Anyone have steering vibration issues with RRO lift? - Page 3 - JeepForum.com
post #31 of 53 Old 08-05-2012, 07:09 AM Thread Starter
CaniacNation
I'm going to have the wheels balanced at a shop with the Road Force Balancer this week to see if it helps at all.
CaniacNation is offline
post #32 of 53 Old 08-05-2012, 08:25 AM
Dave2002ti
2012 WK
Stock 18in wheels
Borrow a set of stock 18" OEM wheels and have tires mounted and see if problem is still there. Chances its the tires are slim. Toyo makes a quality product and has excellent quality control unlike Goodyear and BFG.
Best tires shops also offer the ability to balance the tires/wheels while they are on the vehicle.
Did the shop rotate tires front to rear and see if the problem still exists.
Problem may also be the shop and their incompetence. Telling you to live with it isnt good customer service.
Dave2002ti is offline
post #33 of 53 Old 08-05-2012, 09:16 AM
lharrell79
Wow, didn't realize you had the 70th Bronze Pearl. That's exactly what I have. Looks really good with the blacked out grill. How'd you black it? Also, how much of a hit have you noticed on the power and mpg's going to a bigger tire?
lharrell79 is offline
post #34 of 53 Old 08-05-2012, 09:55 AM
Dave2002ti
2012 WK
Btw
You may want to try taking it to the top tire store in your area and see what they say. Top Tire Store is the one the track day guys and girls use for their tires. They will have a competent staff who can properly balance and mount tires and diagnosis tire, wheel and balance issues.
Have you measured you driveline angles etc.
Contact Toyo and see if their tech support has any suggestions. Their tech support is some of the best in the tire industry.
Borrow wheels and tires from another GC owner and mount and see what happens.
post #35 of 53 Old 08-05-2012, 06:50 PM
MaineJeep11
2011 WK
This is good advice Dave, I am going to put my stock wheels/tires back on and see if there is a difference as well. Caniac Nation, the jeep looks great.
2011 Laredo V6, OR1, RR 2.5" lift, ProComp 7036 wheels, 265/70/17 Toyo Open Country AT's - SOLD
MaineJeep11 is offline
post #36 of 53 Old 08-06-2012, 07:41 AM Thread Starter
CaniacNation
I just pulled the grill and back lift gate chrome piece off. They come off surprisingly easy if you just keep pulling with steady/even pressure. Once the first tab breaks free, the rest just lay down and let you have your way with them. I just spray painted them, and honestly they look like Scheiße. I was thinking of pulling them again and use plastidip in the spray can, but I don't think those on here who have used that stuff are 100% happy with the results, so I'll just order the black pieces from Mopar eventually.
BTW, I love the interior of this edition.
post #37 of 53 Old 08-06-2012, 07:51 AM
webspoke
Do the wheels have the oem center bore (71.5) or adapter rings to keep them hubcentric? My combination had vibrations until I could get the hubcentric rings. That reduced it dramatically, and then my tire store takes extra care to balance and mount, including torquing the wheels with them off the ground(someone inside holding the brake). The wider offset also makes any small imbalance feel worse.
2013 White V8 Limited, 285/60/18 Terra Grapplers, 25000 miles problem free
2011 Black V8 Overland, retired at 46000 miles with QL problems
webspoke is offline
post #38 of 53 Old 08-07-2012, 01:38 PM
JeepWK2R
No, the center bore on these wheels is larger. Where did you get you hubcentric ring, and would they be centric to the wheels?
JeepWK2R is offline
post #39 of 53 Old 08-07-2012, 04:10 PM
webspoke
If procomp can't provide them, there are other company's that manufacture them to typical sizes. If you can find out the bore on the wheels, check out motorsport-tech.com they either have or can build one to mate up to the jeep hub and your wheel. Your tire store may be able to source them as well.
webspoke is offline
post #40 of 53 Old 08-08-2012, 07:29 AM
Dave2002ti
2012 WK
Why?
Would you buy a wheel that is not hub centric or doesn't have the rings to make it hub centric???
post #41 of 53 Old 08-08-2012, 08:11 AM
lharrell79
Because they make lug centric wheels.
post #42 of 53 Old 08-08-2012, 08:29 AM
Dave2002ti
2012 WK
Lug centric
Lug centric wheels have always been iffy. I would never buy a lug centric wheel. A wheels needs to be hub centric and the lug nut holes need to be the correct size and in correct location.
post #43 of 53 Old 08-08-2012, 07:15 PM
MaineJeep11
2011 WK
I don't understand the hub centric vs. lug centric - can someone explain to help those of us off that have the non-hub centric aftermarket wheels? Of course, the guy at ProComp and the shop that sold me the wheels never mentioned this issue, but shame on me for not being informed. Thanks
post #44 of 53 Old 08-08-2012, 07:41 PM
masscomguru
Hub centric wheels lock to the center ring of the hub. They are guaranteed to be centered on the wheel. Lug centric means that the lugs are used to center the wheel.
masscomguru is offline
post #45 of 53 Old 08-08-2012, 07:56 PM
MaineJeep11
2011 WK
That is what I thought, thanks for the info. I'm going to check w/ ProComp again to see if they have the centering disks or whatever they're called.
To the OP - any update with your setup?
Brand New 2012 JGC Overland Quadra Lift already having issues on Day 1. JGCenthusiast WK2 Grand Cherokee Forum 35 09-24-2015 01:28 AM
Radio Control in Steering Wheel Issues: Anyone Else? ThatSickRip WK2 Grand Cherokee Forum 19 07-03-2012 10:36 AM
Vibration LMI500 WK2 Grand Cherokee Forum 2 05-24-2012 05:08 PM
Vibration during acceleration.. sdlimited WK2 Grand Cherokee Forum 2 03-06-2012 11:11 AM
odd sound / vibration 56-70 mph ZZVitas WK2 Grand Cherokee Forum 6 10-23-2011 06:28 PM
