-   WK2 Grand Cherokee Forum (http://www.jeepforum.com/forum/f309/)
-   -   Accessory switch location, Any ideas? (http://www.jeepforum.com/forum/f309/accessory-switch-location-any-ideas-1325180/)
trooper1968 02-06-2012 06:00 PM
I just installed a Warn Multi-Mount Receiver mount winch, and need a location for the power on/off switch. I was thinking that a location that gave me the option to install a bank of switches would be ideal, especially if I need switches for other accessories in the future.
I see that some have installed switches inside the center console, but I was thinking to the right of the front headlight controls, there seems to be enough room for a Carling Three Position V-Series Switch Holder
http://www.otrattw.com/prodimages/vm3.jpg
Finished dimensions are 3.40 X 2.30 inches
I know cutting holes can be a big deal, but the Carling switch holders look very professional, and allow for less than accurate mounting holes, and you can install flat blanks in the unused holes.
Thoughts? Anyone have a better location?
/cl
drballard33 02-06-2012 08:06 PM
I was thinking the same spot, or lower near the gas door switch. Either spot is good because it's a bit out of the way yet close enough to reach either from inside the vehicle or outside the vehicle.
trooper1968 02-08-2012 03:53 PM
Thanks, I was thinking the same, I am going to pull of the panel this weekend and see how much room is behind the panel.
/cl
JMP8562 03-04-2012 07:06 AM
Did you install it ? if so how about a picture :thumbsup:
hope you dont mind . i added it here to make it easier for the next person. and they can add to it pictures are a great help.
thanks for sharing trooper1968
WK2 WRIGHT UPS
http://www.jeepforum.com/forum/f309/.../#post13171827
trooper1968 06-12-2012 02:06 PM
Ok, I took the plunge and installed a bank of switches below the headlight switch (as you can see the space to the right of the headlight switch was a no go unless you want to do some MAJOR cutting).
For those who want to do the same, it is not for the faint of heart because of the amount of cutting to accommodate the depth of the switches. Anyways, I am pretty happy with the outcome, my only beef is that I sometimes hit the gas cap switch with my knee when I get into the Jeep because it is no longer recessed. I might switch the two power wires so that the switch is in the off position when it up instead of down.
Here is the lower portion of the dash opened up. You can see the new winch power, ACC and ground wires hanging out. You tap the orange w/grey wire for dash lights.
https://dl.dropbox.com/u/2987356/winch_install2.jpg
/cl
Switches installed and ready to go! The switch includes a red light for power and a green light tapped to the dash lights and comes on when the rest of the dash is light up.
https://dl.dropbox.com/u/2987356/winch_install3.jpg
The solenoid for the winch is installed under the hood, with the power cables routed under the truck back to the receiver hitch.
https://dl.dropbox.com/u/2987356/winch_install4.jpg
After the install the winch into the receiver, connect the power and you are ready to go.
https://dl.dropbox.com/u/2987356/winch_install1.jpg
Anyways, I pretty happy with the way it turn out.
/cl
Looney 06-12-2012 02:53 PM
nice install. looks factory to me...:highfive:
2MchFun 06-14-2012 03:40 PM
Nice job! Thanks for sharing.
Jackal01 06-14-2012 04:06 PM
Looking good. Do you travel with the winch in the cab, mounted to hitch or left at home? Going to install a hitch up front?
trooper1968 06-14-2012 07:08 PM
Thanks guys!
I usually have the winch in the cargo area. Although a recent trip to Vancouver where I needed the cargo room, I left it at home. I never thought about leaving it installed on the hitch, but I suspect that it might not be legal to do so.
As for the front, no plans to install a hitch, but I am hoping that ARB comes up with a good looking bull bar bumper.
Rock sliders and a roof rack are next on the agenda.
/cl
Jackal01 06-14-2012 07:19 PM
Is the winch secured in the back in case of a MVA? I don't think it is legal. At least for most states since it sticks out so far. Even if it was legal I wouldn't want to.
JMP8562 06-17-2012 09:49 AM
Thanks for posting the pictures........ Clean look :cheers2:
Wk2flatlander 04-01-2014 08:23 AM
Cable placement with warn quick disconnect
Originally Posted by trooper1968 (Post 13710396)
Ok, I took the plunge and installed a bank of switches below the headlight switch (as you can see the space to the right of the headlight switch was a no go unless you want to do some MAJOR cutting)....
/cl
Nice work.
Do you have any pics of running the 2 gauge cable down the side of your jeep with the disconnect? Any words of advice for running this cable?
The time now is 12:31 PM.
