2015 LED DRL is Purple - JeepForum.com
post #1 of 8 Old 11-19-2015, 08:36 AM Thread Starter
mcl52
I have a 2015 Grand Cherokee with the LED daytime running lights. I just noticed that one of the individual LED bulbs is a bluish purplish color. Not sure when this happened - there is currently 11K miles and had it for about 11 months. Is this a warranty issue? Seems like it would be an expensive part to replace. Anyone experienced something similar?
mcl52 is offline
post #2 of 8 Old 11-19-2015, 08:38 AM
danlikescoldbeer
2015 WK
I've seen a few threads on it, premature failure. I believe they will warranty it.
2015 Grand Cherokee Altitude
1999 XJ
danlikescoldbeer is offline
post #3 of 8 Old 11-19-2015, 08:45 AM
2kg4u
2014 WK
I've seen that on other JGC's on the road, although not 6 or 8 together like that. I agree, those are failed LED's and I would think warranty would cover it. To my knowledge the entire headlamp assembly has to be replaced.
Roy
2014 Overland, 3.6 L
Fumoto Qwikvalve, Ionic CXV running boards, Michelin X-Ice Xi2 snow tires
2kg4u is offline
post #4 of 8 Old 11-19-2015, 10:33 AM
murderedoutGC
2016 WK
I dont remember the exact figure but i do know that your jaw will drop when you hear how much they are....
2016 GC Overland High Altitude White on black
murderedoutGC is offline
post #5 of 8 Old 11-19-2015, 11:42 AM
jim_in_PA
2012 WK
It's "just" an LED failure which can happen sometimes. Your dealer should replace it for you under warranty...that's been the case with other incidents that I've seen posted.
2012 JGC Summit Hemi
2016 Subaru Outback Limited
2011 Subaru Outback Limited
jim_in_PA is offline
post #6 of 8 Old 01-12-2016, 10:52 AM
lamstang94
I'm having the same issue. One dealership says the warranty is 12 months 12,000 miles. I have 16,000 on my 2015 GC and they say it will cost $1200. Another dealership says it is covered under the 3 yr 36,000 warranty. Anybody know the real true answer.
Thanks
lamstang94 is offline
post #7 of 8 Old 01-12-2016, 10:57 AM
murderedoutGC
2016 WK
Thanks
idk the warranty answer but when I looked into buying them to install on my jeep they were a grand a piece so not sure why it would cost you $1200 to have it fixed.....
post #8 of 8 Old 01-12-2016, 11:31 AM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Things like replaceable light bulbs and brake pads are considered maintenance items and are covered for 12,000 miles. The headlight LEDs are not replaceable short of replacing the entire lamp assembly. That should be covered for 36,000 miles. Pm member Jeepcares with the question, they are FCA customer service.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is offline
