"Alice", my WK2 Laredo 4x4 - Page 21 - JeepForum.com
post #301 of 394 Old 02-05-2014, 04:38 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Originally Posted by eibyer View Post
I want to see that roof top tent when you get it set up. I've seen videos of it but I have this fear of rolling out of the tent and onto the ground.
lol. Well...it is a regular tent (except for the built in metal bottom, built in pad, etc so it closes up completely. I would only worry about someone coming along and knocking the ladder down thus dropping half the tent.
The RTT probably wont happen until summer but I will post it up!
2011 Billet JKUS
Jackal01 is offline
post #302 of 394 Old 02-14-2014, 01:04 PM
JeepGC73
2013 WK
When do you think you'll get those alt. center caps for the TKOs? I'm back to thinking I'm going to order those... might pull the trigger soon
'13 WK2 V6 LIM | 18x9 MB TKOs | AFE GT Intake | Sprint Booster | RRO Leveling Kit | RRO Rails
JeepGC73 is offline
post #303 of 394 Old 02-14-2014, 01:12 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Before our CO trip in June. Lol
Trying to squeeze more life out of these tires before I buy my next set. Not happy with the passenger version of these tires. Probably only going to last 35k with regular rotations. At 31k now. LTs are the next set.
Sent from my underground lair.
2011 Billet JKUS
Jackal01 is offline
post #304 of 394 Old 02-14-2014, 02:58 PM
JeepGC73
2013 WK
Haha nice. Yea I'm thinking I'm going to order them soon... next month or so.
Sucks about the tires. GL on the next set!
JeepGC73 is offline
post #305 of 394 Old 02-14-2014, 03:07 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
I wish I would have paid more attention when I bought them but I didn't. Had a brain far I guess. I think I'll get Terrace Grapplers again just LT.
2011 Billet JKUS
Jackal01 is offline
post #306 of 394 Old 02-16-2014, 04:26 PM
rbevans
You answered this is another thread, but I figure I'll post here for others to see. I have a WK2 without the QL and my stock tire size is P245/70R17. I saw that you went with P265/70R17 after you purchased. Was that before you went with the lift and if I was going to go with that tire size should I have any problems?
Black 2012 WK2 Laredo
rbevans is offline
post #307 of 394 Old 03-01-2014, 08:24 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Ordered a rear tire carrier from CBI that plugs into the hitch. Also ordered a Cobra 75 as a kit with a Wilson antenna, mount, speaker and meter.
2011 Billet JKUS
Jackal01 is offline
post #308 of 394 Old 03-07-2014, 09:53 AM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Got the CB and antenna mounted and running. I am not a fan at all of the cable in teh door jamb. I am most likely going to drill a 1" hole , use a grommet and RTV sealant in the plastic that butts up against the grey portion of taillight. Won't be seen. I am having trouble tuning the antenna, also. I am sure I will get it eventually. The cable runs along the plastic and under the plastic and carpet from the OBA all the way to the front driver side where the CB box is located behind the center stack. The antenna is a Wilson 4' Flex and the CB is a Cobra 75.
Edited. No longer mounted to plastic. On the D post.
2011 Billet JKUS
Jackal01 is offline
post #309 of 394 Old 03-07-2014, 10:13 AM
eibyer
Very cool, thanks for the pics! Is that no ground plane antenna?
eibyer is offline
post #310 of 394 Old 03-07-2014, 11:06 AM
SilverbackWK
2013 WK
Very nice. I am doing the similar myself, abandoning the hitch mount idea. I am going to mount a bit higher though, above the tail lights, so the mount will be grounded to the cars metal.
2013 Grand Cherokee Altitude, 3.6L, 275/65/18 BF Goodrich TA KO, MTB KO 18", RRO 2.5" Lift, BWoody Extended Sway Bar Links, RRO Winch Mount with Combo Bar (modified), Warn Zeon 10-S Winch, RRO Sliders, Mopar Hitch and Tow Hooks, Rigid Industries Lights, GoPro Hero3 Black edition, Cobra 75WXST, 4' Firestik II
SilverbackWK is offline
post #311 of 394 Old 03-07-2014, 11:09 AM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
That is my understanding. I have never had a tunable antenna before so I am new to that aspect. My readings are all over the place. Maybe it is because it needs a ground plane but I have not found anything to state that it needs a ground.
2011 Billet JKUS
Jackal01 is offline
post #312 of 394 Old 03-07-2014, 12:43 PM
eibyer
I believe it has to specifically say it is a no ground plane antenna for it to be one. If no markings then you'll need ground plane or maybe try to make it work by running ground wire (additional stuff to hide, yuk). This is the main reason why I went with the ngp version since our mounting points are non-metallic.
eibyer is offline
post #313 of 394 Old 03-07-2014, 02:03 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
The antenna has a ground wire on it already. Nowhere does the packaging say to mount it to a ground plane or anything. It only mentions the ground as a last option if the swr readings are not achieved. I cannot find much info on my antenna regarding install.
2011 Billet JKUS
Jackal01 is offline
post #314 of 394 Old 03-07-2014, 05:20 PM
95GCL
Interested to see how that rear tire carrier turns out
95 zj Laredo, 249tc, 206k miles, 5.2L v8, KOR light bar, Kenwood BT555U Head unit
95GCL is offline
post #315 of 394 Old 03-21-2014, 03:13 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
So I bought a new antenna and cable! I bought a 3' Firestik 2 and the Firestik lo-profile cable. I also moved the mount to the body above the tailights. I am getting 1:3:1 on my SWR. Can't get much better than that!
The brain for the CB is behind the center stack to the right of the accelerator. It looks better than it does in the picture. This as mid-install.
2011 Billet JKUS
Jackal01 is offline
Options on 2011 Laredo vs. 2012 Laredo 10129 WK2 Grand Cherokee Forum 5 02-21-2012 06:39 PM
Oil in a new GC Laredo?? mixer440 WK2 Grand Cherokee Forum 8 02-07-2012 08:51 AM
Can I add OEM Nav to my Laredo-X? rider14x WK2 Grand Cherokee Forum 2 06-08-2011 11:15 AM
Just got my Laredo kmag53 WK2 Grand Cherokee Forum 11 02-19-2011 08:19 AM
