Blend door gears repair (no heat passenger or drivers side) - Page 3 - JeepForum.com
 1Likes
post #31 of 179 Old 05-27-2014, 08:37 PM
bdotyjr
I am so glad I found this thread. I have a 2011 Durango with the same passenger's side temperature control issue. The dealer said it was most likely a full dash pull repair ($1100-1300), but when I pulled the silencer panel I found a piece of the suspect gear. I'm 99% sure the gear is my issue as well, but I could not for the life of me figure out how to pull the glove box off. I'd be willing to pay the dealership to repair it if they agreed it was a simple (1-2 hour) repair, but they seem anxious to pull the entire dash out to fix it. Now armed with this information, maybe I can get them to agree that it's an easier fix than first estimated. Thanks for the info!!!
bdotyjr is offline
post #32 of 179 Old 05-29-2014, 03:21 PM
elarm1
2011 WK
Woah you sure did take a lot of parts off! Glove box and plastic behind glove box came off for me and that's it. My A/C went out on the passenger side. Figured it was a blend door and just ordered an actuator just to find out it was fine. It was the plastic gear behind the actuator. The dealer had the gear for 3.29 and the actuator was bought from Rock auto for 18 bucks. In the mean time while everything was on its way, a piece of cardboard kept the door closed so my a/c would still be frigid!!!
2011 Grand Cherokee Overland Hemi QL QDII QLII
5% tint
20" gen2 SRTGC Chrome wheels
InTunes by HemiFever
elarm1 is offline
post #33 of 179 Old 05-30-2014, 09:37 PM
bdotyjr
I picked an actuator gear up from my dealer for $2 and tore into it tonight. It took me about two hours start to finish, including the time it took me to take the actuator apart so I could rotate the output shaft about 90 degrees and get the gear to line up with the blend door gear. From the looks of it, the actuator had over-rotated when the gear originally fell apart. The gears are keyed where they mesh, as are the internal gear splines, so it became easy to see what I needed to do before I put the actuator back on. I know from experience if you try to rotate a shaft with plastic gear reduction that it usually does not end well, and taking the actuator apart was actually a fairly simple task. Once the actuator was installed I fired it up to check, and verified the passenger's side was now able to go hot and cold on command. Success!
Thanks for all who have contributed to this thread. You saved me big time from taking it to the dealership, and momma is now cool and happy! ;-)
bdotyjr is offline
post #34 of 179 Old 05-31-2014, 01:55 AM
Ah673000
This is amazing to me that after 15 years , Jeeps are still having " blend door failures " .
The WJs were legionary for blend door failures ( 1999-2004) . A engineer in Texas designed sold a repair kit that did not require the $1300 dealer fix . Mopar finally adopted the repair and put out a compatible kit . Now I see the WK2 has blend door problems also . Two decades to cure a problem..... Amazing!
Sure hope they have cured the dreaded window regulator issues.
Thanks for the heads up and DIY info.... I will be prepared ..... Not a question of of but when .
Ah673000 is offline
post #35 of 179 Old 07-07-2014, 09:35 AM
ddw1668
[QUOTE=bdotyjr;23300545]I picked an actuator gear up from my dealer for $2 and tore into it tonight. It took me about two hours start to finish, including the time it took me to take the actuator apart so I could rotate the output shaft about 90 degrees and get the gear to line up with the blend door gear. From the looks of it, the actuator had over-rotated when the gear originally fell apart. The gears are keyed where they mesh, as are the internal gear splines, so it became easy to see what I needed to do before I put the actuator back on. I know from experience if you try to rotate a shaft with plastic gear reduction that it usually does not end well, and taking the actuator apart was actually a fairly simple task. Once the actuator was installed I fired it up to check, and verified the passenger's side was now able to go hot and cold on command. Success! (Quote)
I don't see where the gears are keyed to prevent over rotation.......What am I missing?
ddw1668 is offline
post #36 of 179 Old 07-08-2014, 04:39 PM
bluegrassguitar
2011 WK
Thought I had the infamous blend door issue, too, but turned out to be a clogged filter (23000 miles, go figure) and slightly low refrigerant level. The thing will freeze ice cream, now.
bluegrassguitar is offline
post #37 of 179 Old 07-21-2014, 01:27 PM
last2stnd
Intermittent Blower
This past spring my passenger side blend doors were not working so I pulled the glovebox off last night and found it was the actuator gear. I put everything back together and ordered the part. However today, my blower seems to be working intermittently. Anyone know what could have caused this? I tried switching between 'Auto' and manual fan, and it just seemed to turn on for a minute then shut off, then a few minutes later it would come back on.
The only thing I could think is that I didn't unplug the negative wire of the battery, since I only disconnected two light bulbs when I took the glove box off to access the actuator.
last2stnd is offline
post #38 of 179 Old 07-21-2014, 01:39 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Perhaps knocked a blower connector loose... or some ground?
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #39 of 179 Old 07-28-2014, 10:09 AM
Mpadrino27
2011 WK
Intermittent blower possible solution
@last2stnd - This sounds very much like the issue I just recently dealt with. Did you find any small bits of black plastic in the passenger foot well? That's how I found out that mine were broken.
When the actuator gear breaks, it allows the actuator motor to travel beyond it's normal travel limit. Since the PCM controls and adjusts the HVAC system, the computer reads this extra travel as a fault, and signals the vehicle operator of the problem by switching the blower motor on for approximately 1 minute, and off for approximately 25 seconds.
The motors usually don't go bad, but the gears break constantly. I would recommend ordering several just to have on hand until needed, since they're only about $3/ea.
Once you replace the gear and secure the actuator motor, the PCM will begin to cycle the actuator motor to align the blend doors properly. This process could take anywhere from 30 seconds to 5 minutes. If everything is lined up properly, and the PCM detects proper gear/blend door travel, the blower motor should begin to function properly again.
Oh, and I would recommend disconnecting the negative battery cable before repairing the gear problem, as the space is tight, and the air bag actuators are located just above the glovebox door. One good knock might trigger it. Better safe than sorry, right?
Hope this helps!
Mpadrino27
Mpadrino27 is offline
post #40 of 179 Old 07-30-2014, 05:50 AM
ddw1668
Hope this helps!
Mpadrino27
Thanks! The 30 seconds to five minutes for the actuator motor to cycle was causing me to think the system was not working...........Will buy some extra gears. Shame that Jeep can't put better stuff in an expensive vehicle........
ddw1668 is offline
post #41 of 179 Old 10-12-2014, 06:41 PM
jgcsc
Great forum, thanks to all who contributed to this thread. My JGC has the same issue on both sides, I'm still trying to figure out if it's the gears or the actuator itself that's broken. How do I calibrate the actuator, I don't have a scan tool
jgcsc is offline
post #42 of 179 Old 10-15-2014, 04:16 PM
1Clunk
2011 WK
I'm kinda illed up for a new guy here.
I think my TIPM is trying to eat the driver's side actuator motors. It ate the original and trying to eat the replacement.
I hope it doesn't try to eat the transmission or fuel injection.
1Clunk is offline
post #43 of 179 Old 10-18-2014, 09:37 PM
1Clunk
2011 WK
Talked to the Tech at the local dealer today.
Seems that the blend door activator is controlled by the Heater Control Module, not the TIPM.
They're ordering a new Mopar actuator then will determine what's going on.
Will update the results in a few days.
1Clunk is offline
post #44 of 179 Old 10-28-2014, 05:26 PM
mleon
I have the same problem. No heat blowing on the driver's side. I have replaced the actuator but the actuator is not turning on. I see that they commented something about leaving it on for 60 seconds to 5 minutes. Will this calibrate the actuator or what will this do? Are there any further steps I need to do to make the new actuator work? Thanks
mleon is offline
post #45 of 179 Old 10-28-2014, 08:01 PM
Mpadrino27
2011 WK
Originally Posted by mleon
Hi,
I saw your comments about replacing the drivers side blend door actuator. I have replaced the actuator but it seems like it's not working still. It seems like the actuator is not receiving the signal but then I saw where you said to leave it on for 30 seconds to 5 minutes. Is this to calibrate it? Is this the only step you have to do to have the actuators working againg? Hope you can reply and thanks for your help.
Were both gears still intact? The best way to test that the actuator is working properly is to plug in the harness before installing the actuator, and making sure the gear turns a full 360 degrees. IIRC, it does so in 90 degree increments. If it is working, you'll need to make sure the little black gear is properly aligned with the teeth on the blend door, so that the actuator will not travel too far, and break the gear in the process.
When you turn the vehicle off, the computer automatically performs a self-test to on the HVAC system / blend doors. This doesn't truly calibrate the actuator / gear mechanism, but rather just lets the computer know that all systems are working properly (Unfortunately, if they aren't, you won't get any notification on the dash / information screen).
You should be able to hear a slight humming, which is the actuator during test mode. Often, if it is misaligned, you'll hear a loud clicking noise, just before the gear breaks. Even though they are plastic, the actuator motors have quite a bit of torque. The computer test mode can take between 30 seconds and 5 minutes to complete. If everything is lined up properly, and the PCM detects proper gear/blend door travel, the blower motor should begin to function properly again.
Let us know how it goes.
