Another AC question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Another AC question
New Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition CoiEnjoy 5% off in April 1997-2006 Jeep Wrangler Door Weather
Unread 04-11-2015, 06:10 PM   #1
HSTNJEEP
2013 WK
Another AC question
Took a short trip today and used the AC...it could just be my imagination, but I swear the air (although it seems good and cold) does not seem to be blowing as hard from the vents as I remember it did last summer. Last summer was my first to own the Jeep. Blower has seven settings, and I don't remember ever going past 5. Even here in Alabama.
I think I went to setting 4 today: but again, I seemed to remember it blowing harder last summer.
What could cause that?
HSTNJEEP
2013 WK2 Laredo, 3.6, Mineral Gray
2004 WJ Special Edition, 4.0, Graphite Metallic
HSTNJEEP is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 07:09 PM   #2
14summithemi
2014 WK
Clogged or really dirty ac/cabin air filter could.
14summithemi is online now   Reply With Quote Quick reply to this message
Unread 04-12-2015, 05:41 AM   #3
HSTNJEEP
2013 WK
I replaced it last August. That is another reason this is puzzling. Filter might have 9,000 miles on it at most.
HSTNJEEP
Unread 04-12-2015, 08:43 AM   #4
kryogen
2011 WK
I have that same question. Sometimes this winter, I couldnt get it to blow hard enough to defrost the windows. Even at max, it was blowing really "medium-low at most".
There is an issue somewhere but I don't know what....
2011 Grand Cherokee Overland V8
kryogen is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 09:10 AM   #5
14summithemi
2014 WK
IMHO, your problem is not a blower speed/force issue but more of a general lack of flow vents directed at the window surface. My point is that even a hyper turbo blower, with the current vents, would not be sufficient for northerners and their fogging issues. I know this is not a widely reported issue but I have to agree that my MY14 is far worse at defrosting than my '02 JGC was.
I had my '02 JGC dash out 4 times for heater core, blend door, recirc door and actuator probs and I was not impressed with the design of the whole setup as it relates to "installability". By that I mean that with all the foam tape, weird un-even matching channels, etc.. it was obvious that it was nearly impossible to install this unit 100% correctly even at the factory for tight airflow, etc...So much so that seeing these deficiencies I was able to vastly improve (better foam tape, taking my time to align everything) the airflow just by assembling and installing correctly.
I am willing to bet that the current hvac boxes share some of these deficiencies. Case in point, I can never get the faces vents to stop blowing some air. When I am on windshield and feet, for example, I also have to shut the actual face vent louvers to stop airflow from hitting my face. It was absolutely unbearable until I got the "hot box" fix done.
Unread 04-12-2015, 02:39 PM   #6
Sondra3
2014 WK
Gives new meaning to the term 'hot head' doesn't it!
(sorry, I couldn't resist)
2014 GC Overland Hemi, Quadra II, Tech Package, Black Forest Green
2004 Laredo Columbia Edition
Sondra3 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 03:20 PM   #7
14summithemi
2014 WK
Or...yours is the best I can come up with!
Unread 04-12-2015, 06:18 PM   #8
JeepGC6855
2014 WK
In my opinion, the 2013 and earlier Grand Cherokees had a much better climate control system
2002, 2004, 2005, 2009, 2014 Grand Cherokee Limited, 2014 Wrangler
JeepGC6855 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 06:51 PM   #9
HSTNJEEP
2013 WK
Anyone get the hissing sound from the AC? Lasts about 1 to 2 seconds each time it does it. My 2004 WJ does it often. My 2013 WK2 does it mainly when you first turn the AC on (from off position). But occasionally will do it while in AC mode.
HSTNJEEP
Unread 04-12-2015, 07:10 PM   #10
HVACNY
HVACNY's Avatar
2013 WK
Are the arrows on the filter going in the same direction as the air flow(down).If not it would restrict the airflow..
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 07:12 PM   #11
kryogen
2011 WK
so far the jeep hvac system is the least reliable I ever had.
It fogs, fan speed varies, sometimes I get almost no hot air on the feet, sometimes I do.
Not clear enough to go to the dealership yet...
Generally I think that it's bad. Never had a car perform that bad in winter. The jeep is a fogging nightmare. I just keep it at max setting all winter....... defrost/feet.
In the maxima I could keep it at 4/8 and it wouldnt fog. In the jeep it's max fan speed or it fogs like hell. And sometimes it does fog anyway.
I have to use the remote start all winter to get it warm before I leave, or it will fog like crazy, even with max fan speed when cold. (no car did it as bad before).
Oh well.... I'll get rid of it before my extended warranty is over in 2017. Whatever.
