Another 2014 GC rattle solved. - JeepForum.com
post #1 of 7 Old 12-28-2013, 09:39 PM Thread Starter
NC4stroker
2014 WK
So, my friend has a 2014 GC limited 4X4 with less than 2K miles, and they've been noticing a rattle, which seemed to emanate from the center of the dash.
I got under the vehicle and started tapping around, and I found the forward most skid plate bolt to be very loose. Interestingly enough, the noise was very loud going very slowly down the road, say < 5 MPH, and would disappear when turning right.
Here is a pic and vid.
Youtube Capture is acting funny, so I'll try to upload the short vid later.
Here is the vid.
NC4stroker is offline
post #2 of 7 Old 12-29-2013, 09:45 AM
2014RedHemiGC
2014 WK
One advantage to changing your own oil - checking everything underneath and tightening when needed.
2014 Deep Cherry Red GC 4X4 V8 QDII
2012 Crystal Red Cadillac CTS-V Coupe
2011 Crystal Red Chevy Corvette Z06/Z07
2014RedHemiGC is online now
post #3 of 7 Old 02-22-2014, 09:55 PM
JG_2008
I looked into this on my 2014 GC Limited. The rattling on my GC was not coming from this. Still have not found the what is causing the rattling. My rattle is coming from upper dash somewhere.
JG_2008 is offline
post #4 of 7 Old 02-23-2014, 03:11 PM
ChrisCicc
Have you checked the sunglass holder?
ChrisCicc is offline
post #5 of 7 Old 02-23-2014, 04:22 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
That rattle used to drive 2011-2012 owners nuts
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #6 of 7 Old 02-23-2014, 08:21 PM
13ovsummit
2013 WK
I've got a rattle when going over certain road bumps coming from the head-liner, right in front of the sun-roof. I can duplicate the noise by tapping the head-liner slightly. Seems like a small amount of foam rubber inserted into the gap up there would probably cure the problem. I hesitate to try to get the dealer to mess with it for obvious reasons, but was wondering if any 2013 GC owners with a sun-roof have the same rattle?
13ovsummit is offline
post #7 of 7 Old 02-23-2014, 08:32 PM
JG_2008
I checked the sunglasses holder. It was not that. I fixed the rattle I heard coming from the driver's side upper dash. The noise is caused by a hose that is not properly attached the firewall in the engine compartment.
Here is a link to the fix, jeep garage. org/f107/2014-v6-rattle-61377-12.html
Remove the spaces in URL and it will work.
JG_2008 is offline
