"Alice", my WK2 Laredo 4x4 - Page 18 - JeepForum.com
post #256 of 394 Old 01-13-2014, 01:36 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
The compressor is inside the Jeep. The tank is outside.
Tanks go almost anywhere. Most are designed for exterior use. Compressors are more sensitive depending on the manufacturer. This compressor is moisture and dust resistant, I decided an inside-install would be best since I will not run it unless I need it so noise will not be an issues. The compressor mounting instructions were quite specific on where it can and cannot go but tank...no real requirements that even hinted that my chosen location is unacceptable. And since I won't be running it constantly I am not that concerned with heat. Once I get done with the cover over that hole it is in I will put hinges on it and make it accessible. Maybe put a couple slits for venting of heat. But I ran it till the tank was almost full and nothing was hot or even warm.
2011 Billet JKUS
Jackal01 is offline
post #257 of 394 Old 01-13-2014, 04:20 PM
goin2drt
2017 WK
Yeah I meant the tank sorry. I would think having compressed air exposed to a hard hit from rocks could be bad but I really know nothing. Maybe those tanks are bulletproof. I sure do like that idea to have on board air and that is one clean idea.
2017 GC Trailhawk. Fully loaded in white.
goin2drt is offline
post #258 of 394 Old 01-13-2014, 10:18 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
I could have gone the cheaper route and just used a portable compressor but again...I wanted the ability to use virtually any air tool on the trail, on the road or at home. Not to mention i don't like lots of bags to worry about so this just utilizes dead space and makes the entire process more efficient.
The tank is quite stout. I imagine other, lesser companies have tanks that won't survive down there. I am more worried about the hoses and connections but like I said I still have to tidy everything up including zip ties, heat shrink tubing, cable ties/hose holders on the body and looming.
I fixed all the leaks tonight while staffing at my fire station tonight, too. Took 30 minutes.
Sent from my underground lair.
2011 Billet JKUS
Jackal01 is offline
post #259 of 394 Old 01-15-2014, 09:05 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
2011 Billet JKUS
Jackal01 is offline
post #260 of 394 Old 01-16-2014, 11:45 AM
txwest
2012 WK
Bring on the winch! It's not my mistress we are ripping apart this time!
Current:
'12 GC Overland 4x4 HEMI ORII QL Towing Red/Saddle
Past Jeeps:
'80 CJ-7 I6 4x4 Std
'86 Comanchee I4 4x4 Std
'99 WJ Laredo 4.0 4x4 AWD
txwest is offline
post #261 of 394 Old 01-16-2014, 11:51 AM
eibyer
Requesting more info/pics on that antenna
eibyer is offline
post #262 of 394 Old 01-16-2014, 11:54 AM
txwest
2012 WK
+1
I forgot you even installed it. Hahahaha
Current:
Past Jeeps:
'80 CJ-7 I6 4x4 Std
txwest is offline
post #263 of 394 Old 01-16-2014, 12:53 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
It is made my Laird. It is UHF band 450-470MHz since the frequencies that the area departments use (mostly my FD) are in that range. The mount is a hood, lip mount. Comes with the 20+ ft of cable already attached. I just need to have the plug crimped on. Two hex screws tighten it down and there is a rubber pad on the part that rests against the vehicle. The radio that I use is a Kenwood TK 880 UHF.
2011 Billet JKUS
Jackal01 is offline
post #264 of 394 Old 01-16-2014, 01:42 PM
eibyer
Cool, thanks, do they make dual band antennas like that? I'm taking the test this weekend
I will Google the brand.
eibyer is offline
post #265 of 394 Old 01-16-2014, 01:54 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Test for what?
I haven't seen dual band antennas like this.
2011 Billet JKUS
Jackal01 is offline
post #266 of 394 Old 01-16-2014, 05:03 PM
eibyer
Technician amateur radio license. You're right, they're for a range of frequency only. They do have some that VH/UH but not that compact.
eibyer is offline
post #267 of 394 Old 01-16-2014, 06:20 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
Gotcha. I wanna do that too. One class at a time for me though. Lol. I working on my Arson Investigator cert. Then I will probably do ham.
2011 Billet JKUS
Jackal01 is offline
post #268 of 394 Old 01-17-2014, 08:58 AM
eibyer
The cert you're studying for is more important
eibyer is offline
post #269 of 394 Old 01-17-2014, 09:47 AM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
My job doesn't require it actually since I am just an Fire Inspector not Fire Investigator but it definitely doesn't hurt and possibly may even help me out if our dept ever decides to do investigations.
But when the SHTF and it TEOTWAWKI Arson Investigators won't matter but HAM operators will.
2011 Billet JKUS
Jackal01 is offline
post #270 of 394 Old 01-19-2014, 10:27 PM Thread Starter
Jackal01
Jackal01's Avatar
2011 JK Wrangler
So we finished the winch and bumper install after 10 hours of work. After the half way point I just stopped taking pictures.
My first, solid advice is buy one of the winches RRO has listed on their site. Not from them per se but my Quadratec Q9000s barely fits and it look some cutting and moving of parts that is not part of the instructions. That is because the winch I chose is slightly too big. My mistake for thinking "most" winches were the same size (ones around the same weight class). The KC lights will only fit on the upper "stinger" because the lights are so big (with the HID ballast built in) that they need a lot of space behind them. Just as long as the mounting bolt on the light is behind the majority of the light it will go fine. I will post what pictures I have, most very early on and post-install.
2011 Billet JKUS
Jackal01 is offline
Options on 2011 Laredo vs. 2012 Laredo 10129 WK2 Grand Cherokee Forum 5 02-21-2012 05:39 PM
Oil in a new GC Laredo?? mixer440 WK2 Grand Cherokee Forum 8 02-07-2012 07:51 AM
Can I add OEM Nav to my Laredo-X? rider14x WK2 Grand Cherokee Forum 2 06-08-2011 10:15 AM
Just got my Laredo kmag53 WK2 Grand Cherokee Forum 11 02-19-2011 07:19 AM
