndyBob is offline
post #11 of 12 Old 04-11-2011, 05:47 AM
magr80
2011 WK
The Overland Summit comes with the rest of the warning system stuff. Other models as an option ...
magr80 is offline
post #12 of 12 Old 04-11-2011, 08:42 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
+1
You will see several Limited and perhaps Laredos on the lots equipped with the advanced warning and adaptive cruise package, but surprisingly few Overlands. It is an option on all models but the Summit where it is part of the standard equipment.
ColdCase is offline
Leather Installed Next Week / Color Blind Dabitz WK2 Grand Cherokee Forum 24 06-05-2012 11:01 AM
Setting up Homelink Garage Door Access?? getoutandplay WK2 Grand Cherokee Forum 17 08-19-2011 09:11 AM
Problems linking garage door(homelink) illuzions WK2 Grand Cherokee Forum 14 05-22-2011 01:28 PM
Door pockets LED's mario figueroa WK2 Grand Cherokee Forum 7 03-31-2011 07:15 PM
ACC, blind spot detection, crosspath detect pkg chiscoe WK2 Grand Cherokee Forum 4 02-23-2011 01:44 AM
