Anoyed by Wiper Controls with Rain Sensing Wipers - JeepForum.com
post #1 of 13 Old 02-21-2014, 06:54 AM Thread Starter
i20sailor
2014 WK
Seems like the Chrysler Engineers did not think through the design/layout of the wiper controls when they added the rain sensing feature. They just retained the design that has been in place since the invention of intermittent wipers. I hate that I can't do a single wipe without rotating the control know past off. My last 2 cars had the wiper controls on a separate stock and a quick tap down would initiate a single wipe without having to disengage the rain sensing setting.
i20sailor is offline
post #2 of 13 Old 02-21-2014, 07:08 AM
2kg4u
2014 WK
Turning the knob in the opposite direction and releaseing it will give you a single pass without engaging the rain sensing setting.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #3 of 13 Old 02-21-2014, 07:16 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Yeah, but I find that the moisture sensing feature is so effective that it is rare that I need a single wipe and twisting the knob is not all that inconvenient in that case. An easy "mist" single wipe was very useful on other vehicles without the moisture sensor, however. Chrysler just does it differently.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 13 Old 02-21-2014, 07:23 AM
kkreit01
I hated that feature on my previous Lincoln. I didn't see why they even had intermittent intervals. They had a mind of their own, and it couldn't be defeated. I could get a single wipe just by changing speeds, but after that wipe, they wiped whenever they felt necessary -- which wasn't when I needed it. They were OK for a steady rain, but a real pain for drizzle/sprinkles.
kkreit01 is offline
post #5 of 13 Old 02-21-2014, 07:42 AM Thread Starter
i20sailor
2014 WK
Actually, I don't think it works that well in all situations (i.e spray from other cars, very light mist). That's why I would like to have a single wipe without having to disengage the rain sensing.
post #6 of 13 Old 02-21-2014, 07:43 AM Thread Starter
i20sailor
2014 WK
I know this. You are missing the point. I want to initiate a single wipe without disengaging the rain sensing and then having to re-engage at the setting I had.
post #7 of 13 Old 02-21-2014, 07:54 AM
2kg4u
2014 WK
Then turn it up one setting and back down again. That will initiate a single swipe without disengaging rain sensing.
Roy
2kg4u is offline
post #8 of 13 Old 02-21-2014, 08:58 AM
hemispin
2014 WK
I found the rain sensing feature just about useless. It was hopelessly random at best. It's one of the first things I disengaged.
hemispin is offline
post #9 of 13 Old 02-21-2014, 09:03 AM
ColdCase
ColdCase's Avatar
2011 WK
What sensitivity setting have you tried? Do you use anything like rainX on your windshield? I agree there are situations where one needs a single wipe and the sensor misses it, but for me that is rare. Perhaps I have better sense than others
Oh, like others have said, when I want one wipe, I just click the sensitivity setting on stop and back.
ColdCase is offline
post #10 of 13 Old 02-21-2014, 10:07 AM
TurboRush
Thats what I do.
I'll also say I hate hate hate hated rain sensing wipers. They were the most useless thing in the 2 Lexus' I owned... light mist, FULL SPEED, downpour.. n i c e a n d s l o w.
I was happy the Jeep had a way to disable them and figured I'd be disabling them right away. However, the Jeep implementation has been one of the best I've experienced IMHO (not saying it does exactly what I want, but its right a lot more than other cars I've experienced).
TurboRush is offline
post #11 of 13 Old 02-21-2014, 11:32 AM
jim_in_PA
2012 WK
Just turn it one "click" and back and you'll get a single wipe.
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #12 of 13 Old 02-21-2014, 03:39 PM
kloubik
2014 WK
I believe the WJ had this done much better (and I have to say I was surprised how well the rain sensing wipers worked on my 2004 Overland). If I remember correctly one could engage the automatic wipers and if needed a single tap towards on the lever did a single wipe without messing with the rain sensing settings.
BTW, having to turn the knob to get one single wipe on my current 2014 WK2 is one of the most annoying things and whoever designed it should feel ashamed for such a lousy job. Not only it is very clumsy but you also have to completely take one hand off the steering wheel to be able to do it! Imagine passing a semi in the rain when you suddenly need an extra wipe to see something at all...is this a moment you want to take your hand off the steering wheel and having to perform some clumsy movement with your hand to get a quick single wipe?
I sometime wonder why we have multiple buttons on steering wheels to control all kind of smart phones, multimedia etc comfortably. And on the other hand, to control things like wipers that play a lot into being safe on the road is done the way it is in the current WK2.... not ergonomic at all.
kloubik is offline
post #13 of 13 Old 02-22-2014, 10:23 PM
MattXJ
2014 WK
+1 - I find myself rarely needing to do this very often tho, as it does a pretty darn good job most of the time on its own.
89 XJ (Ltd): RE 3.5", full leafs, 3/4" coil spacers, RE monotubes, JKS Adj trac, tcase drop, OME steering stab., BFG AT 31x10.5xR15s on 15x8 3.75bs, Borla cat-back
14 WK2 SRT: DiabloSport catch can, Borla S-Type
MattXJ is offline
