4Lo stopped working - JeepForum.com
post #1 of 8 Old 01-06-2014, 07:25 PM Thread Starter
cloner63
2015 JK Wrangler
4Lo stopped working
Was an idiot and became stuck in a a ditch during the snowstorm. Complete stupidity on my part. I was pulled out after by a pickup, but it took a fair amount of effort. At first my 4wd Low was fine, but during the course of pulling me out my front wheels stopped churning. No error messages, but it did lurch a bit at a couple of points. I took it out of 4Lo and put it back in, but it did not help. Always indicated 4Lo. It feels like I only have RWD. I have quadradrive on my 2012 Overland. Did it just overheat, will it reset, or is it likely cooked?
cloner63 is offline
post #2 of 8 Old 01-06-2014, 09:19 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Hard to tell, 4lo is direct coupling I think. Could be broken front axle, front diff, front driveshaft, transfer case chain. I've heard of some that have destroyed a front axle half shaft. But you are going to have to do some troubleshooting. Get under and take a look. If nothing obvious, jack one front wheel off the ground and try to spin it, if you don't notice anything unusual, put it into 4low and try to spin it. You shouldn't be able to turn it.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
post #3 of 8 Old 01-06-2014, 09:59 PM
modernblueWK
If you break a front axle, driveshaft the jeep will not move forward unless its in 4lo. If your transfer case is damaged then there should be lights telling you so. I wonder if the brakes overheated from spinning wheels trying to get out?
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #4 of 8 Old 01-07-2014, 03:13 AM Thread Starter
cloner63
2015 JK Wrangler
Thanks for the comments, guys. I drove it about 6 miles after getting out (in snow mode) and no warning lights. I hear no unusual sounds. I just know that only the rear wheels were spinning at the end of the ordeal. I did spin those wheels a lot. I will have to wait until after work to troubleshoot. Like I said - nothing "seems" wrong except I lost the front wheel spin towards the end of the extraction. I was embarrassed all the way around.
cloner63 is offline
post #5 of 8 Old 01-07-2014, 01:38 PM
ColdCase
ColdCase's Avatar
2011 WK
Right, I keep forgetting that its only wheel spin that will lock the transfer case... and with a busted axle there will be no wheel spin.
ColdCase is offline
post #6 of 8 Old 01-09-2014, 08:00 PM Thread Starter
cloner63
2015 JK Wrangler
Update. The dealer says the transfer case clutches were worn, and the electronics to shut down the 4wd. This was covered under warranty (the good news). They are replacing the whole transfer case. The bad news is it is on back order and may be 2-3 weeks. In the meantime they cleared the codes and it " may" work. I am driving it until the part arrives. This is the first time I got stuck, and it concerns me that the 4wd failed.
cloner63 is offline
post #7 of 8 Old 01-09-2014, 08:14 PM
1slosvt
I wouldn't worry about it too much now- you're getting a whole new transfer case! I hope everything works out well for you! Hopefully the weather will be calm while you wait.
-2012 JKUS
-2014 GC Laredo
-2k xj
1slosvt is offline
post #8 of 8 Old 01-09-2014, 08:36 PM Thread Starter
cloner63
2015 JK Wrangler
Thanks! That is the bright side. And I will be much more careful about how I treat her. I really was an idiot.
cloner63 is offline
