Any issues going to 20" wheel on Laredo X? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Any issues going to 20" wheel on Laredo X?
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 06-11-2011, 09:06 AM   #1
imtheant
My wife and I are looking to purchase a new Laredo X but we want the dealer to swap out the stock wheels for the 20" Overland wheels. Will the stance/ look be about the same as the Overlands model eventhough we wont have the adjustable air ride suspension or will I need to look into lowering/lifting the truck? I just want the Laredo X to look like the Overlands do. Any thoughts?
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline   Reply With Quote
Unread 06-11-2011, 09:56 AM   #2
kkuntz01
Personally I'd stick with 18's but that's me. The 20's may look a l'il nicer but the 18's will be have a l'il smoother ride due to the taller side wall.
Plus cheaper when it comes time to replace tires.
Sure my rig has seen the trail, but I wheel it like a soccer mom looking for a parking spot at Nordstroms.
kkuntz01 is offline   Reply With Quote
Unread 06-11-2011, 11:05 AM   #3
ColdCase
ColdCase's Avatar
2011 WK
The 20 inch stance would be near identical to an 18 inch equipped WK2 if you use the stock tire size. The stance would also be the same as the limited with the 20 inch wheel option, if you've seen one of those. There would be more wheel/less tire sidewall with the 20s but overall the stock 18 and 20 inch tires are the same diameter and width.
I think the laredo look would be close to the normal height overland look, not the park or the off road heights. Just saying that because I'm not sure what the overland you saw was set too.
ColdCase is offline   Reply With Quote
Unread 06-15-2011, 01:44 PM   #4
mchassler
2011 WK
The factory tire & rim combos, whether the 265/60r18 of the 265/50r20, offer a near identical size... 30.5 x 10.43.
You will be fine.
2011 Wk2 Limited 4x4, Hemi, Tow IV, 2.5" Lift, Tinted Tails, Sharkfin Antenna
2010 M-Benz R350 4matic, PP1, AMG package,
1988 Ford Mustang GT, 5.0 V8, 108,000 original miles (1st car in HS)
1998 ZJ, Mopar Crate V8, Custom 9" Lift w/ 35" BFG MTs (sold Dec '08)
mchassler is offline   Reply With Quote
