4wd check? - JeepForum.com
post #1 of 9 Old 02-20-2013, 04:04 PM Thread Starter
prweaver
4wd check?
I'm about to purchase a 2011 4wd (qt1) JGC at what seems like a very good deal... With the full time system how do I confirm it is 4wd and not Rwd just being passed off as 4wd?
prweaver is offline
post #2 of 9 Old 02-20-2013, 04:12 PM
Kev M
2012 WK
Look under it. If it's got a transfer case and front axles, you're good.
Kev M is offline
post #3 of 9 Old 02-20-2013, 04:15 PM Thread Starter
prweaver
I'm not very mechanically inclined; can you link me to a picture of the transfer case to know what I'm looking for?
prweaver is offline
post #4 of 9 Old 02-20-2013, 04:23 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
While looking at the EVIC display between the gauges, start the WK2. It will display "QuatraTrac I" or II if its a 4WD.
A 4WD vehicle will have a drive shaft going to the front axle and a front differential. These will be missing from 2WD and there will be a lot of empty space.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #5 of 9 Old 02-20-2013, 04:35 PM
Kev M
2012 WK
A transfer case is a box usually behind the transmission with two driveshafts coming out of it. One that goes back to the axle for the rear wheels and one that goes forward to the axle for the front wheels.
The shafts are what turn the axles, and the axles turn the wheels.
I suspect everything else could be faked, but if the shafts are there you should be good.
Kev M is offline
post #6 of 9 Old 02-20-2013, 04:36 PM
Kev M
2012 WK
Not that I would expect someone to try and pass such a new vehicle off as a 4x4 if it's not.
Kev M is offline
post #7 of 9 Old 02-24-2013, 02:33 PM
WvTaco
2011 WK
http://www.wk2jeeps.com/wk2_vin.htm
matches mine. 1j4rr4gg
WvTaco is offline
post #8 of 9 Old 02-24-2013, 02:48 PM Thread Starter
prweaver
Originally Posted by WvTaco
Perfect!! Thanks so much for this.
prweaver is offline
post #9 of 9 Old 02-24-2013, 03:45 PM
Kev M
2012 WK
I've removed four wheel drive from used vehicles and added it to others. Just to be clear, the VIN only tells you what left the factory and you could be deceived.
Kev M is offline
