4WD malfunction on the beach (SERV 4WD) - Page 5 - JeepForum.com
post #61 of 240 Old 05-04-2012, 10:37 AM
eibyer
Interesting thread. I hate that thought of the 4WD owners being beta testers for buggy software.
eibyer is offline
post #62 of 240 Old 05-04-2012, 10:01 PM
Chrazy-Chris
2012 WK
Originally Posted by avalys View Post
I just took my relatively new 2012 Overland Hemi (with ORA II / QD) down a long trail here in Colorado. I drove for several miles on loose dirt in 4H with Select-Terrain on "Sand/Mud", and then "Service 4WD" light came on. The 4WD system continued to operate normally, however, except for the light.
I turned the car off and back on, and the light was gone, so I kept going. A few miles later, same thing. Now I am starting to get worried, as the trail is essentially a 12-mile long descent, with no way out except back up the hill, and it was highly unlikely I'd make it out without 4WD. But everything was still operating fine, except for the light, and I was not in any mood to turn back around.
For some reason, it occurred to me that I had never driven this long a distance before in Sand/Mud mode, so I "rebooted" the car (again, clearing the light), and left it in Auto for the remainder of the descent (another 8 miles, maybe). No problems whatsoever.
On the way back up, I kept it in 4L and Sand/Mud mode the whole time, and again had no problems.
I suspect the vehicle does not like being left in 4H in Sand/Mud mode for a long period. Maybe too much heat generation in the transfer case with the variable torque split changing all the time. Running it in 4L locks the transfer case, which explains why it would tolerate that better.
I will ask the dealer tomorrow when I bring the car in (one of their wheel weights fell off on the trail, ) to check the codes and see if he can tell me what happened - but that's my theory.
This seems like a logical explanation... I appreciate your thoughts on this because I will be doing a lot of muddy road driving (Nebraska Dirt Roads + rain/snow= Mess) as well as getting through deep snow (sometimes with a layer of ice underneath.. quite challenging). I anticipate using the QTII settings in 4hi..... now I know what to expect. It's too bad because the way you have to drive this stuff is all about momentum... 4hi > 4low. Maybe I'll just stick to the auto setting. I wish there was a temp gauge for the transfer case and transmission. That would be a cool option for the ORA package.
2012 Laredo V6, 26X, QTII ...coming Oct 2012
Chrazy-Chris is offline
post #63 of 240 Old 05-05-2012, 08:29 PM
ColoradoGrand
2015 WK
Chrazy-Chris
Thanks for the tip. We plan on making several off road excursions this spring and will keep it in the Low range auto mode. I can't wait to see if we are able to traverse Hancock pass in the collegiate peaks area. It's good to hear from another Colorado Springs person.
ColoradoGrand is offline
post #64 of 240 Old 05-05-2012, 09:05 PM
Chrazy-Chris
2012 WK
Well don't take it as a tip from me... I was just applying what avalys said.... I don't even have my Jeep yet. It sounds like the safe bet is to stick to Auto for 4hi and use 4low for the other setting if you're going to have it there for awhile.
From my experience with other 4x4s, you also don't want to keep it in 4low for too long unless you're pretty much "crawling" the entire time because it is geared for low speed, high torque. I never used 4low much in Nebraska because "crawling" through deep mud or deep snow is just asking to get stuck... you want to be able to just keep your momentum going and expect to have all 4 tires spinning. Climbing up the Rocky Mountains would be a different story.
I'm pretty excited to make the move to CO. I've been cooped up in Los Angeles for a few years now and am ready to get back to the great outdoors.
post #65 of 240 Old 05-06-2012, 09:15 AM
Greg012GCO
2012 WK
Welcome back to high altitude and attitude Love CA, but nothing like living in the sky.
Greg012GCO is offline
post #66 of 240 Old 05-08-2012, 12:47 PM
gloworm
2014 JK Wrangler
I have just got my European diesel spec overland summit and it features transmission temp gauge in the menu :-)
gloworm is offline
post #67 of 240 Old 05-08-2012, 01:45 PM
z06vette1
I was finally able to have the dealer capture a code thrown by the four wheel drive failure that I experienced within the first 100 yards that I had driven on the beach. The jeep is finally "fixed" or so they say it was a front axle wheel speed sensor? I will update further when I look at the service invoice. I hope to help the others that have had this unresolved issue. I don't believe that it is attributed to excessive slippage or heat like same may have claimed. Glad to finally have some objective data from the dealer
z06vette1 is offline
post #68 of 240 Old 05-08-2012, 04:52 PM Thread Starter
jgiuliani
That's awesome z06vett1, once I see your post I'll forward the information on to my service manager to see what he has to say. thanks!
jgiuliani is offline
post #69 of 240 Old 05-08-2012, 07:51 PM
ColoradoGrand
2015 WK
gloworm
I was reviewing the various functions within the EVIC the other day and you can scroll through to a screen that reports the trans temp.
post #70 of 240 Old 05-08-2012, 08:17 PM
z06vette1
Newirth motors in Wilmington NC was able to finally solve this issue. I will post the exact sensor as soon as I see the invoice my wife took the car to the dealer and I have not seen the work order myself. H
post #71 of 240 Old 05-08-2012, 09:58 PM
Chrazy-Chris
2012 WK
Great, glad to hear it's getting fixed and that it sounds like it turned out not to be an overheating/overworking issue. ColoradoGrand- which trim do you have? I wonder if that is a feature on all EVICs or just the Overland.
post #72 of 240 Old 05-09-2012, 07:36 AM
onebluemcm
2015 WK
Is it only in 4-low that the transfer case is locked? I've never had a vehicle with a locking or limited slip transfer case, only the typical locked ones, I guess. I've only ever had Ford Rangers that were 4x4 - I assume even in 4-high these were a "locked" transfer case.
onebluemcm is offline
post #73 of 240 Old 05-09-2012, 07:41 AM
WvTaco
2011 WK
My larado x has it. It's in the menu with oil pressure, oil temp, and engine hours.
Just thInk of the high range as a clutch LSD diff
WvTaco is offline
post #74 of 240 Old 05-09-2012, 08:31 AM
Kev M
2012 WK
By the very nature of the system there are very few (if any)? AWD systems that use a locking transfer case, UNLESS it only locks under certain circumstances. And truthfully, any system that is on all (or can be on all) the time is really an AWD system - even if it's got the basic architecture of a 4wd system (i.e. transfer case with front and rear differentials).
You don't want a locked transfer case under most driving conditions, which is why systems like the QT1 and QT2 are designed to vary torque distribution front-to-rear under so many circumstances.
Kev M is offline
post #75 of 240 Old 05-09-2012, 09:28 AM
onebluemcm
2015 WK
So, and I think I know the answer to this, with the system in the new GCs, you cannot ever get it truly into a 2WD/rear wheel drive only mode - correct? I'm realizing this now, but wasn't totally aware of it I guess pre-purchase. It is marketed as a "4x4", so I guess I kind of assumed that it would have a 2WD mode. Normally I research the h#ll out of everything, probably assumed too much with this one though...
SERV 4WD warning light redjeep11 WK2 Grand Cherokee Forum 6 12-04-2011 05:33 PM
Tee Time / Pebble Beach / Great Commerical! hobbie1 WK2 Grand Cherokee Forum 0 08-13-2011 01:36 AM
Serv 4WD Jxferrara WK2 Grand Cherokee Forum 5 06-01-2011 05:08 PM
Beach / soft sand driving mf012e WK2 Grand Cherokee Forum 3 02-17-2011 08:07 PM
