Amplifier Bad in WK2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK2 Grand Cherokee Forum > Amplifier Bad in WK2
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 11-03-2014, 12:08 PM   #1
cpgerlach
Wk Amplifier Bad in WK2
All modes of stereo (AM/FM, CD, HDD, Aux) in 2011 JGC are static, crackly, white noise, can barely make out sounds. Otherwise, it works. Dealer told wife that the internal amp is out due to a code B142D on a diagnostic. Not understanding the electrical in detail, is there an internal AND external amp? We're happy with the audio (when it was working). Do we have to replace the whole front unit? Where is the best place to purchase one of these? Thanks!
cpgerlach is offline   Reply With Quote Quick reply to this message
Unread 11-03-2014, 12:25 PM   #2
2kg4u
2014 WK
The only external amp is in the vehicle rear, so if the dealer described it as the front amp it is most likely in the radio, and requires a new radio. You also likely need the dealer to program the radio to your vehicle. Which radio do you have and what is the vehicle build date. If you PM your VIN to me I can look up which radio it has.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline   Reply With Quote Quick reply to this message
Unread 11-03-2014, 01:05 PM   #3
cpgerlach
Last 8 of VIN are BC546655
Unread 11-03-2014, 08:34 PM   #4
E-rok
Had the same symptoms. Dealer replaced amp in rear, fixed it. Think theres a tsb for it.
2011 WK2 Laredo X Hemi
2013 Ram 2500 Cummins
E-rok is offline   Reply With Quote Quick reply to this message
Unread 11-03-2014, 09:03 PM   #5
cpgerlach
The stereo is the 430 (RBZ). Any idea why this would happen, especially after just 3 years? Can the internal amp be fixed or replaced? Seems silly to have to replace the entire unit at a cost of $567.75 from the dealer. Also, the antenna was broke a couple years ago ... looks like a remnant of the old is in the female threaded antenna hole. It could probably be taken out if some effort was put into it, although we've never had an issue with reception and so haven't bothered. $271.49 to replace the radio, antenna, and base. Grand total of $976.91 so my wife can have music etc in her car again. Thank goodness she called me and I had her hold off. Is this a known issue with the 430? Any advice appreciated. Thanks!
Unread 11-03-2014, 09:07 PM   #6
cpgerlach
Thanks E-rok. I'll look into that.
Unread 11-03-2014, 11:53 PM   #7
goodburbon
1997 XJ Cherokee
As far as antenna remnants, a left hand drill bit and an ez out should take about 10 minutes if you're very careful and slow.
Heat is the enemy of electronics. Amplifiers are great heaters It is possible that the air circulation around the amp is diminished by the need to keep things hidden.
Sent from AutoGuide.com Free App
goodburbon is offline   Reply With Quote Quick reply to this message
Unread 11-04-2014, 07:49 AM   #8
2kg4u
2014 WK
Rear amp p/n is 5064533AI, but AJ, AK and AL are compatible. Radio p/n is 5064685AM. There are no other amps shown, so if they are telling you it is the front amp it is integral to the radio and does not have a serviceable part number.
Best price I see for the radio is $650 on Ebay (http://www.ebay.com/itm/2011-2012-20...ht_2562wt_1363)
Vehicle was originally built as an Enterprise rental.
Roy
Unread 11-04-2014, 09:22 AM   #9
kkreit01
If these items are out-of-pocket, it's the perfect time to go aftermarket. It will be cheaper, sound 10x better, and be much more flexible. I had the 430 in my car. I wanted to make it sound decent, and add a backup camera. In the end, it was much cheaper to replace the 430 with an aftermarket DDIN DVD, than to purchase a lockpick & DSP.
kkreit01 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2015, 08:52 PM   #10
cpgerlach
Thanks. Still dealing with this issue. Dealer reset the external amp in the rear, but did not fix the problem. No goodwill $ from Chrysler due to mileage in the 90Ks. Any recommendation as to a proven aftermarket unit that works reliable with all the other functions? Since I can't DIY this kind of thing, I guess my best bet is to throw parts at it at the dealer?
Unread 01-29-2015, 10:34 PM   #11
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Only the base Radios use an internal amp to drive speakers. The rear amp, if installed, has digital and proprietary connections to the radio head, and it feeds all the speakers. You are not going to find plug and play. There have been folks replace the amp with aftermarket, but that can be a lot of work. You may want to check with a couple auto audio system installers and see what they can do.
Looks like a replacement rear amplifier is less than $300 at forum sponsor moparonlineparts.com
2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6, 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline   Reply With Quote Quick reply to this message
