Aftermarket sound system - JeepForum.com
post #1 of 4 Old 02-09-2013, 09:01 AM Thread Starter
Jeep_Brothers
2011 WK
Has anyone hooked up an aftermarket head unit for amps? Is it possible to do that or are there software issues when removing the factory head unit?
I want to hook up a couple amps for a tight sound system I don't have the alpine premium audio.. will this be difficult?
Thanks
Jeep_Brothers is offline
post #2 of 4 Old 02-09-2013, 07:12 PM
RageOfFury
2014 WK
Howdy!
I've replaced the base 6-speaker system and the headunit in my 2011 Laredo E. It's not an easy task at all. It took me a whole weekend, a good 20h of work. Getting the door panels off and back on again is a major pain in the a... It's doable, but you have to plan it out and have the right tools.
I went with an all Alpine setup(speakers + amp) & Pioneer headunit.
RageOfFury is offline
post #3 of 4 Old 02-16-2013, 01:20 PM Thread Starter
Jeep_Brothers
2011 WK
Okay well I got a mono amp and 4 channel amp I need to hook up but the factory head navigation unit doesn't have anywhere to hook up RCA cables in the rear.. so I guess I have to get a new unit which brings me back to my original question.
Now if I get an aftermarket alpine double din unit and a PAC C2R-CHY4 + SWI-RC with mounting kit will that be all I need and there won't be any problems?
Thanks for your input.
post #4 of 4 Old 02-16-2013, 03:48 PM
RageOfFury
2014 WK
Will you be also changing the speakers in the doors?
If you're changing the speakers, using aftermarket amps, then I recommend changing the headunit as well. PAC offers an adapter that will give you RCA outputs from an OEM headunit, but why keep the OEM headunit if you're replacing everything else?
If you go down the aftermarket double din headunit route, you'll need the PAC RP4-CH11 adapter. You'll also need a dash installation kit.
