Blend Door Actuator Problem? - JeepForum.com
post #1 of 5 Old 09-21-2017, 05:56 PM Thread Starter
krazykrames
2011 Grand Cherokee
I lost heat and AC control on the driver's side. I figured it was a broken blend door actuator cam gear because the same thing happened 2 years ago. I took the cam gear off and sure enough it was broken. I replaced that and everything worked good, hot and cold.
A week later I heard some clicking like the cam gear was turning more than it should against the blend door or the cam gear was broke again. Also the heat and AC control quit working. I'm 100% sure it was correctly alined when I put it together.
I took everything apart again and found the gear to be fine. I then figured the actuator gears were messed up inside, I opened the actuator and that was also fine.
At this point I'm I don't know why it stopped working this time, anyone have any ideas?
krazykrames is offline
post #2 of 5 Old 09-27-2017, 06:33 PM Thread Starter
krazykrames
For some reason I keep aligning the cam gear to the blend door and it lasts about a week, then I hear clicking and it gets off alignment again.
Any thoughts?
post #3 of 5 Old 09-27-2017, 06:57 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Sticky/binding blend door?
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #4 of 5 Old 09-28-2017, 09:39 AM Thread Starter
krazykrames
It must be. Is it possible to see the blend door from inside the housing by running an inspection camera down the vent on the dash?
post #5 of 5 Old 10-05-2017, 09:27 PM Thread Starter
krazykrames
Nope, too many twists and turns.
