6500 vs 6800GVW....what does this mean? - JeepForum.com
post #1 of 11 Old 02-14-2013, 05:54 PM Thread Starter
barry1me
barry1me's Avatar
Ok so im a bit confused on the 6500 vs 6800GVW. What does this mean in the sense of how does it affect Payload, or Towing capacity? You can purchase a 2013 Laredo X hemi with a tow package and it will tow 7200lbs, and have a 6500lb GVW, or a 2013 Limited hemi with tow package and tow 7200lbs and have a 6800lb GVW? Im confused on this.
Sport TJ build
everything below has a hyperlink to the install/review
Before you ask about a product in the Technical forums check out the product review section!
barry1me is offline
post #2 of 11 Old 02-14-2013, 06:12 PM
lysol
2013 WK
Google is your friend my friend.
But to answer your thread, GVW (6500lbs & 6800lbs) is Gross Vehicle Weight. Your vehicle should never exceed this weight. This includes gas and all fluids, passengers, luggage, etc... for the vehicle only
The towing capacity (7200lbs) is the maximum weight of the object you are towing.
On a side note, if you read more, you'll see that the tongue rating on the tow package for the Jeep is 500lbs. that is how much downward force is being applied to the hitch.
MINE > '14 JKUR Anvil
HERS > '13 WK2 Overland Summit V8 Mineral Grey
lysol is offline
post #3 of 11 Old 02-14-2013, 06:21 PM Thread Starter
barry1me
barry1me's Avatar
I know what GVW is....I didnt ask the question clearly enough. a Limited 4x4 hemi with trailer tow package (6800gvw) vs a laredo x hemi 4x4 with trailer tow package (6500gvw) both have the same payload capacity and towing capacity. I was just a little confused on they didnt change towing capacity with the HD vs SD brakes.
Sport TJ build
barry1me is offline
post #4 of 11 Old 02-14-2013, 06:45 PM
WvTaco
2011 WK
ok 4x4 hemi
larado gvw is 6500 payload is 1480 but curb weight is 5020
limited gvw is 6800 payload is 1660 but curb is 5150
overland gvw is 6800 payload is 1590 but curb is 5210
on 11 models.
if i had to guess the awnser would be quadra lift.
WvTaco is offline
post #5 of 11 Old 02-14-2013, 08:06 PM
5-90
5-90's Avatar
1988 XJ Cherokee
GVWR = Gross Vehicle Weight Rating - how much you can put on its four wheels. This is determined from the frame, engine, suspension, tyres, brakes, &c.
GCVWR = Gross Combined Vehicle Weight Rating. Weight limit of vehicle and towed load (trailer + payload.)
Tongue Weight = The "downforce" on the trailer hitch/tow point. Usually 10% or less of towed weight (typically, a 1,500# tow rating allows for 150# of tongue weight. A 5,000# tow rating can be anywhere between an allowed 200-500# tongue weight - may be more, may be less.) Tongue weight can be changed by positioning of the load on the trailer, even though total weight does not change.
"Dry Weight" = Vehicle, no fuel, no driver, no passengers.
"Wet weight" = Vehicle, full fluids. May include driver.
"Kerb weight"/"Curb weight" = Vehicle, full fluids, unloaded. Typically does not include driver, and usually also considered "wet weight" (I'm thinking back to ground school for wet weight - but wet weight of an airplane usually does not include anything beyond airframe, engine, fuel/fluids.)
"Payload," obviously, is the difference between GVWR & kerb weight.
Can you overload past GVWR? Often, yes - but you'd better have better tyres than OEM, you'd better drive carefully, and you'd damned well better think ahead WRT stops! Being "overweight" (as far as your GVWR) usually makes any roads incidents automatically your fault, since you're not likely to be able to control your vehicle (steering & braking will both suffer.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #6 of 11 Old 02-14-2013, 08:10 PM Thread Starter
barry1me
barry1me's Avatar
I understand all of what you said above but I was just confused on why they only change the GVW by 300lbs and totally change brakes on jeep, but yet it doesnt provide any increased trailer towing capacity.
Sport TJ build
barry1me is offline
post #7 of 11 Old 02-15-2013, 06:01 AM
lysol
2013 WK
Have you seen the video where they loaded a JGC to the max and performed the "moose test"?
Maybe this has something to do with it?
lysol is offline
post #8 of 11 Old 06-27-2013, 08:41 AM
tdbmd
Sort of a related question, is the 2014 V6 rated for over 6000 lbs GVWR? The reason that I ask is that we may be able to write it off as a work truck if over 6000 lbs
tdbmd is offline
post #9 of 11 Old 06-27-2013, 10:37 AM
tjkj2002
2002 KJ Liberty
Same body,same trans,same engine so it will not change the tow limit.The different suspension will effect GVWR though but not max tow limits.
tjkj2002 is offline
post #10 of 11 Old 06-27-2013, 01:18 PM
WvTaco
2011 WK
6500 it seems for both 2wd and 4x4
WvTaco is offline
post #11 of 11 Old 06-28-2013, 10:51 AM
tdbmd
Thanks
tdbmd is offline
