5.7 Hemi tick - 2012 GC Overland Summit - JeepForum.com
post #1 of 10 Old 08-15-2017, 01:43 PM Thread Starter
myriad360
2008 WJ
Seemed to get better for a bit after changing all 16 plugs ($$$), but I'm back to sounding like a '74 cattle truck. What's the cause, and has anyone found a fix? Lots of other hemi owners online with this complaint, but so far no solid cause or fixes.
https://youtu.be/1G_d6JJ4Yoc
https://youtu.be/_YdXTbQ59Ls
Great XJ Troubleshooting/mod sites list:
2001 Jeep Cherokee 4.0 L Limited, White. Bought in Grangeville, ID 06/11/08. Stock everything.
1998 Jeep Wrangle 4.0 L, Green. Bought in Nampa, ID 02/21/09
1988 Jeep Cherokee 4.0 L, White. Bought in Vancouver, WA in 2003. 1st Jeep, White. Bought with 3" lift, added Pacesetter header and 40 series Flowmaster
myriad360 is offline
post #2 of 10 Old 08-15-2017, 02:18 PM Thread Starter
myriad360
2008 WJ
Hmm, might give this a try. Will report if it helps. http://www.**********.org/f107/hemi-...ner-47182.html
post #3 of 10 Old 08-15-2017, 04:14 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Loose or broken exhaust manifold bolt or a cracked manifold is a common source of a Hemi ticking sound in a broad range of vehicles, just about everything they squeeze a V8 into from cars to trucks. Many mistake the exhaust leak for the hemi tick, but the exhaust leak is a commonly reported fix. Its not the classical valve train tick where there is no fix. Because of production variances one engine's tick may be louder than another.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #4 of 10 Old 08-16-2017, 10:35 AM
mx71
2013 WK
Check oil and exhaust manifold bolts.
mx71 is offline
post #5 of 10 Old 08-16-2017, 04:13 PM
BolderGuy
2013 WK
Annoying thing is that they (exhaust leak vs Hemi tick) sound similar and both go away when the engine warms up. Can you smell exhaust coming out from under the jeep when you start it?
3rd GC. ZJ, WJ and now WK2. Decked out Limited with OME lift running 275/55/20s.
BolderGuy is offline
post #6 of 10 Old 08-16-2017, 11:17 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
A lot of the 'ticking' sounds, especially at idle, is the nature of the direct injection. I had that noise in both my 2011 GC Overland and 2014 GC Summit. Surprisingly, my 2017 has very little noise. All three had/have the 5.7L Hemi.
"In the end...It's all Hack."
HackFabrication is offline
post #7 of 10 Old 08-16-2017, 11:25 PM
azzkicker
2007 WK
My hemi makes an idle tick that I would call a lifter noise, or loose rocker arms. I've had it checked at the dealer, and they say it's normal.
I'm not sure I believe them, but I'm not too worried either because I have a warranty and I really wouldn't mind building a custom hemi anyway.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #8 of 10 Old 08-17-2017, 06:03 AM
ColdCase
ColdCase's Avatar
2011 WK
The V8's cam is high in the block making for awkward pushrod angles. Being high in the block, any valve train noise is heard louder than just about any other engine on the market (the noise has more of a direct path). So you have bad pushrod angles that have a tendency to make noise plus production variances and a more direct sound path that, when combined, make for ticking noises that you don't hear on other engines (the noise is there on other motors but it is harder to hear it). Its normal.
ColdCase is offline
post #9 of 10 Old 08-17-2017, 10:10 AM
WindyCity
Mine has what I would call a normal tick for the hemi. I do run seafoam in the tank every once in a while and it will really help quiet down the tick for a couple thousand miles, but it always comes back. I am currently at 108k in my 11' hemi and it has been the same since day 1.
WindyCity is offline
post #10 of 10 Old 08-18-2017, 05:20 PM
mike12806
Hemi has port injection, not direct
Sent from my iPhone using Tapatalk
mike12806 is offline
